Guest bigsky Posted September 20, 2003 Share Posted September 20, 2003 I am interested in know how to convert a F4U-4 to a F4U-5 (early Korea era). I know there are differencies in the crowel, but how difficult will the overall be? I am planning on using the Trump 1/32 Corsair to do so. If anyone has done so before, I am #> interested. Link to comment Share on other sites More sharing options...
Silverback Posted September 21, 2003 Share Posted September 21, 2003 F4U-4 to F4U-5 (Damn! What a project to consider!) 1. Add a scale 12" (I think thats the right number) to the fuselage in front of the wing leading edge. 2. Alter the forward fuselage cross section to the -5's "pear" shape and recontour the exhaust cutouts. Fabricate appropriate exhaust pipes. 3. Modify the cowl to incorporate the two cheek scoops and the proper -5 cowl flap configuration. 4. Modify the wing root intakes to -5 configuration. 5. Modify the fabric sections of the wings to metal panels. If ailerons or flaps are fabric, they must be metal-covered as well. Also, lose the step in the starboard inboard flap if its included. 6. Modify the 6 x .50cal armament to 4 X 20mm; alter the access doors and ejection chutes; add -5-style rocket launch stubs. 7. Modify the interior to -5, or -5N standards as appropriate for the version you're building. 8. Modify the canopy, windscreen and fuselage spine to -5 configuration. 9. Modify fuselage for kick-in and drop-down steps; modify radio access panels. 10. For a -5N, add the radar pod; for a -5NL, also add deicer boots. 11. Assuming the engine is a true -4 version (R2800-18W or -42W), you'll be OK. Otherwise modify the smooth "B" gearcase of teh early corsairs to a "C" series bolted gearcase. Also, I think the propeller was different (but I can't quite get a handle on the shape). Some -5s also got the later-style wheels, although most had the early ones. A great reference is the AeroDetails book on the F4U. Good luck, patience and more good luck will be the key to making this one work! #> Phil Schenfeld - 'nother bent-wing guy Link to comment Share on other sites More sharing options...
