43 -
Posts posted by nzdavidh
Nice save. That combination of gunze paints and future killed my Tamiya Viper ever since I've been using Tamiya clear as a gloss and have never looked back.
People interpret the same rules differently and on the day the [scrutineer] that looks at this model will make the decision that is binding.
This is one of the reasons I think QMHE needs the most straight forward of OOB rules. Every year at competitions, people argue about the interpretation of the rules for this category (or at least its immediate predecessor). I can tell you from experience at the scrutineering desk, that people have extremely strong views about how the rule is applied, I can also say it's rarely applied consistently which only serves to annoy competitors more. One person's minor modification is another's modification too far. I think the OOB rule should be "you can use the contents of a single box to build the model in accordance with the instructions. Aftermarket decals or paint masks can be used. No modifications are permitted other than to reinstate panel lines removed when filling seams" - i.e. if it was in the box when you opened it, you use it as it was presented.
If this were the rule, we would know now - without argument - that removing the detail in the canopy is not permitted, nor is scribing engraved lines in place of raised detail.
For me, QMHE's golden rule remains (taken from its website):
Possibly the most important rule for competitors...Behave ethically. Read the competition rules closely and enter your model in the correct category. While most modellers understand and accept the subjective nature of the judging process, they will not accept people deliberately entering in categories that do not comply with the rules of the competition.
While we try to ensure each model is entered in the correct category through our scrutineering process, there are an incredible number of kits available on the market. Occasionally, we’ll be unsure whether a modeller has added parts not included in a kit or made modifications not permitted by the category rules. For this reason, we have to be able to rely on the information modellers provide us about their models when they enter. If we overlook something, and inadvertently allow a model to be entered in the wrong category, we know one of the many experienced modellers attending QMHE will notice... and word gets around very quickly.
There is no value in winning or placing in a category if you did not comply with the competition rules.
Which is not to say I believe Eric intended to do anything other than comply rules as he has interpreted them. My concern continues to be that there is any doubt at all about what those rules mean, and it's something I believe is ridiculously easy to fix and has been for years.
Apologies for hijacking your build thread Eric, good luck with the Sea Venom.
There are some raised lines present on the bottom of the outer wing panels and other small hatches but the majority of the aircraft is engraved. I will rescribe the raised panel lines in the original position of the raised lines (even though they arent accurate), and in the fashion of the other engraved lines of the kit so that it all matches. I believe that this may fit under the `minor refinement' part of the rules and certainly would not constitute a major rescribe/re-rivet job.
I've always thought this particular category needed to be scrapped in favour of a true Out of the Box category where you could build a kit using the contents of the box (regardless of the media included). Most modern kits include etch and in some cases resin... that we have this category dedicated to modelling the way it was done in 1982 beggars belief (at least IMO). I'd much rather see some of the excellent new kits that have been released entered in this category than encourage people to build second-rate older kits. Let's face it, high quality 1/32 kits are a recent phenomenon. I can't think of a good reason why you should have to enter the enh/mod (or whatever its called now) category if you've built the new Corsair straight from the box or one of Academy's big jets.
I think your use of aftermarket decals is probably fine, but I didn't think the category rules would permit you to either sand the cockpit details flat in order to use decals or rescribe details other than to replace lines lost during construction (and if they were raised lines you needed to replace I imagine you'd replace them with raised lines because a mix of raise and engraved can look odd). I've scrutineered several times at QMHE and this is how I've seen the rule interpreted in previous years. That said, these interpretations vary depending on who is scrutineering and who the chief judge is... if you think you've complied with the rules give it a crack, the worst that can happen is you find your model in the ENH category with comparatively few enhancements.
Fair enough - I was looking at this one http://www.grubby-fingers-aircraft-illustration.com/images/Hawk_A27-28_20_med.jpg
I take it the 16 painted practice bombs does mean you're going with the 4x CBLS load out... should look good.
Looking forward to seeing it after the flat coat goes on. Personally, my least favourite part of the build process is this phase - the decalling/all shiny bit. A question: should the end of the front det cord be hidden by the framing. It may just be the angle of that one particular photo but it looks like the cord ends short of the frame (i.e. doesn't connect to anything).
Mr Mottram has a photo of it with four CBLS and a gun pod - I imagine you've seen already seen it- all the evidence you need to load it with 4X CBLS and gun pack. I like the metalic blue on the missile too.
http://motty.hobbyvista.com/Articles/Motty's-Hawk-A27-01-31-01.jpg
There are a few photos around that show the CBLS on the outer stations and drop tanks on the inners, not sure whether the kit includes tanks.
