11,238 -
Days Won
33
Everything posted by thierry laurent
Jetmads 1/32 JNSDF U-36 Learjet
thierry laurent replied to thierry laurent's topic in Works in Progress
We had the dangerous part. Now we have the frustrating one: the rear bulkhead. As that area is not very visible, Jetmads only gives the double rear seat part with… no bulkhead behind it! It is unfortunately difficult to find pictures of that area in Learjet 36 military jets not fitted with the seats of VIP transport planes. Most available pictures show similar civilian versions with the front of a luggage compartment. Moreover, because of the wing spar identical location there are obvious differences between the short cabin of the versions based on the model 36 and the long ones based on the Learjet 35. This explains the step you can see. On top of that step, the U-36 simply has the wall separating the cabin from the fuel tank. I based my modification on the C-21 pictures I found and some TM views of the area. I give no guarantee this is fully accurate but hopefully the area is close to invisible in the fuselage and furthermore it will be painted black. Moreover, this is far better than what is given in any kit! The work is frustrating as you need to dry fit in the fuselage dozens of times. I’m quite happy this part is behind me! One of the challenges is the need to reinforce the new floor part without adding thickness that will prevent the insertion in the fuselage. If you look at the lower side, you will see I just used tiny amounts of very thin CA glue and had yet to sand here and there to be able to locate correctly the part. Assembly tolerance is so tight that there is no positioning margin. -
If you take the same path than me, you should first remove the sliding table boxes from the sides and the floor. This is the most dangerous step. Keep in mind you are handling a very brittle part and removing such sections out of that part will remove most of the structural strength of the sides. I used the ultrasonic cutter and a light power tool with a grinding head to minimize handling but even with that approach and a cautious work I succeeded in breaking the rear sections at least twice! You have been warned! The thin slot in the sides of part A03 also need to be filled as well as the four cup holder holes on the top of the sides (plastic rod sections and CA are ideal for that). If you look closer at the picture hereunder you will also see I removed the upper tab on the rear port and front starboard seat structures (red arrows). I cheated as I should have removed the full structure and filled the small slots in the floor part. I did not do that as they will be hidden when all the components will be added. I was not masochist enough to add invisible work! We will go back to the cabin seats later. -
Now is starting the big challenge: the cabin. There are two approaches. You can scratch build a fully new interior based on the Jetmads floor part, or you can modify the US version one (part A03). I decided to take the second approach even if it is riskier (no spare part if I decided to change my mind and build the US one). I considered it has some major benefits. The most obvious one being the dimension issues lower risk. The single part tubular approach used for the central fuselage section has a major drawback: you can only insert the cabin as a full module through the front. To me this meant that scratchbuilding the full cabin would be a terribly time-consuming sub-project! Indeed, it is everything but easy to create something without being able to dry fit regularly and identify precisely what prevents the correct positioning of a modified or scratch built part. Copying all the external dimensions of the US cabin is a possibility but the assembly tolerance is so small that this looked far too time-consuming to me. The side effect is the need to modify a very fragile part. However, the dimensional challenges will at least be limited to the new rear bulkhead area. This picture shows what needs to be removed and added: I just found a single picture of the U-36 cabin, but it showed some interesting features even if only the starboard side is visible. So, unless finding more pictures, this implies artistic license to recreate some areas of the interior. Hopefully, they will not be very visible through the rear windows. -
As aforementioned the U-36 has none of the bulkheads separating the cabin, toilet, and cockpit areas. All components of the kit located behind the cockpit seats should be put aside. This covers all the parts used in assembly steps 27 to 30 (page 9). Obviously, as the bulkheads will not be used, the four slots to position them correctly in the fuselage need to be filled in. I simply used some plastic strips and CA glue as the following picture shows it. Sanding a little bit the interior of the fuselage interior at that step is recommended as even if a small part will finally be visible this decreases the risk to distinguish faint ridges on the surface after the painting process. -
An important remark to start the U-36 assembly: For whatever weird reason, Jetmads decided to print the starboard pod glass tip (part O45) rather than adding a clear resin part. This is probably the worst design decision they made in that kit as there is no spare part and cleaning it is an absolute nightmare… Finally, this took me more than four hours of work for a single part as you must: - Remove the supports without damaging the surface. - Sand the external (convex) but also the internal (concave) sides to remove the printing ridges. - Polish both sides as much as possible to restore the clear part transparency. The macro picture clearly amplifies the remaining scratches. I still have to use some Klear but, as it is, it is usable. The resin has also a yellowish tint that cannot be removed. Hopefully, it looks this will not be very noticeable when added on the pod tip. So, if you consider building the U-36 version, start with that specific part! At least this will give you the opportunity to switch to the US version in case of problem. -
Cleaning the main 3d-printed parts will ask for some hours of work. The most complicated area is the main landing gear wells. Obviously with 3D print you can add a lot of small features on big parts but reaching some intricate areas to clean them is not always easy. The use of different fiberglass sanding pens and jewellers’ files is recommended when you have removed the printing supports. Jetmads optimised the design of the resin part gates to get good casting results. However, this comes with a side effect. There are quite large casting gates and removing them is not the most user-friendly activity. I guess they had to balance quality of casting with part cleaning user-friendliness. I am not criticizing the approach, but this results in a longer process to avoid damaging them. This is particularly applicable to the wing parts. I left most of the small parts on the gates as they are very fragile. So, it is better to remove them progressively. One thing I will replace is the static electricity dischargers. I am afraid simply looking at them can break them! -
