Hy guys, have to start a new project between the "Graf-G6" and "Ernestyne", it´s a order-job for a guy who wants a special bird, a FW 190 A-5 ( Revell), but this time not as a "cutaway" but in "complete-service", means all service-flaps have to be opened! Will be hard ´cause the bird has to be finished just in time for christmas........ok, sounds like a challenge. Here are a few pics from the first steps, first one is cowling cut into pieces and fuselage opened
another shot of the BMW, little motor inside is partially visible at the back...of, forgot, motor and lights will work!( I hope)
here´s a shot of the fuselage halfs before glueing them together, because of having not much time for this bird I decided to fill the fuselage only with the interior that will be visible through the service flap on portside, that´s why not all ribs are mounted.
bulges on upper wing for wing root cannons removed to mount them later in opened position, inner structure for gun- bays made from ply-wood.
same flaps, inner structure made from small strips of tape and brass wire, painted, with a little bit of chipping
standing on her feet, painted and ready for a coat of high gloss before the decals, finally I decided to give her the markings of austrian ace Nowotny " Double chevron" from I./JG 54 in Russia
Ok, changed the final markings again..........because I did not have some "Double chevrons" for the plane of Nowotny I decided to give her the markings of another austrian ace from JG 54. Now she´s "Yellow 8" from Robert "Bazi" Weiss. 3./ JG 54. Decals finished, ready for a semi-gloss coat and awaiting the final detailing at motor and guns.
Chris, thanks for the amazing photo-jouney thru the building of your kit. I really like the opening up of the panels to reveal the interior,IE the radio compartment and the rudder thingee. If you need some << in 1/32 I will be happy to send you a set I've got many more than I'll use. Any pics of the 'pit on the FW? also, how do you open the panels: scribe and use the kit parts? thanks again for the pictures- mike in calif
Hy Mike, thanx for your compliments! A few of this double chevrons would be great, especially the size for a FW 190 ( a little bit bigger than the ones for a Me109, black with white outlines) ´cause I´ll will do the plane of Nowotny anyway for my own collection. Please e-mail me at CNASMaol.com for that. The cockpit is not really worth a detail shot....shame on me.....but because there´s not much time left I used the kit´s cockpit without any extraordinaire details. `bout the panels: they are milled out and then handmade from aluminium sheet because if you would cut them out carefully to use them later you already would have to sand them down to reach the right thickness, think this would take the same time as make a new set from alu. Did the same with the upper and lower cowling flaps, used the kit ones as a mold, cutted out some from alu and bent them carefully over a Revell colour-can to get the right form. Looks much better than the kit ones.
Think she´l be finished next weekend,
cheers
Chris
3 1/2 hours for that motor detailing with lot´s of electronical parts ( mostly from scrapped computers), cables, wires in different sizes........and coffee! here the motor and gunbay area rough ( unpainted)......
Looking GREAT Chris!
How did you do the strapping on the hoses in the engine bay? Is that sheet styrene? Very nicely done.
