jbrundt
LSP_Members-
890 -
Everything posted by jbrundt
That makes me sad...
Yeah, not at all like a WNW. Lots of flash. Dodgy fit, sink marks. Some things fit fine, others not at all. For example, the left MG drops right in, the right one needs a lot of tweaking to get it to fit properly. The instructions are very vague at times on what parts to use for which version so you'll need to check references. For the bracing i used .015" music wire. It's definitely needed on the landing gear. Without it it's very wobbly. I used EZ line for the aileron cable going from the fuse to the upper wing. For cables going from the fuse or wings to the control horns i used stretched sprue. There was a lot of hype built up for this kit. But in no way is this WNW calibre and it can be seen this kit was rushed to market to capitalize on WNW's demise.
Glad the the journey is over. The kit was underwhelming but overall I'm happy with the end result. It's clichéd and iconic. MRP krapplack red for the overall finish. As usual it goes on like buttah. I substituted Master barrels for the kit PE. The kit has its issues; warped wings, crap instructions, questionable engineering fitting, lots and lots of flash and seam lines that need clean-up and frah-gee-lay structure that needs wire bracing. Admittedly I got caught up in all the hype surrounding this kit but I do like the Dr.I and if i ever get around to building the Roden F.I i have in the stash it will be an interesting comparison. For now though my WWI itch has been scratched and satisfied for quite some time. Great War planes are always like a session of self-flaggelation. https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201125_062354.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201124_104709.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201123_200737.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201123_200805.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201108_100958.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201108_101143.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201104_151940.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201104_151920.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201104_151832.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201103_080413.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201103_080403.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201103_080312.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161636.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161531.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161621.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161503.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161447.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161439.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201014_161341.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201011_115703.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201010_142701.jpg https://hosting.photobucket.com/images/j8/jbrundt/LRM_20201010_121420.jpg
Eduard interior, exterior, engine. You end up seeing maybe 20% of the total used. TBH, the kit really doesn't need it. The detail OOB is actually quite good. I guess it all depends on how much work you want. Good luck with your build.
Well, the big Trumpy Avenger is done. For those that have followed this build it has been an adventure. Her she is in her glory, warts and all...
Big update.. Wingfold has lots of PE.. Techmod masks for outside, insides were done using the carrier as a template MRP paint was used... Jig required to set wheels plus brake lines added to gear: Techmod decals were used, some finesse was required for the port side insignia to fit over the air vent scoop as solvaset had zero effect on the decals. Walkways were done using ammo paste. Getting close to done... Now please go to the Ready For Inspection forum section for the final reveal....
Fuse is now closed. I also made the front cowl removable.
Back to work on the TBM. Interior painted...
Just finished this Tamiya Panigale 1199
Moar pics.....
Started the Avenger with a crapload of PE....mix of soldering parts and CA.
Probably....but there will most likely be more than a few on the tables.
Me recently completed Tamiya F-14A in VF-84 livery. Paint is primarily MRP. Only extra bit was the Fine Molds metal pitot.
My Hasegawa FW-190A-8 in Heinz Bar colors.
My Revell Me-262B-1 that I built back in 2017. MRP paints, Eduard seatbelts, Master FuG antennas and then just what is in the box. I added some piping to the exposed engine under the cowling cover.
My Revell F-18E, Wolfpack flaps & wingfold, two Bob's decals, Hasegawa weapons. Enjoy!
My Trumpeter E-100 Jagdpanzer. And her she is with the fender skirts installed: It's a monster......the workable track I used was the most time consuming part.
The weathering debate has been going of for many years now. There are equal proponents on either side of the 'spanish style'. Basically it comes down to what you, the modeler, like. You are the one who has to look at the completed model for the rest of your life and in the end you can't make everyone happy............ so ultimately the completed model has to make you happy. Argument can be made that what we do is a form of art and all artists have different styles and conversely every viewer of art is different and has their own particular tastes. Beauty is truly in the eye of the beholder.
Base is from Just Plane Stuff. Very easy to do, just paint and weather.
Thanks guys. It was a fun build. And an awesome kit.
Kevin, PM sent.... Jeff
Here's my Tamiya 1/32 F4U-1 Corsair. Hope you like....(sorry for the quality, I used my cell camera)