To go back to the U-36, you get a quite good external replica. But, regarding the interior, the situation is less glamorous. Jetmads asks you to use the standard cockpit with its rear bulkheads and only gives a bare central floor for the cabin (part A07)! Ouch! This is a pity as this is far from depicting the actual airframe features! To say it short : - The U-36 has NO bulkhead between the cockpit seats and the rear wall of the cabin. The cockpit seats rear is consequently visible if you open the large fuselage doors, but the kit ones are not accurate and have simply zero rear detail! - The cabin rear wall is not located at the same plane length station. The U-36 is based on the shorter cabin Learjet 36 whereas the kit has the interior of the C-21 (military version of the Learjet 35). Jetmads simply gives two parts to fill the rear windows but does not consider the bulkhead location difference. - The jet cabin is not an empty cargo one. It has some seats and three large racks full of electronic boxes. They are located close to the door. So, there is no way to open the door without reproducing them! Moreover, they are also visible through the cockpit windows because of the lack of bulkheads. Here's what you get: Conclusion: that dimension is very disappointing in a kit of such a quality.… I think the only “simple” approach asks for closing all the cabin window shutters, close the fuselage door and paint black the fuselage interior behind the cockpit seats to hide that big void. This would still result in an impressive model but would be to my eyes a major missed opportunity. -
Globally, if you want to ease your life, build the C-21 version! The kit has all the components to create a particularly good scale replica and you get multiple choices of USAF schemes. In comparison, the Japanese version clearly looks like an afterthought. It is true the version is not very well documented, but the model contents are quite disappointing if you intend to make a U-36. The Finnish air force initial ECM version is asking for most of the same external components than the U-36. The most obvious visible differences are the Learjet 35 longer cabin and the use of the standard wing tip tanks. So, this could have been included quite easily as another optional scheme. Strangely, this was not considered by Jetmads whereas the typical military woodland green/black scheme of Finnish Learjets is very different from the flashy U-36 colours. The main missing item for that one is a rear bulkhead with black boxes as the Learjet 35 cockpit/cabin stayed quite standard (that mark kept the bulkheads and all the cabin seats except the double one at the rear). Anyways, you also need to rebuild the bulkhead with some black boxes for the U-36. As a conclusion, unless you did exactly what I did (specifically buying the kit for the U-36 version), the USAF C-21 is a far easier option. And if you want an ECM version, reproducing the Finnish one is far easier even if the decals issue still needs to be solved. Nonetheless, take care as such airframes evolved noticeably with the addition of additional windows for photography as well as various external radar/scanner lumps and bumps. -
Some basic recommendations: The assembly of such 3D-printed models is easy (with some noticeable exceptions), but the clean-up phase is always time consuming even if some kits are far better than others. So, if you like assembling quickly a model to focus on the painting phase, I would not recommend current Jetmads models. I used thin sanding sponges as well as 3M sandpaper that is very souple « sandplastic » sheets to remove the ridges from most of the fuselage parts. The only tricky area is the rear section of the central part, where the reactor pods should be added. It was far easier to use a fiberglass sanding pen there. Take care when sanding as the panel lines are sometimes very shallow (e.g. the nose panel ones) and it is difficult (understatement) to scribe lines in the surface of the material. So, be careful as restoring panels lines will be a risky business. A final coat of primer followed by a micromesh rubbing treatment should give a fully smooth surface. SLA-printed resin has another major drawback: it is harder and far more brittle than plastic or resin parts. Using an ultrasonic cutter is the best solution but such tools are alas expensive. I guess a hot cutter may help as the ultrasonic one sometimes melts a little bit the resin, but I never had the opportunity to test one on printed SLA resin. At least, Jetmads instruction sheets are excellent. They precisely define what is required for each version. Here is one example: When I mentioned that assembly is normally easy, this does not apply to some cabin/cockpit parts of that specific kit. We will have a look at that later. -
Hi guys, Again, I hesitated before starting a WIP thread as I already have various irons on the fire for years! However, I am still waiting for some progress of my house extension next phase to get my painting area. So, various projects are still stuck and even if I did not intend working on another kit, I really wanted to have a closer look at one SLA-printed model. Moreover, I realized that it looks few people worked on the Jetmads Learjet and except a single Youtube WIP of that kit, there is nothing on the web. That void is really becoming a black hole regarding any example of the Japanese Learjet version! Add finally to that the fact that, to me the journey is often more important than the destination, and I decided to jump… I’m occasionally back in trains to commute. So, I also have a little bit of time to type my notes! I already published relevant references and information about the Japanese U-36 in the LSP discussion forum thread related to the kit release. Simply refer to the following LSP page: https://forum.largescaleplanes.com/index.php?/topic/87559-132-c-21a-learjet-35/page/11/ The Gates Learjet is alas VERY badly covered from a documentation perspective. I simply found no relevant printed or online reference about the military versions, and this is even worse for the exotic U-36. Multiple kits were released in 1/48 and 1/72 scale. However, they just cover the external features of the plane. Accordingly, I only worked from U-36 pictures I found on various Japanese websites, some C-21 pictures and online technical manuals of the Learjet.
