1,177 -
Days Won
13
Everything posted by F`s are my favs
Boeing BOMARC IM-99A Missile in 3D
F`s are my favs replied to patricksparks's topic in Works in Progress
+1. I couldn't see a hitch. I looked so hard that I even thought at one moment that it is something like a click bait to look hard. Man, that's a gorgeous looking Missile in that paint scheme! I just hope it didin't happen after taking these pics, of course.... PS: I just looked again... I couldn't see anything wrong. If it is because of the distance indeed - I believe some additional/subtle weathering will be more than enough to mask any imperfection. -
Yep, you can do all sub-assemblies in chaos, without following any instructions, and then assemble all in the way you like/prefer the most... which is (the best-case scenario is) always the easiest way. Btw about the instr. panels - they are fantastic! I just experienced the Quinta decals for the first time myself and, as a quick tip - those are ''raw'' elements... like everything else ''oob'', they need treatment as well - i.e. I used matte coat applied gently with the brush over certain areas/knowbs/switches, then drybrushing gently with clean brush. The goal is to remove the matte only from the raised ''parts'' like knowbs and switches, and leave the flat areas underneath with a matte finish. It creates a very nice combo of shiny/glossy elements and matte surfaces underneath, quite like the real thing according to me at least. Then, you can add a tiny little bit of black paint to the matte coat and use it as a filter... to make the panels look slightly darker, according to the reference pics, if needed. Some very subtle ''chipping'' imitation along the panel edges is also nice, with aluminum metalizer (for example) on the top of the brush, if the reference pics say so. Anyways, the IPs look very good if you leave them just like that, no doubt about it.
It looks impressive indeed! Simply unique. I followed along and I like this 3D printing approach very much... a whole new set of problem solving tips, criteria, tools, etc.
F-117A Nighthawk, 1/32, In-flight mode
F`s are my favs replied to F`s are my favs's topic in Ready for Inspection
Thanks y'all! Highly appreciated. Btw I took a video and uploaded it to youtube, only to see that it is reversed... anyway, here is a link to Drive - https://drive.google.com/file/d/142x0VDisU_eRzap6QUcfa83_rgbNqpSB/view?usp=sharing I switched the option to be visible, but (based on previous experience) I'm not sure if it is visible. I plan to take a better video anyway. -
Yeah, finally ready. It was a blast this model! There is only one thing that bothers me very much and I would fix if I could - the PE zig-zag pattern of the canopy... It looks like there is a gap or something (it looks like the original), because I fixed it not perfectly flush with the fuselage. My goal was to leave a tiny little gap (fixed it while adding a piece of paper tape temporarily underneath) while trying to leave enough room for the primer/painting afterwards (the thickness of a paper tape). Cause it should make contact with the faceted surface, and I was affraid the whole canopy could lift up a bit if it was the paint touching underneath those zig-zag patterns. Yet, it turned out that the whole painting stage was with the canopy closed, and there is no paint(s) between the PE zig-zag patterns and the facet plastic. Well, it looks like the original plastic piece. I'm quite happy with everything else. Check out more pics - in flight mode & parked mode. It was a very interesting build. Thank you all for the comments, questions, tips, and other bits of advice!
And some closeups, in-flight again: The RAM boundary ''line'' indentations turned out even better than anticipated... imho. Ah, those knowbs and displays... You can even see the green outline of the F-35 on the center display... I thought it will be impossible to notice through the canopy... On to the rear section. Btw all these pics are with dailyght, but no direct sunlight. You can note how the composite parts (flaperons, ailerons) are differently weathered from the rest of the surfaces... (but they look the same when viewed from a distance). Hope you like it. I plan an outdoor session for the parked mode, with the wheels down, canopy open, etc... -
So here is the WIP, the weathering is ready, and it is finally ready: A ''walkaround'' in in-flight mode, first:
Tamiya 1/32nd scale F-15E Strike Eagle
F`s are my favs replied to geedubelyer's topic in Works in Progress
It says "4 weeks later..." gotta be a bug. 10x for the flashbacks, I remember some of the pictures I used as a refference were downloaded directly from the google results, and it took me some time to realize they were indeed from here... -
Oh yes, another Strike Eagle. I just checked those Kopecky resin details... no words, man, they are awesome... good luck with the knobs and switches now, I figured out what you meant with ''fly off into each other''. I couldn't believe all of them are separate pieces at first. This is gonna be madness, at least they are not as much as in a legacy plane cockpit. Btw very nice masking and black shading of the side consoles. It would be nice to scratch something like imitations for the labels of each instrument/knob... I remember I did it that way, and it worked well, so if I remember justice - the main IPs are quite large and spacious - there was just enough space to add some labels. If you choose to do it - do it before adding any switch/know, of course. Another hint - paint the front cowling at the same time, so they both are with the same/color/weathering/treatment. And, Happy modeling!
The bottom fuselage with the fuel/oil leaks - dry and ready: On to the top fuselage - here are some moments from the second stage weathering - matte coat as a filter (transparent overall, but with a little bit of blue) + salt and water to enhance the white lines: (PS: the next one is with white flashlight... the whites really stand out, but they were not as extreme as they look like) Then the third and final stage is the final coat - a mix of around 70% matte and 30% satin lacquer. Then fuel/oil leaks with pure satin lacuqer (as on the bottom), and the final ''stains'' with oil paints, i.e. in the exhausts, traces along the canopy... maybe a couple more things. I wanted to keep a rather ''clean'' overall look though. Then, the addition of the last components - the HUD and the oxigen line to the console in the cockpit, the intake grilles, and I removed the masks... and it is almost nighttime. Yet, I did a short video, it's low-res, but it's almost no daylight left. The oil paints are very very thin and subtle, so they should dry very fast as well. I almost can't believe, but I think it is ready.
