2,842 -
Days Won
46
Everything posted by Tolga ULGUR
1/32 Trumpeter P-51B Mustang with Aerocraft corrections
Tolga ULGUR replied to Tolga ULGUR's topic in Works in Progress
Today's update;, Seat belts are from Eduard -
Some progress in the cockpit -
*** Finished*** 1/32 Dragon Bf-109E-3 "Dr Erich Mix"
Thanks -
*** Finished*** 1/32 Trumpeter P-47D-22 "Kansas Tornado"
Some progress; It was painted entirely in black primer. I used Tamiya's black acrylic. It needs some rest before Alclad. I will left it fallow for about a week -
First output for the cockpit -
Finally the painting has started The first step is the lower surfaces. They were painted with Gunze acrylic RLM65. -
I will change Gunsight. As seen in the picture, RAK Mk.II gunsight was used in this Mustang, as in many European Theater P-51s. I'll refer to my spare box for this. The strongest candidate is a resin piece from the set of Barracudacast. -
I started working on the cockpit to move on to the fuselage. Aires cockpit is ready for painting -
Thanks -
Thanks Martin -
Today's update: This is one of the most problematic parts of Trumpy's kit. As seen in the pictures, the area between the windows behind the cockpit is very wide. It is obvious that this is not the job of Trumpy's A team. Aerocraft released a clear resin kit a few years ago for this problem. It looks like it will work. The necessary parts of the fuselage were cut. Test fitting looks good. I keep moving forward, hoping I don't run into Murphy. -
Some progress I decided to build this model with the flaps down. However, this requires some modifications in the fuselage. I made these areas with plastic sheet and putty -
Thanks a lot Wayne, appreciated After I retire, I'm trying to finish the models on my bucket list, of course, trying not to compromise on quality.
Sure Ray Thanks for that
Well, The canopy mask has arrived. And I used it. Windscreen painted and installed. Emil is ready to be painted. -
I started working on the fuselage. I made the exhaust slots more reasonable by using thin plastic sheet. I will use Aerocraft's exhausts instead of Trumpy's crappy ones -
Yes, Vector's set is great. I built one before with the Vector set. However, I left the wheel well as it was. -
What you wrote encourages me to use the other set I have in the P-51A project. It is possible that I will bring this to my agenda as well. Thanks -
Here too the outer corners of the set need sanding -
Aires wheel well part installed. -
Thanks a lot Kev, much appreciated indeed.
Thanks
Some progress on the wings The incorrectly positioned landing light that Antonio mentioned bothers me. I will have to fix it -
Thanks a lot -
For my opinion this silhouette is an Allison Mustang And I want both of them "And another! Finally, that very famous aircraft, which was once under development by my wife's initiative, will be coming in a new, completely redesigned form. I can only show you a silhouette of it now, as it is still a long way off. It will fill a big missing piece in the collection of aircraft model! Luftwaffe is under threatl! "
