Rob Colvin Posted April 20, 2011 Author Share Posted April 20, 2011 Well........ The harrier started out as mine but after completion (A day later) it went to a good home! Link to comment Share on other sites More sharing options...
Bruce Posted May 18, 2011 Share Posted May 18, 2011 I had a similar problem with uneven primer paint on a model I was doing, it just kept dispersing in certain areas. Until I remembered that some sprues aren't always totally clean and carry some of the release agent off the mould. So, got some liquid detergent and wiped down the offending areas, and hey presto no more problems! Don't know if your model suffered in the same way, but worth a try if you haven't done it yet? Funny how you can forget this stuff after a while. Roy. some of the car builders in our club suggest using automotive liquid detergent because most household detergents contain some oils to keep your hands soft, etc. whereas the automotive ld's don't great work Rob Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 18, 2011 Share Posted May 18, 2011 (edited) Rob Awesome work on the Harrier. Simply a beauiful build. Peter Edited May 18, 2011 by Peterpools Link to comment Share on other sites More sharing options...
K.C.Hawk Posted June 4, 2011 Share Posted June 4, 2011 Hello Rob. Impressive, inspiring - real job ! Fantastic Harrier! I want to make Harrier in 1/32 scale but necessary RAF secvice. A few months ago I made the Harrier 1/48 scale. Not wanting to clutter up Your topic I will only show one image. Good luck with the next model. Kris. Link to comment Share on other sites More sharing options...
Rob Colvin Posted June 7, 2011 Author Share Posted June 7, 2011 (edited) Very nice harrier indeed. Trumpeter does a 1/32 GR7. You should give it a go. Rob Edited June 7, 2011 by Rob Colvin Link to comment Share on other sites More sharing options...