Nice! Happy to see this. And yeah, time certainly flies fast. The cabinet and the lights are Amazing, not to mention the combo of models - just lovely! Btw this Jetmads company also intriguied me quite a lot when I found out they would make the F-22... hopefully for real, and soon. As I'm thinking about it now, it's probably more than a year since they announced the F-22 project - do you know about anything new on that topic...
Awesome stuff, awesome shapes! The foil wrapping impressed me quite a bit, and I have some questions - 1) what kind of sandpaper do you use for the sanding? (I suppose these pics are after sanding) - is it water sanding or just norma but with a very fine grit? And 2) - do you have a special ''punching'' set to punch each bolt/rivet individually, or is it some kind of a DIY tool?... I doubt it is a standard circular riveter. And maybe another question - I see some areas where two aluminum panels seem they have slightly overlapped edges - is it on purpose like that (it was like that on the real plane) or is it just a ''safety margin'' to not risk exposing (along the panel junctions) the surface underneath. Tu in advance
...almost forgot - here is a vid of the retraction
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
The MLG is ready for touchdown... almost. So, all this: ...transformed into that: I think Ive beaten my record for for magnets - 38 for this MLG. There are 8 on the fuselage halves that stay hidden. This is due to the piano hinges that are impossible to replicate even in this scale. Of course, the movement doesn't even get close to reality, but my point was only to make it functionable. I don't even plan to add wires and stuff in the wheel wells... maybe only the break fluid lines along the main struts... Next up - painting...
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
Amazing Tomcat! From 1 to 10, I give it a solid 10! The weathering plays a major role for that. Now I see some little things that are not perfect - 1) there is a seamline visible at the tail end, where the top and bottom half of the fuselage are glued - along the fuel damping tubes and sensors. And 2) the flat bottom area of all wheels seems it does not accept the flat surface underneath properly - there are some gaps with light visible along the sides. I deal with this very easily just by pacing the model on a perfectly flat surface like yours, then putting a (let's say 400 grit) long flat piece of sandpaper right underneath a tire, and hold the tire with one hand very strong, while moving the piece of paper just a couple of times... it just sands off the little imperfections right away, and all the light gaps disapear. Moreover, the stress in the pylon struts is much less, as the weight of the model is distributed evenly over the entire ''flat'' spots of the tires, not just on one edge or another. But that's it... I can't find anything else...
- 20 replies
- aires resin
- zacto intake correction
- (and 1 more)
Congrats on the build! She is fantastic!
Thx all! John, I just found a tutorial about this twisting wires method, and did some initial trials... and didn't like the outcome... It just untwists and twists all along, cause the idividual pieces of wire were stored in small reels and there is a lot of ''natural tension'' in each wire... This is after a coat of lacquer. My plan is to try to secure both ends as stretched as possible, then coat them with a 2-componenet epoxy instead of just lacquer... Then I'd like to see how the original handles would look like with just thin decal stripes used as wrapping paper... kinda sounds easier than the twisting method, but right now I'm on some MLG adventures... Realism - 0%, yet the goal is just to make them retractable/funcitonal.
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
Thanks much for the idea! Sure I'm gonna try this decal method, I even think I have the perfect decal stripes. Btw I found a video and gave this method a go - with the twisted painted threads. It's more difficult though... the results are not satisfactory. I might prioritize the decal stripes...
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
Awesome! Btw is this aperture an exception from the clean-looking silhouette... @O.W, a fabulous collection you have there!
The seat - firstly, black, then the main colors, + gloss: Then decals, and the other colors; then, satin + weathering ever so slightly. I know I couldn't do the yellow/black pattern of the ejection handles justly, but these are very very closeup images as well. And I think it is ready. Here a quick testfit... I might not use the PE belts, as I managed to separate the figure from very low and they stayed almost intact. Not sure yet... but the cockpit is just about ready.
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
Yeah... undoubtedly one of the best-weathered Tomcat models!
RAF FG.1 XV571 WILD HARE Phantom Conversion
F`s are my favs replied to Anthony in NZ's topic in Works in Progress
Oh, this is going to be fantastic! Of course those dents in the plastic are something so simple and realistic, and (if you ask me) always required. Why people are affraid of ''abusing'' the plastic while we all use knives, saw blades, cutters, etc. throughout the process? Not to metion what the rivetting/rescribing tools do to the plastic. Some realistic indentations (according to photos) are always a nice touch, at least in this scale. Btw, aren't some panel lines missing near the exhaust/nozzle area - is it right after sanding maybe? -
10x for the tip, Oldbaldguy. I already have some good high-res pics of the MB seat, yet I'll check out the website for sure. Richie, the ''new'' seat is just perfect now... the main colors are on, now it's all about detailing, decals, and final touches. Also, the IPs and the cockpit tub are ready and... what to say... this Thing is gorgeous on so many levels... I can't believe they even included (on the left-hand side) an ''image'' with the white contours of the plane and the loadout selection with something that really appears like green lights... About the radar screen - unitially I thought the white particles are dust that can easily be removed, but it's actually pattern imitation. This 3D decal thing is wicked evil! Still, there are a few other items to include like levers and switches, but I'll do it when it is more safe, later in the build.
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
Just a quick up - it went well. I'm gonna use the MB seat from the kit, with quite some mods/improvements, while the Lockheed seat separated decently well, and stayed in one piece. I'll keep it as a spare part, no idea for what model. So, on to the next page - here is the fit I'm happy with: The seat is heavily modified and not ready yet. It needs wires, pistons... but first - instrument panels and 3D decals.
- 62 replies
- starfighter
- f-104
(and 1 more)
Tagged with:
