fockewings Posted June 8, 2015 Share Posted June 8, 2015 Hei all, some small comparision since I am not able to post pics on the thread it was intented for. The first to the left is the incorrectly shaped Hasegawa blade of the "new-mold" Second to it is the nicely done PCM blade only needing some minor tweaking at the top Third is HDs superb blade measured and copied from an original part freshly discovered at the Luftwaffenmuseum Berlin-Gatow Last ist the under-strength Revell-blade. Same problem as with the Heinkel 219 Revell Kit. Too slim/narrow Thunda, D.B. Andrus and RBrown 3 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 next pic is a line-up of all the spinner-cones I have available to the left the undersized Hase spinner in the middle the freshly received Revell F-8 spinner with wrong positioned panel lines and too blunt at the top the last is HDs newly made Spinner for the F-8 the openings for the blade roots are wider on the F-9 but the rest is virtually the same. Dont let yourself be tricked - the small edge underneath needs to be trimmed down a lot to have the bottom part fitted (seen in the front) Thunda, D.B. Andrus and RBrown 3 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 To be seen here are the Fans of: 1. Hasegawa with to long appearing blades due to the small center diameter 2.HDs prototype but not finished Fan - the blades need to be wider as on the following 14-blade for the F-9 3.HDs F-9 fan 4. the nicely done Revell fan RBrown, Thunda and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 (edited) this is an old Hase Prop which I had balcanced for my A-4 conversion I started almost ten yers ago. This project stalled due to the whereabouts of information regarding the winter camo of JG54. Anyway I am lucky not to have proceeded since the Prop will be modified to HDs Blades and Spinner set. Again this is the original part put together only minor rivets added. Edited June 8, 2015 by fockewings Thunda and RBrown 2 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 this one happend by pure mistake. I had removed the slim edge for centering the bottom part of HDs set and couldnt use it for any serious balancing. I speak of balancing since my model has a circuit with motor LEDs and Sound syncronised from the start until the end with position lights and exhaust- gas-flickering... Anyway I thought of trying this out and voila - the Spinner from HDs F-9 set fit over the Hase without turnig it down. Note the bigger openings for the F-9 blades/wooden blades Also the cane sits to high caused by the Resin collected in the top Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 to check the result I took another badly balanced centerpart and cut off the peak putting the Cone over it shows the change in appearance SO the Fan blades do not appear so long anymore.. Still missing is the cones bottom-part Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 the next pics are showing some Hase Landing gear covers - heavily modified to fit into the wings underside openings. Hasegawa made a shortcut there but Revell appears more correct and they didnt forget about details either.. They are long enough and fit properly giving the right appearance. RBrown, Thunda, D.B. Andrus and 1 other 4 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 Also, before someone is calling my info "unverifiable information" I better do my own topic with own pics and reliable pics to explain and guide. I am doing the FW190 since over ten years now and I am still finding new things and also the information and the research thanks to friends and collegues are much more sound than for example 15-20 years before. Consider only the camo and the markings. Anyway this pic shows the leg fully extended and out. The model is my heavily modified Hase-Bird in 1/32 to resemble an early A-4. RBrown and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 this one hopefully works RBrown, Thunda and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 those pics showing the details a bit better... RBrown, Thunda and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 the wheels are taken off again since I had to grind them down a lot and I have now much better ones. Again glad not having forced to use those.. Bill M. and Thunda 2 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 well back to topic here is a nice pic showing the difference i length between HAse and my modification which is identical to the Revell. Just that about 5 years are between them RBrown, Thunda, Ralph-D and 1 other 4 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 I basically used two parts and ground them down to make them so thin... Thunda 1 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 Well back to the Spinner and the nose: I removed the cowling ring and the oil armour ring to have them next to each other 1. to the left Hasegawa 2.true copy without changes through PCM 3.HDs newly made armour ring for the F-8 Watch out the outside has a tiny bit more material since the curb was slightly different from the A-8/F-8 4. Revell which is nice nut to high it seems I need to compare mesurements later on in this tread RBrown 1 Link to comment Share on other sites More sharing options...
fockewings Posted June 8, 2015 Author Share Posted June 8, 2015 (edited) Revells Oil cooler and armour-ring. The profile-curbs are almost not there on the nose ring. Here is Hasegawa better but since the Hase Armour ring is split in to two parts, it makes it very difficult to get a round shape together with the oil cooler ring. Edited June 8, 2015 by fockewings Link to comment Share on other sites More sharing options...
