22 -
Everything posted by SNA
Thanks friends! I have decals for few more romanian 109 (E3, G6) and I like to build them. Hope we will get also decals for G2/G4 version.
1/32 IAR81C Special Hobby (new images added)
SNA replied to Wackyracer's topic in Ready for Inspection
Superb! -
Thanks friends! For the position lights I made a hole in the clear plastic parts with a 0.2mm drill and I put some paint inside.
Hello! Just finished another romanian Bf109. I used the 1/32 Revell kit + Eduard Interior and some quickboost resins. The model is painted in RLM 76 and covered with RLM 74/75. I am very happy with the result, hope you will like it too.
IAR 81C Slt.Av. Mircea Teodorescu 1/32 Special Hobby
SNA replied to Miloslav1956's topic in Ready for Inspection
Superb! -
Thank you friends! Hope the next one will be better, learned a lot from this forum and your builts.
After a long time I finally done this model, difficult kit, many modifications, but the result it is model of a beautiful plane. Parts from antena wire:
I'm using super glue with activator for brass, the control surfaces were fixed with Italeri's glue for plastic. It is not the best glue, but it is very easy to fix them again if they fall and without other major damages. All of them are handmade, I'm using drills from 0.5mm to 1.5mm, nail scissors and round files. Firstly I make one piece, after I check if fits ok I copy that piece. They are not perfect, but I don't know how to make PE.
The decals have a wrong colour, they have a yellow closer to a lemon and they should be closer to RLM04, so I painted the wingtips in a yellow close to the decals to not have a huge difference. In this picture you can see the difference between decal sheet from Radub's conversion set for IAR80 and decals from AZUR kit.
Done with last parts of hinges, tomorrow I mount and paint them.
Hello! Today I started the work at flaps and ailerons hinged, just finished 24 small parts with the size less 2mm.
Hello! Last days I was worked slowly because I wasn't at home, but I applied the decals. I had small build-up problems with semi gloss varnish and I don't know exactly why, but it is not a total disaster. The kit decals doesn't have the corect yellow colour for crosses, but for me it is not a tragedy, the yellow should be closer RLM04 and I recommend Radub's decal sheet. Hope today I will have enough time to mount the flaps and ailerons.
Hello! Last days I worked at my project and now it is approaching to an end. Hope to finish this soon, cause it took me more than I exected. I struggled alot to glue the engine on fuselage and I managed to broke it once, I also have to repair the antena. Today I worked at undercarriege, I shortened the legs a little bit and I made new doors from brass because the plastic ones were ugly. Now I have to add the hoses to the wheels brakes and mount the flaps and ailerons.
Scarlat Norbert Alin is my name
Thanks for nice words! Yes Kevin you can publish it on the website:)
Hello friends! This is my new Bf 109 Ga6 based on Revell kit. For this kit i used BigEd set, Eduard landing gear and Radub's decals set for Ga6 version, but the roundels were painted. Hope you will like my work! http://i299.photobucket.com/albums/mm302/parasuta99/ssg_zpsxcnghhtw.jpg http://i299.photobucket.com/albums/mm302/parasuta99/hu_zpsawx9lffw.jpg
Hello again! A small update to my projet: First of all i changed the oil radiators with new ones made from brass I closed the fuselage and mounted wing, after that i filled the gaps, rivets and primer. For rudder i used kit decal and fit almost perfectly. Now i am a little bit stuck with the instrument panel, but i hope to find a solution soon.
Thanks for the nice welcome! For interior i used Agama RLM 76, but maybe RLM 76 Gunze is better. For IAR 81C be carefull to use this type of control stick, initially i used early type,but i had to change it.
Hello everyone! This is my first post on this forum and i want to present to you my latest work in progress. It's an IAR 81C kit from Azur, basically is out of box, but i've made some modifications to the kit using Radub's book, "Vanatorul", as reference. The first modifications i've made to the cockpit: -the seat has been build from scratch because the kit is wrong, as materials i used brass, styrene and the seat bottom is vacuformed from shrinkable plastic compared with the kit -also i've made a new floor and map case -on the cockpit sides i added some panels which are missing - and on the right side i figured the panel with some electric circuits
