BloorwestSiR Posted January 5, 2013 Author Posted January 5, 2013 I then added some sheet styrene to either side of the rear fuselage to act as a more positive shoulder for the upper fuselage piece to rest on: There are some gaps on either side that I filled in with styrene strip and that helped reduce the amount of sanding as I didn't want to lose all the corrugated surface detail: Here's the fuselage mounted on the Tamiya Spitfire stand:
BloorwestSiR Posted January 5, 2013 Author Posted January 5, 2013 That's where I left off. We had to do some renos to the house and as a result, I had to pack up the work bench and my stash: That was 2 months ago but everything is done now. The good news is I have a hobby room now with separate ventilation and no worries about other stuff encroaching on it. I should be back up and running this month and will try to get some work on the X-15 done. Carl
