thierry laurent Posted June 9, 2010 Share Posted June 9, 2010 Hi! Typhoon units used trainings rockets in 1944-45. It seems that they were made of the classical rocket body with a cement warhead. I guess that if you want to put rockets on a postwar Typhoon, you should probably use such rockets on Mk3 rails, shouldn't you? Does anybody know a picture showing such warheads? I'd like to know if they look like the classical frag or AP ones (aerodynamically shaped). TIA Link to comment Share on other sites More sharing options...
Kagemusha Posted June 10, 2010 Share Posted June 10, 2010 They were the standard 60lb type, all black. There was an article in AIR Modeller sometime ago, I no longer have it - went on ebay - but I did take some pics of the illustrations, if you pm me your email addy I'll send them you. Link to comment Share on other sites More sharing options...
Edgar Brooks Posted June 11, 2010 Share Posted June 11, 2010 This was an experimental fitting. Edgar Link to comment Share on other sites More sharing options...
Barry Posted June 11, 2010 Share Posted June 11, 2010 Same double stack set up was done for the Mossy was it not? Barry Link to comment Share on other sites More sharing options...
Edgar Brooks Posted June 11, 2010 Share Posted June 11, 2010 It was similar, but this one was an attempt to link two rockets together, as a single package; the Mosquito set-up still utilised single rockets, although, of course, the salvo could still be used. Anyway, this is the back end, which is normally unseen Edgar Link to comment Share on other sites More sharing options...
thierry laurent Posted June 14, 2010 Author Share Posted June 14, 2010 Thanks Edgar! If I analyze correctly the pic, the dimensions seem to be than same than the ones of the classical HE 60lb but with a blunt nose. Thierry Link to comment Share on other sites More sharing options...
Edgar Brooks Posted June 14, 2010 Share Posted June 14, 2010 Absolutely true; the body was a standard diameter drainpipe, with a threaded end, onto which the choice of head could be screwed. Edgar Link to comment Share on other sites More sharing options...
