Brian Perris
325 -
Posts posted by Brian Perris
Ben,
Have been trying to find a copy but no joy so far! Know where to purchase a copy??
thx,
Brian
Again thanks all for the great info. I've got the Eduards PE for internal and external, the Contact Resine set, two of the CMK sets (the engine and the main gear area replacement), and a set of the Montex masks for it. It should be a fun build.
Brian
Thx Guys for the info. D--great links.
Brian
Collecting data for my late fall build of the Revell 162 and looking for some good reference material--any suggestions?
thx,
Brian
Thanks all.
Brian
What are the major differences between an F-14A and B?
thx,
Brian
JEEPERS!!!!!!
Brian
I've used 91% to wipe it down once applied to a model after drying--the alcohol worked very well. I've got a spray can of the 1000 that I'm going to use as a primer to cover some sanding scratches--once applied from the can is it a good idea to wet sand it to get a better surface or is the surface ready to finish sand?
Brian
Thanks for the look Mark.
Brian
Mark,
The intake sideplates look pretty good in the pics? Did you do a pattern or ? for those sideplates? If so can you show it on the forum? I've read your MIG article several times hoping that part 2 would show up!!!!!!
thx,
Brian
Matt,
Checkout Jerry Rutmans' detail sets for the kit. I have all of his resin for my bird and I think it will really add to the kit.
Brian
Jay,
The bird looks great--makes me want to get mine out and start to work.
Brian
Ben,
Just fit my first intake and with the wing in place the intake doesn't fit up against the fuselage. I think that like yours I'm going to have to sand some of the intake bottom off where it butts up against the wing to move the intake back flush against the fuselage side. Looks like once I sand that area down it should fit up against the side of the aircraft pretty good. Thanks for the info and confirmation on the tweaks needed for these parts.
Brian
Thanks for the steer Mark.
Brian
Ben,
Didn 't you do an article about installing the seamless suckers in your Tammy F-4? If so, where can I get a copy of it????
thx,
Brian
Larry,
Good to see you back on the net.
Brian
Chris,
Thanks for the great pics and the tip--what tip you might say??? The way you covered your tank just provided me with an idea on how to cover my 24th scale Hurricane tank and make it look more realistic.
thx,
Brian
It was a Mercury Capsule that was completely scratch built--it was incredibly detailed--not the Atomic City model. There was one of those right down the table from it.
Brian
I saw the display also--didn't realize the A-7 was that big!!!!
Brian
Looks great Erwin.
Brian
Thanks Mike,
That also adds a great deal of clarity as to how this harness works. Have two books on this bird in bound--looking forward to seeing some more detail of the cockpit area to help the build.
thx again,
Brian
Radub,
That's exactly the diagram I needed! Thx--that's one crazy affair!!!!!!
Brian
Radu,
Do you have a good seat reference pic that illustrates how the sutton harness attaches to the seat? I understand the shoulder harness and lap belts but my set of CE resin belts has a second "Y" belt that I'm not sure where it attaches??
thx,
Brian
Thanks for the pic,
Brian
References for the He 162
in Aviation Discussion & Research
Is the MBI book a paperback with a black cover?
Brian