The Aircraft we would HAVE to Scratch Build Right Now
thierry laurent replied to Archimedes's topic in LSP Discussion
Difficult to say: Voodoo, Neptune & A-37 are in the top of the most desired planes of my list. Then, there is the Sea King and Sea Knight, then the F-82, then the... I'm afraid you have opened the Pandora's box... -
Macchi Fighters book.....Oh, my!
thierry laurent replied to paul fisher's topic in General Discussion
Well I got one less than a month ago! I paid it the double of the initial price but again I cannot complain as it looks quite difficult to find any of the OOP ones for less than 100€! I used Find-more-books and Eurobuch. I found 11 of the Classic OOP books in less than a month while staying far from the crazy prices. So it IS possible to find them but you need to look for them everywhere daily on sales platforms such as ebay, Amazon, Abebooks and others like Rakuten plus check all the major resellers. -
Indeed! Fortunately I found one copy two days ago for a quite reasonable amount (around 80€) and yesterday ordered the Do17 one for close to the same price. I got it from France but it looks the book is actually in India! Still hunting for the Do215 and V2 ones... -
Well, at that time few model glues were available to us. We essentially worked with the quite messy Britfix 77 or similar tube cement glues! Later some more liquid glues appeared from Uhu, Revell and others. Unfortunately, I cannot remember what he used. Moreover as someone else built the kit, it was not possible to say for sure. This just looked like "standard" plastic glue.
Hi Paul. The same author released the S79 Sparviero in the same series some years ago. The other book has the same quality. BR. Thierry -
The book arrived this morning. So the delivery date was seemingly a provisional one! -
Well, I observed that at least thirty five years ago. I had a cousin who loved building 1/24 trucks. He got a second hand assembled and roughly brush-painted AMT wrecker model from a friend. The kit was OOP for many years. So, in spite of the model state he was happy to get it. To restore it he put it in a mix of caustic soda pellets and water to remove paint. Two or three days later, there was a pile of separated white plastic parts in the plastic container he used! The parts were not damaged and were free of decals, paint and even glue close to everywhere. He cleaned the remains with an old toothbrush and got close to a new kit! There were obvious traces where glue had etched the plastic surface but I was really amazed! Unfortunately I did not do it myself and as it was a long time ago I have no clue about the brand, concentration or any other practical parameter. Nonetheless, that looked quite magical to me!
Caustic soda can also dissolve glue!
I forgot to add that I'm removing all the instructions sheets and decals from the plane kit boxes. The goal is two-fold. First, having all the plans in specific folders per air force in my library is helping me to know what I have (aftermarket sheets are put in the instructions of the related kits). Second, the decals are put in different folders with aftermarket ones per air force and topic and stored in a big cardboard box in the same room. So, they are in a room where variations of temperature and humidity stay reasonable and I can take decals for a project far more easily. Unfortunately the room is currently full of cardboard storage boxes because of the house extension works and move of contents from my parents in law house!
Same here. Mine was ordered two weeks ago and it was announced for the same date! I saw it yesterday in a shop but the price was the double of the Amazon discount price! -
Now this is top priority given to books and limited edition kits. Other items follow. You can observe that books from large editors disappear now after...a year! This is a quite new phenomenon linked to small production quantities. This wasn't up to that extreme before Covid. So if you want to pay reasonable prices get if you can whatever limited release item that interests you! Think Jetmads or Kotare for kits. I got from a French editor books about the Atlantic wall bunkers and guess what? He already warned that he will only produce 200 copies of the fifth volume! Jeez! As an IT guy I considered at least 100 times a worksheet or, better, a database. However, as a modeller acting as a squirrel for more that 40 years, I would not know where to start and this would ask for ages. So, I'm relying on my good memory and this is reasonably ok up to now! I forgot some items and purchased some useless ones but the drawback is minor in comparison with the listing effort. Possibly for my retirement time as I will not be anymore in front of screens for long hours!
I'm wondering where's the injected model of the SR-71 for which we saw some basic test shots years ago? Out of my memory it had to be released by Vintage fighters.
Thanks to that thread, I finally found most of the missing links AND for acceptable prices! Strangely the three I could not find were recent releases (Do17, Do215 and V2). Only one is available on Abebooks but for a stratospheric price! Hopefully Crecy will have the good idea to re-release them. This is a very good question Mark. According to the authors, the contents were even delivered to the editor. God knows why that one never saw the light as it looked very promising!?!
