kensar
LSP_Members
  • Posts
    281
  • Joined
  • Last visited
Everything posted by kensar
  1. I have finished this Williams Bros 1/32 Caudron C.460 racer that won the 1936 Thompson Trophy and the Greve Trophy race. Flown by Michel Detroyat. The build was a simple one with few parts. The aged decals did present a challenge, but I managed to save them with Microscale Liquid Decal Film. I added some internal structure visible in the wheel wells and cockpit. The pilot figure is from Immense Miniatures. I replaced the kit landing gear with wheels from the parts box and scratched the struts. The plate oil coolers are bare metal foil, and are not drilled out, as so many modelers mistakenly do. The oil cooler plates have dimples in them, not holes. The dimples create a turbulent boundary layer in the air that flows over them, facilitating heat transfer. This is the second in my collection of Williams Bros kits.
  2. I've been somewhat negligent at posting updates, but there is not much to this model. I have found some more interesting wheels in the parts box and the decals were a nightmare - they wouldn't release from the backing paper and had to be peeled off at the very high risk of being torn. I used some decal saver liquid to help in this regard. After a clear coat to seal the decals I should be finishing this soon.
  3. Excellent work, Marcin. I love it.
  4. Here I am showing my Williams Bros Gee Bee R-1 which I have just finished after several years on the shelf of delay. It depicts the 1932 Thompson Trophy winner and was flown by Jimmy Doolittle. It's made OOB except for the propeller hub, which I remade from aluminum. I did not include the thin black pinstripes separating the red and white colors as I could not think of a way to produce them in scale. The pilot figure is from Immense Miniatures.
  5. Here is a Dora Wings Caudron C.631 sport plane made in the 1930s. It was used to set multiple intercontinental flight records from France to places like Tokyo, Japan and Madagascar. This particular plane was flown by Andre Japy from Paris to Tokyo, but crashed in Japan, severely injuring Japy. This is an out of the box build, typical for limited run kits. Thanks for looking and comments are welcome.
  6. Excellent work Marcin! Creative re-use of parts from other models and very nice scratchbuilding. Where did you obtain the drawings you are basing your build on?
  7. I've been wanting to do an automotive subject from the early 1950's Grand Prix races, but there are no really good models. I came across this Heller kit and decided this was it. I upgraded a number of items, the spoked wheels being a must do. I also put in a wire grill and added a number of small details on the body and hood. The dashboard is made from aluminum HVAC tape that was 'machine turned' with a Dremel stone. The instrument bezels are turned on the lathe and aftermarket instrument faces were used. The drum brakes are turned aluminum as are the wheel hubs. The rims are turned from ABS pipe and the spokes are monofilament fishing line. Thanks for looking and comments are welcome.
  8. Started this recently - a Williams Bros 1/32 Caudron C.460. I will model the 1936 Thompson Trophy winner as pictured on the box art. I am adding some detail in the cockpit and wheel wells. Engine plug with pushrod detail in brass. I am adding a pilot figure. This is a figure from Immense Miniatures that has been re-posed to a large extent. Also rebuilding the landing gear for sharper detail. This brings me up to date. Comments welcome and thanks for looking in.
  9. Thanks Mike. I appreciate you taking the time to comment.
  10. I figured it was time to do my first Bf109 and this Eduard weekend edition kit fit the bill. I built it out of the box. Used AKI lacquer paints. Does anyone else think their RLM02 is too green? I used a grayer color for the interior surfaces. I was impressed by the level of detail and the decals. Thanks for looking in.
  11. That would go nicely with my Micro Mir Junkers W34!
  12. A lot of people are doing autos lately and I just finished this, so ... This is a fictious Carrera Panamericana racer from the 1954 race. I started it over 10 years ago and lost momentum on it. Just decided to finish it as a change of pace.
