fastzx
LSP_Members
  • Posts
    1,105
  • Joined
  • Last visited
  • Days Won
    1
Posts posted by fastzx
  1. I've always liked the echelon formation. Stair stepped tucked in nice and tight parallel with smoke on. That way you could hide your acrylic rod supports and still have a sky background and not be overly large to display especially if you angled the support rods to let the sky base be a backdrop.
    That would still let you mount on a wall.
    I have seen the echelon formation performed with 5 jets.
    For fun
    http://www.zerosixright.com/fly-with-the-us-air-force-thunderbirds/
    Jon
  2. Ok sorry for that.
    I know you have a lot invested in your bearing and pulley but
    Just a thought here....and that is all.
    The gearing looks reversed as it exists now
    I propose that instead the driving gear or pulley attached to to motor should be the larger diameter and the pulley or gear on the rotating wings should be smaller in gearing or diameter.
    That way the motor (with larger diameter gear) can rotate at a lower RPM yet "overdrive" the smaller gear on the center wing section.
    That change would seem to me to generate more effect for less power drain.
    Just a thought.
    Jon
  3. Thomas,
    Looks great, two of my favorites.
    Glad you fought through and whipped these.
    Will look great in your collection two examples if
    of two fine pilot's steeds.
    The "Kid's" mustang is very nice and the whitewall tires are so 1940's!
    The red rims on Gentile's plane don't look bad.
    I still have to finish my stalled Shangrila Stang.
    Bravo.
    Jon
  4. Crew: 2 (tandem)
    Length: 35 ft 8 in (10.87 m)
    Wingspan: 59 ft 1 in (18 m)
    Height: 11 ft 6 in (3.5 m)
    Wing area: 401 sq ft (37.3 m2)
    Empty weight: 6,400 lb (2,903 kg)
    Gross weight: 16,000 lb (7,257 kg)
    Max takeoff weight: 16,000 lb (7,257 kg)
    Powerplant: 1 × Pratt & Whitney Canada PT6A-67F turboprop, 1,600 shp (1,200 kW)
    Propellers: 5-bladed Hartzell Propeller HC-B3TN
    Performance
    Maximum speed: 230 mph; 370 km/h (200 kn)
    Cruising speed: 184 mph; 296 km/h (160 kn)
    Range: 1,841 mi; 2,963 km (1,600 nmi)
    Endurance: 10 hours
    Service ceiling: 25,000 ft (7,620 m)
    Armament
    8 hardpoints for up to 9,000 pounds (4,100 kg) payload, including but not limited to:
    2,500 pounds (1,100 kg) or 1,000 pounds (450 kg) smart bombs
    8 × AGM-114 Hellfire laser guided missiles
    38 × 2.75 inches (70 mm) Hydra 70 folding fin aerial rockets
    2 × GAU-19 .50-calibre (12.7×99 mm) gunpods
  5. Jerry,
    The first thought I had when they described the dimensions (75 feet) was that it was a wing.
    If it flew that far it would most likely be out of fuel and the fuel tanks keeping the debris floating due to air trapped in the wing tanks. Unfortunately the discovery of 120 additional debris is not good. If they were aware of the situation those are most likely floatation devices or worse due to the number.
    Jon