That cockpit looks stunning
This may be the most remarkable build thread I've read, amazing... Fantastic work.
Great threat, superb modelling , fantastic result... Almost impossible to beat a raspberry ripple
That is freaking amazing... well done. So good.
Nice work. Sorry to see the flat rigging wire didn't work out...
If the one with the spade end is designed to be inserted into the fuselage rather than recieve an RFC flat flying wire, does that mean none are suited to use with RB etch flying wires (I had hoped this was the purpose of the one with the spade end)?
I was thinking RB etch would be the way to go with my SE5 as I prefer their appearance to elastic for RFC wires. .
If one looks at the middle turnbuckle here , it has a spade end to accept p/e flat rigging. I would urge research into the p/e flat rigging prior to trying to get it to work. Jus' sayin'...
This is where, for the price of the turnbuckles, I think Gas Patch could really help out. Some good guidance materials and advice about which aircraft to use the turnbuckles on would be great.
I just got my order of the GasPatch turnbuckles a few days ago and on initial inspection the look really good if not a little rough in texture. I was planning on spraying them with a Tamiya's grey primer and then a dark brass colour mix.
Cheers,
Wolf
Hi Wolf, do you think the turnbuckles would survive being cleaned up with the wire brush fitting in a dremel. works well for white metal gear?
Fair enough, I'm keen to give them ago but at 14.5 euro a set figured I'd need to aim or the right set. Will study instructions when the time comes but was hoping gas patch would offer some guidance, maybe you could suggest this in your review, they could add the info to their website
I saw those gas patch turn buckles on Doog's model pages on Facebook earlier in the month, they do look amazing. I was wondering whether their instructions make it clear which style of turn buckle to use and when, do you need all three or are the turn buckle styles specific to particular aircraft and/or tasks.
When I saw the pic of the pencil, I thought you planned to carve a new prop out of laminated timber... now that would be something else
WNW RFC flat flying wire is knitting in elastic. EZ line reportedly has a different profile (round not flat). Personally, I can't pick the flat profile in the knitting-in elastic and would rather use RB's flat etch for RFC flying wire ... Eric if you can spend the difference between what it costs to buy EZ line and what it costs to buy knitting-in elastic in gas money, you are getting lousy mileage out of your Holden.
That part camo, part NMF drop tank is a nice detail in those reference pics. I love it when there a little details like hat you can incorporate in a build. Bang seat looks very nice.
Dave, Looking at a few more pics you are right, I might rip it out and take it up a bit higher. The only problem will be the sides of the seat may be too high compared to the side consoles if you know what I mean. I may even just leave it where it is!
At his point, you're just asking for trouble ripping it out. If it were me, I'd leave well enough alone. Do what everyone else who enters QMHE knowing something should look a little different does, omit the relevant reference photos
Hi Dave, I used the Quickboost seat, and next to the kit seat it is certainly smaller. I think I have a pic of the 2 side by side in an earlier post. I raised the seat by about 3mm to what you see it now.
Good plan, it's beautifully paint but looks noticably underscale when down that low. Looking forward to seeing it at QMHE... it will take up a whole lot of real estate on the comp table.
Nice paint work.
That shot next to Showtime 100 just shows how big the F-117 really is. Amazed to open the 1/48 box and realise how big it is. Is the kit ejection seat underscale - it looks a bit that way,the top of the seat should be up above that last lightning hole?
An impressive model... the weapons look good finished.
too much
in LSP Discussion
I tend to avoid subjects that don't require weathering. It's one of those skills I would love to master... its the bit of the process that really brings modelling to life for me.
I have to admit to be being a bit of a fan of pre-shading as a weathering technique but not the meticulous outlining of panel lines using black paint approach. To my eye that always results in a cartoon like effect. No matter how subtle the effect, if I can pick black preshaded panel lines the illusion is ruined for me.
I like using a more random approach and pre-shading colours that compliment the range of tones you're aiming for at the end of the process (which means you'd almost never use black as a pre-shading colour). I also tend to avoid shading the panel lines, focusing instead on particular areas that might have weathered and leaving others alone. I see it as one more technique in the tool-kit so wouldn't write it off completely (reflecting on some of the early comments in this thread regarding pre-shading).