  13. I picked up this kit at a model show for $10, so I was willing to accept some inaccuracies and difficulties in building, but I was pleasantly surprised. The box art is not very impressive. I can't attest to the accuracy of the profile because I didn't compare it to line drawings. The kit has only one build option - for the V6 prototype. This model is of the C-1 variant - the ground attack version with the short wingspan. The panel lines on the wing look correct for this plane. The kit gives me the impression of a limited production kit. The parts count is very low, similar to Hasegawa's Macchi kits. There is a PE fret included. The gray plastic is quite soft. The panel lines are okay in width, but vary in depth in different areas. The kit radiator is for a Dora 9, not a Ta152, so I used a Quickboost resin part, and the prop blades don't look correct, so I used an Eduard prop from the parts box. The engine plug looked lacking in detail and I added an ammo box up in the fuselage, but unless you turn the model upside down and look into this area, you can't see these details anyway. The decals are good and settle nicely with some setting solution. There is a ridge on the wing root that is on the inside of the wheel well that really needs to be filed away, or it appears the wheels would not go into the wheel well. This is the first model I used MRP paints and I'm not impressed with how the paint crazed the bare plastic, so if you use MRP paint, be sure to prime first. The parts fit is good. I would not hesitate to buy another HB kit in this line of subjects. I do wish HB would produce an H version with the long wingspan, but the differences between the C and H versions mean the H would be a completely different kit.
  14. A simple kit with few parts, but looks good when completed. I did get the Quickboost radiator insert and used an Eduard prop. Thanks for looking.
  15. The LZ38 was the first zeppelin to bomb London in 1915, leaving 7 dead. I have depicted this airship here with the Takom zeppelin P class LZ38. This kit does not have many parts, but is quite challenging to build due to small PE parts with no spares. I scratchbuilt the gunner's platform on the top, as it is supposed to be on the top of the hull, not set into it as the kit has it. I photographed the model against a black background as if it were on a night time flight, and photoshopped out the supporting rods. Thanks for looking in.
  16. Anyone know if the Amazon price is likely to increase after it's published?
  17. Thanks, everyone, for the kind comments and the 'likes'.
  18. Here is my build of Roden's Sopwith Strutter kit. I have replaced the kit engine with a Vector Clerget 9 engine and made numerous scratchbuilt parts. I have represented the flying wires with tubing and monofilament. The kit has a typical Roden flavor with improved wing strut locating pins and holes. I have depicted a USAS strutter of the 90th Aero Squadron flown by Lt. H. R. Ellis and Lt. P. B. Schuss out of the Ourches aerodrome in France in July 1918. The research work was done by George Grasse, to whom I am grateful for his effort. The plane still had French markings as it came from a French squadron. I hope you enjoy the pictures.
  19. I am using MRP paints for the first time on a Hobby Boss TA-152 and I am seeing this. My impression is that the MRP paints are thinned too much to spray them closely onto a surface and the thinner does not evaporate quickly enough. This gives the paint pigments time to conglomerate into the 'rough' surface before the thinner does evaporate. I'm calling it 'weathering'. Try spraying from a greater distance, giving the thinner more time to evaporate before reaching the surface and see if you get different results. Just a theory.
  20. Yes, sorry I did not respond earlier.
  21. Thanks for all the nice comments. The Meng kit is very detailed. Attachment points for the ailerons and rudder are very small, making them susceptible to damage.
  22. Here I present my build of the Fokker DR.I #425/17 in its early days. This Meng kit is well detailed and mine presented additional work due to mis-aligned mold halves, in addition to the usual warped wings and broken fuselage panel. Thanks for looking in!
  23. Hot on the heels of my last completion is this 1/48 Special Hobby Grunau Baby II sailplane. A glider that many early Luftwaffe pilots trained in. Designed in 1933, it was manufactured by many companies and individuals, and examples were still flying in the 1950s. This simple model depicts a fictitious plane. The woodgrain is done with oil paint covered with Future. Thanks for looking and comments are welcome.
  24. Completing another of my favorite subjects - sailplanes, here is the 1/48 Ardpol SZD-8 Jaskolka (Swallow) high performance sailplane. Designed in Poland in the early 1950s, it garnered 15 world records between 1954 and 1960. It had numerous unique features for the time such as a sliding Plexiglass canopy and semi-retracting main wheel. This is the 9th 1/48 sailplane model in my collection with a couple more to come.
  25. Here is my latest completion - A FW190 F-8 in Italian colors. I believe this group was in Italy for only a few months before being transferred to the Eastern front. The model was originally an Accurate Miniatures FW190 A-8, obtained for a good price, but the plastic was the Eduard version with the engine and gun bay detail - an absolutely horrible kit to build with closed panels. Authentic Decals lent a couple of markings. The camo was brush painted. I'm planning to put this in a diorama base with an Opel Blitz truck. Thanks for looking.
