Lisec
LSP_Members-
21 -
Everything posted by Lisec
Because of the PB issues, I can only link one of the finished models, no luck with in-progress... http://mkgrunf.com/f6f-5-hellcat/
I am aware it still isnt finished, but blackbasing (and with it marbling) would yield different results than what you have. The thing is to go with a lightened dark blue with spots of subtly different colors (I go with yellow) and then blend it with a regular dark blue to get that marbled,faded look. You do what you do, I really have no issues with it, but it's not blackbasing Try it on a paint mule,one in black and one in grey and you will see what Im saying
Well...to be precise,you did whitebasing on the dark blue should have kept the medium blue more tightly confined so you could utilise the black surface. IMO splotchy dark blue on the med blue looks a bit off
Hasegawa 1/32 FW-190D-9 "Schwarz 14 + I" 10./JG2, April 1945
Lisec replied to Warbird's topic in Ready for Inspection
How come you went for a 76/82 combination of wing colors? -
A beauty!
Sadly (or not for the allies ), it didn`t fly much...
Forgot to add...the Jeep was modified with the add-on armor of the cab and interior
Ola Finished this little dio a few weeks ago. The Komet was finished 10 years ago,but i was never happy with the paint job,as at the time I had a basic airbrush. So...a few years later( 10 to be precise ), I decided to redo it. Basically took it apart,cleaned it up a bit,made the Jeep, from Academy and did the groundwork. The Komet is also from Academy, 1/72, and I did some scratchbuilding inside the cockpit supported by Eduard PE and CMK resin control surfaces and a part of the engine. The figure is ReedOak Anyways,here it is
S.e.5a - No 74 'Tiger' Squadron, Clairmarais 1918, Diorama
Lisec replied to kkarlsen's topic in Ready for Inspection
Holy shiiiiiiitake mushrums -
Forgot these...
Forgot to add these
Matija Lisec (yes yes you are probably pronouncing it wrong hehe)
Sure,I have no problem with that And thank you all for the comments
Ty! GunzeSangyo,still the best paint IMO
Revell 1/32 As the one before, Revell 1/32 Aires cockpit, GWH seat belts,Brassin exhaust, new small wheel bulges on wings. Barracudacals marking Yellow 24 6/JG27, sprayed RVT band The base is not complete Some hi-rez pics here,if anyone is interested(the same set,just larger pics) http://mkgrunf.com/me109g-10-erla-early/
Revell 1/32. Not sure if I should rant about the kit, I believe most know it`s issues... Went with Barracudacals, Green 7 JG300. Sprayed RVT band. Modified the interior,added Aires seat belts,Brassin wheels,drilled out exhaust. Made in tandem with an early version which I`ll post next. The two cockpits(one is a modified Revell,the other Aires)
