miamiangler
484 -
Days Won
5
Posts posted by miamiangler
Thanks Peter for your kind words. I bet the WNW Tripe is easier to build !Willi
Absolutely incredible work. After your magical touch, the The rotary is a gem all by itself. Super work on teh cockpit interior; the floor boards are simply outstanding.
Keep 'em coming
:popcorn:
Willi
Hi Dave ,Hi Willi,
Thanks for the tip these look great and appear easy to manufacture. One of the few shortcomings of the WNW kits is the mysterious lack of spark plugs and I don't like the idea of having to buy a set from Taurus Models every time I build up an engine.
Cheers
Dave
Yes the spark plugs are easy to make with the tubing and the VectorCut nuts you can make lots of spark plugs in an evening . I still like the Taurus Models spark plugs ,but if they are hidden then you are better off making your own . As you can see I put the cowling together and not too much of the engine can be seen .
I started work on the interior of the Sopwith by adding bracing wire and adding the pulley for the elevator control .
The only addition to the IP is decals and clear rod to the pulsameter (lower left ) .
The decals are from the 1/48th Airscale WW1 set . I always thought they where to big for 1/48th !
Thanks ,
Willi
WoW very nice start ! I,m watching this one ! ,
Willi
Thanks Maru5,Willi ...the engine looks SPECTACULAR ... So very effulgence in appearance ...
I have a thing for engines..LOVE IT...
Seeing how good..no, hang fire, BRILLIANT you are at wood effects I am just hanging around to see the triplanes wings...
The kit looks pretty good except for the soft plastic ! I am starting on the interior .I love doing the wood effects on WW1 aircraft I have been checking the WNW`s site and using that as a guide . I am going to get the resin Fuselage since it is a lot easier then lengthening the fuselage by 6mm.
More later ,
Willi
Many thanks RonApparently the kit fuselage is correct for one of the prototypes but not for the production version Triplane. Contact Pheon Decals at pheon@pheondecals.com to see if the correction set is still available.
Edit - or just go here: http://www.fawcettmodelsandpatterns.co.uk/1-32-scale-resin-detail-correction-parts
Thanks Ron,
It does look 100% better .I just can`t find a web site from where I can purchase the set .
Willi
I didn't know there was a problem with the fuselageJust curious...are you going to use the kit's short fuselage or are you going with the Pheon/Brian Fawcett corrected fuselage?
This is the kit I won on Swanny`s WW1 contest . This kit will be a little more of a challenge then the WNW`s kits. I`ll be detailing the engine and interior . There`s no decals for the instrument s on the dash board so some work will be done there . I`m going to start with the engine first . I will replace all of the round bumps on the engine block with Vector Cut nuts . the spark plugs will be made from rods and tubing . the push rods will get the same work done by replacing the oversized plastic with metal tubing .
Before:
After:
Added the nuts and using .25mm rod as a guide for the push rods .
More to come later .
Thanks ,
Willi
What I did is before painting the base color .I sanded the prop with some course sand paper . That way you get some grain effect . I made the masks out of blue tape .Whoa!! Willi,that propellor belies the fact that its been painted and looks SO real...the wood effect is amazing.......
The emblems are in the Fokker E.III (late ) WNW kit.Where did you get the emblems? Are they supplied in the kits? Great job!
Very Nice ,I love the color scheme !
Willi
Thanks Dave I`ll check out the turnbuckles and your A/C .Hi Will,
I cannot comment on the Gaspatch turnbuckles, but I have been using those from RB Productions. They are easy to use, look good (IMHO) and are very cost effective. You can see them in action if you take a look at the Roland that I just completed as part of this group build
Dave
Willi
Well I decided to do Manfred Von Richthofen`s A/C I`m still waiting on Parts to arrive in the mail so All that I have done is paint and decal the tail . I still am not sure which turn buckles I want to use . The R&B productions or the GasPatch Models ? I would like some feed back on which turn buckles look the best .
Thanks ,
Willi
Hi Erwin
That`s a good base color , but instead of using brown house paint .Use artist oils . I like raw umber and burnt seianna for my props . I like some props in dark colors ,but you can lighten up some of the wood also .
Willi
Very Nice . Awesome job !
RODEN , Sopwith Triplane
in Wings of the Great War
Thanks Tim ,
I did some work on the wood graining of the struts .I just have to add black paint to the brackets .
The fuselage I ordered are a big improvement from the original . It`s 6mm longer . I added the bracing wire .
Today I glued the fuselage together and glued the bottom wings to the fuselage . I still have to add the seat cushion and seat belts .
Well that`s all for now!.
Willi
