Luca
LSP_Members
  • Posts
    1,304
  • Joined
  • Last visited
Everything posted by Luca
  1. https://www.forecastinternational.com/archive/disp_old_pdf.cfm?ARC_ID=452 http://www.deagel.com/Sensor-Systems/ANASQ-228-ATFLIR_a001647001.aspx same external dimensions (length: 183 cm, diameter: 33 cm, weight: 190 kg), but the front/rear parts seems slightly different though I'm not 100% sure
  2. superb building and great paint job sir! only a question for you: did you find any problems when assembling the kit? I have an A-6A in the herd and I wanted to know if there were any particular critical points in the Trumpeter kit thanks
  3. nice subjects, especially the JR two-seater!
  4. I thought there were only those two boxes out there (Golden Dragons and Chippy Ho)... hoping Starfighter will help us to clarify our doubts.
  5. ok thanks Tony, so which legacy hornet box do I have to search for to get the ATFLIR pod? p.s. is the adapter the same between legacy and super hornet?
  6. hi guys, Trumpeter instruction sheet calls it "AAQ-25" that is wrong.....anyone who built the Rhino can tell me if that pod is correctly shaped/sized? (unfortunately Trumpeter is not phenomenal in warloads) I know Wolfpack makes it but only in 1/48 scale. Thanks for any help.
  7. thanks guys. What are these AAM-5? https://make.dmm.com/item/687992/ plastic? resin? what?
  8. inert or operative missiles, on the belly or under the wings. Otherwise, what missiles (medium-range) can they put? TIA.
  9. aaargghhhh I have a lot of SAC u/c legs in my stash...I did not know about this alloy issue
  10. hi Vandy, is this the set you were speaking of (verlinden 1:35 ammo belts .30 cal & .50 cal #60)? unfortunately I've found only this pic and not the reference number I've also found this one: https://www.bnamodelworld.com/military-vehicles-tanks-ammo-weapon-aber-ab-35a047?zenid=3e680b145a87c1d4df3b5ca00d1d9b1e
  11. ditto! the two-seater is also more vigorous this livery looks great, too (hope some brand will be doing the decals):
  12. IRIAF and Sundowners tailed are the best just OOB options IMHO... even a three-tone blue would have been nice though
  13. will the KH kit be including this HUGE fuel tank? and further heavy weapons?
  14. thanks Ziggy, as always you rock. great pics
  15. Hi guys, in this photo the nose/radome seems tan (or am I wrong?): http://www.flickriver.com/photos/skyhawkpc/8700558180/ but the AOA decal sheet 32-009 tells off-white, maybe he had got both radomes? also I'd like to know if he had got the dorsal long walkway (dark grey or black).... the decal sheet tells no. Some pics who shows? I'm planning to purchase this sheet. TIA.
  16. Hi Marcel, thanks for the feedback. are you gonna use the BB/Avionix cockpit on your Echo? (it's intendend for the Alpha) what changes should be made in the case? it is untraceable... cheers
  17. thanks Tony, now I've understand. Think I will be buying at least one box just to have the Iranian bird OOB, it's really cool.
  18. sorry for the questione but... what is wrong with the old Hasegawa kit? (positive paneling apart) I still have it in my stash
  19. the systems tells me "Cann't connect to DB"...maybe it's still offline? thanks anyway. I need the 2 halves of the forward fuselage...
