AlbertD Posted July 22, 2020 Posted July 22, 2020 I can't get it to stop blowing air out of the nozzle, even with finger off the trigger. I have put new seals in it and tried a new needle and nozzle set. The only time it quits blowing air is if I take it apart with no trigger. Is the plunger under the trigger maybe out of adjustment? I'm at a loss. Of course I've cleaned it and taken it apart and put it back together a bunch of times. I have also double checked that I have the right needle/nozzle sets matched up.
scvrobeson Posted July 22, 2020 Posted July 22, 2020 Yes, sounds like the plunger under the trigger has either failed, or is way out of adjustment. Matt AlbertD 1
AlbertD Posted July 22, 2020 Author Posted July 22, 2020 2 minutes ago, scvrobeson said: Yes, sounds like the plunger under the trigger has either failed, or is way out of adjustment. Matt Thanks Matt, I started thinking along those lines but didn't know if it could be adjusted. I'll give it a try a bit later. scvrobeson 1
AlbertD Posted July 22, 2020 Author Posted July 22, 2020 16 minutes ago, scvrobeson said: Yes, sounds like the plunger under the trigger has either failed, or is way out of adjustment. Matt It's fixed and works like new. I just tightened up that brass screw under the plunger a couple of turns and no more air leak. Thanks for the help. I owe you an adult beverage of your choice. scvrobeson 1
scvrobeson Posted July 23, 2020 Posted July 23, 2020 Glad that it's fixed. I had the same problem with mine before after first fitting the FPC valve, that little brass screw fixed everything. Matt AlbertD 1
