Stuka Posted August 10 Share Posted August 10 Hey Guys, Here's a review of a beautiful resin conversion from Halberd Models for use with the Eduard 1/48 P-51D. Have no fear, Halberd also offers a 1/32 scale version that uses the Revell P-51D-15 (late version) as the donor kit. The folks at Halberd do some beautiful work. Links to their website are provided below. Thanks! --J https://modelpaintsol.com/reviews/halberd-models-piper-pa-48-enforcer-conversion-kit Martinnfb 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted August 11 Share Posted August 11 Well, it does need a frameless windshield. I compiled related research information here. Uncarina 1 Link to comment Share on other sites More sharing options...
Stuka Posted August 13 Author Share Posted August 13 Thanks for the comment and the great reference link; much obliged! You are completely correct with regards to the frameless windscreen for most of the pics of the PA-48 I've seen. That said, there is an in-flight pic of a PA-48 with the framed windscreen and the restored PA-48 on display at the Air Force Flight Test Museum at Edwards Air Force Base also has the framed windscreen. Do you know if the airframe on display at Edwards was restored incorrectly? Thanks, again for your comment and best regards, --John Martinnfb 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted August 14 Share Posted August 14 Hi John, Absolutely. Those are two different airplanes . The restoration of PA-48 is flawless but it is not PE-1. PE-1 (N201PE ), which was stripped for parts, so the kit represents very unique airframe that doesn't exist anymore. Halberd offers PE-1, one and only and should not be mistaken with PA-48. PA-48 is completely different airplane and frankly, it has very little to do with P-51D. Model = PE-1 (N201PE) Museum aircraft = PA-48 (N482PE) I broke it down in the above mentioned thread, including production runs at Cavalier and Piper. Hope this helps. Cheers Martin Troy Molitor 1 Link to comment Share on other sites More sharing options...
Stuka Posted August 14 Author Share Posted August 14 Thanks for the clarification! Best, --J Martinnfb and Troy Molitor 2 Link to comment Share on other sites More sharing options...
