Sgt Shultz II Posted August 29, 2020 Share Posted August 29, 2020 I would like to know if anyone has ever duplicated Haze Paint as used on Recon P-38's? According to this article http://www.34thprs.photorecon.org/html/aircraft/haze.html. it was applied over a black base coat and the more coats of "haze"paint applied the lighter the paint got. If anyone has tried this what color paint did you use and how did you do it?? Ron Link to comment Share on other sites More sharing options...
MikeC Posted August 30, 2020 Share Posted August 30, 2020 Funnily enough, I'm about to embark on Tamiya's new 1:48 kit with an F-4A conversion. I found that article in my research, and I'm thinking of starting with a white base coat and adding the various graduations of blue with some airbrush work. Link to comment Share on other sites More sharing options...
Sgt Shultz II Posted September 3, 2020 Author Share Posted September 3, 2020 I was thinking of using the Navy colors, sea blue, intermediate blue and white trying to blend them is somehow. Do you think that might work? Link to comment Share on other sites More sharing options...
MikeC Posted September 3, 2020 Share Posted September 3, 2020 I think it's worth a try. I'd not got around to considering which exact shades of blue, but I think you may have something there. Should be a reasonably straightforward job with an airbrush, but I'm not sure how one might replicate it with hairy brushes. Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted December 28, 2021 Share Posted December 28, 2021 I found some reference's to the top color Sky Base Blue FS35123 The bottom Flight Blue FS35190. The ideal application gradation of color from the light bottom color up the sides to cover the darker Sky Base Blue on the top the Aircraft, Being a Patchy uneven appearance. May use Tamiya Blue X4 with a little black in it for Sky Base Blue Fs35123 and AK Real color RC236 for Flight Blue Fs35190 Link to comment Share on other sites More sharing options...
