Chek Posted February 7, 2020 Share Posted February 7, 2020 A solution I've used for years now is as follows and gives the correct type of inverted reflection you see in the reflectors of real lights. Stretch some clear sprue to a thickness suitable to your needs. Hold a clean, cut edge near a candle flame. As you move the sprue end closer to the flame, it'll form a ball and retreat. As you bring the ball in closer it will enlarge. Or burst into a puff of flame - trial and error will see you through. Let it solidify then paint the spherical area silver and let dry. You can then either drill or hot pin a hole for the bulb in the rear of the reflector to apply a drop of clear colour, or leave as is for white lights. At this stage, I find it easier to glue the ball to a pre-painted and prepared mounting bracket or plate. Snip off the sprue stub 'handle' then sand it to a convex round light lens and polish to clarity. You'll never be stuck for light lenses again, as long as you have clear sprue and a candle! LSP_Kevin and themongoose 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 7, 2020 Share Posted February 7, 2020 Nice tip, Chek! Wouldn't it be easier to drill the part first, before painting it, though? Kev Chek 1 Link to comment Share on other sites More sharing options...
Chek Posted February 7, 2020 Author Share Posted February 7, 2020 I forgot one time and was worried about paint flaking and suchlike, but really the drill or pin is so small as to not cause any damage. I find it's also easier to see after painting than the clear part alone. But whatever works for you. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
