rohan Posted February 15, 2013 Share Posted February 15, 2013 Can anyone tell me if when an F18 is parked up, can the tail fin rudders be angled out from the tail fin in opposite directions on the tails? I see pics which appear it is like this. Can anyone clarify that? Link to comment Share on other sites More sharing options...
Juggernut Posted February 16, 2013 Share Posted February 16, 2013 I've usually seen them angled inwards but if hydraulic power is off and the controls aren't locked, I suppose angled out is possible. Most of the google images I've seen show stagnant hornets with the rudders in trail or angled inwards. There is one shot of an adversary hornet with at least one rudder angled outward. I can't make a call on the opposite rudder though, if it's angled outward, it's only a couple degrees as there's not much light showing through the gap between the top of the rudder and the bottom of the stab cap. Link to comment Share on other sites More sharing options...
rohan Posted February 16, 2013 Author Share Posted February 16, 2013 Thanks Tim. Yes I thought the same as you. If the hydraulics are off and not locked they should move anywhere you want them either side's rudder completely independent of the other. Funny how you have seen them inwards and Ive seen them outwards. Link to comment Share on other sites More sharing options...
Dave Roof Posted February 16, 2013 Share Posted February 16, 2013 All of these photos were taken on the same day. All are from VMFA-115 and all aircraft are obviously shut down. First jet has both rudders toed outboard. Second jet has both rudders straight. Third jet has both rudders going to starboard. Fourth jet has both rudders toed inboard. Photos prove they are all correct, so display your model as you see fit. If anyone tells you you're wrong, ask them how many hours they have working on or around the real aircraft. Just sayin' Dave Link to comment Share on other sites More sharing options...
rohan Posted February 16, 2013 Author Share Posted February 16, 2013 Cool thanks for that. That settles it. Many thanks for your time. Ive made them slightly both outward. Ive done a 3 Sqn RAAF low viz markings F18A Op FALCONER (OIF) 2003. I might post it here but how do you post photos? Link to comment Share on other sites More sharing options...
