Guest Peterpools Posted October 24, 2010 Share Posted October 24, 2010 Finally made some progress worth posting. The cockpit tub and nose gear wheel well have been glued into position, the ducting for the air intakes glued into placed and the fuselage halves buttoned up with tube glue. After being away from the hobby for so long, old habits die hard (using tube glue). Following Big Matt's thread, The Beer City Special, I took special precaution about how the front gear needs to be installed before gluing the front wheel well together but I used a different approach. I decided to drill holes on both sides of the front wheel well where the front gear pivot axle goes, so I can insert the gear leg later on.This way I can insert the gear, push it through one side just enough, so that I can then pull it back into the other pivot joint. seems to work well for me. If the instructions are followed, you're going to have a major headache with the gear. The wing is also glued up and ready to be installed but I thought I would first concentrate on the fuselage seams with putty and primer and get them finished and out of the way. This way, the only remaining seam and body work to be done would be the wing roots. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 24, 2010 Share Posted October 24, 2010 Getting ready for the fun part: putty, sanding, repeat and priming. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 24, 2010 Share Posted October 24, 2010 The air ducting has been glued into place and the seam between the rear of the front wheel well and the wing opening still needs to be glued up this morning. I'm first planning on reinforcing the spin fuselage seam from the inside with Evergreen sheet plastic as an extra added precaution. Peter Link to comment Share on other sites More sharing options...
shark64 Posted October 25, 2010 Share Posted October 25, 2010 I went back to your first post. I like the way you write, very clear. Welcome back to modeling. Sounds like we all came back from our younger year to tackle plastic and glue.. Nice work on that cockpit indeed. i always liked that plane,.something about it. Its on my list as well........someday. I will be following your progress. Oliver Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 25, 2010 Share Posted October 25, 2010 Oliver Thank you for the kind words. I'm realizing that as I proceed from step to step, there is as learning ,as remembering as I go. Peter Link to comment Share on other sites More sharing options...
big matt Posted October 25, 2010 Share Posted October 25, 2010 Looks good Peter. I see you had better luck with the guns than I did. I used brass tube because I could not get the resin parts to work for me. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 25, 2010 Share Posted October 25, 2010 Matt Thanks Matt. The guns were a pain and the resin parts were unusable. I wound up using plastic rod. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 14, 2010 Share Posted November 14, 2010 Slow but somewhat steady () progress. As of now, wings and horizontal stabilizers are on, with all the filler and sanding work completed (hopefully). I'm planning on using the Lockheed tip tanks which are now also completed and ready to be added., as well as the gun sight and front windscreen. with some luck, I'll be ready for primer by next weekend. I've got my fingers crossed. Peter I cheated a bit with the photos and used the camera flash, with one small fill light, which seemed to highlight the filler a bit too much. Link to comment Share on other sites More sharing options...
