Hi John1
You are creating some nice work here. If the model you are building is intended to represent an FB.VI then the two cockpit pictures you have posted above are not a good/accurate reference for you but are a good illustration of some differences between Canadian and British built machines. Great if you are building an FB.26. The main switch panel in he middle picture looks like your typical FB.VI switch box. The pictures are taken in the cockpit of KA114. KA114 is a Canadian manufactured FB.26 and was restored faithfully and very accurately as such. The equipment lay out, radio fit, colours etc are all very accurate. The FB.26 is the Canadian built equivalent of the British built FB.VI and are near identical in basic system operation and lay out. The two junction boxes you refer to serve the same purpose but are noticeably quite different in shape to look at between the Canadian and British built Mosquitoes. The Canadians used a lot of American style instrumentation, electrical switches, wiring loom plugs, control cable pulleys etc to name but a few items. The Canadians tended to use Black PVC for their wiring loom conduits where as the Brits liked to use a lot of Yellow PVC for their wiring loom conduits, but not uncommon to find Yellow conduit over painted Black. If you are interested the main switch panel on the right hand cockpit wall was simply referred to as Box "B" and the other behind the Navigators right shoulder which is the electrical system main fuse box was simply referred to as Box "C" Looking forward to more of your updates.
Andy
