HobbyZoneUSA Posted May 19, 2018 Author Share Posted May 19, 2018 Slowly making progress on the Kitty Hawk F-5E - the forward nose section now has thin Evergreen strip styrene filling the slide mold tracks and that will be blended smooth shortly. Meanwhile, it was time to close up the gun bay doors. While I thought the doors were positionable, they were designed to be displayed open. The latches are molded open on the upper door halves which were removed and will be filled in with Mr.Surfacer 500. The upper and lower door halves required a bit of trimming to get them to close properly, but now they are closed. jgrease, Marcel111, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 19, 2018 Author Share Posted May 19, 2018 Finally have the forward fuselage of the Kitty Hawk 1/32 F-5E assembled! This was a bit more complicated than it needed to be, and it takes a little patience, but it does go together. Now I can start on the rear fuselage and wings. Out2gtcha, Iain, NavyF4s and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 20, 2018 Share Posted May 20, 2018 Nice work Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 20, 2018 Share Posted May 20, 2018 Cool. I'm really forward to seeing more of this. Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 20, 2018 Share Posted May 20, 2018 Thanks. The best way to critique your own work is to publish photos and then look at them. I already see a few touch-ups that are going to happen very soon. I think in the same way, it's actually made me more aware of stuff that I hadn't previously noticed, so has actually improved my game some. HobbyZoneUSA 1 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 20, 2018 Author Share Posted May 20, 2018 The Kitty Hawk 1/32 F-5E is moving along much faster. The front and rear fuselage are together and the backdates are completed now including the early LERX, the removal of the ventral chaff/flare mount, and rear RHAW antenna mounts. LSP_Kevin, Harold, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 20, 2018 Share Posted May 20, 2018 The pilot looks excellent too. HobbyZoneUSA 1 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 20, 2018 Author Share Posted May 20, 2018 The project is getting closer to primer! johncrow, Kagemusha, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
Empire Posted May 21, 2018 Share Posted May 21, 2018 Looks great. Cheers Kai HobbyZoneUSA 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 21, 2018 Share Posted May 21, 2018 Wow this is going up crazy fast! I really like the way this is going together, but Im still a bit worried about trunking............I hope someone from the AM sector gives us some seamless ones! Harold, HobbyZoneUSA and LSP_K2 3 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 21, 2018 Author Share Posted May 21, 2018 I have something that I may try on the next build for trunking, but I'm not convinced that it is mission critical either. While it was a bit of a surprise to see that open cavity of the rear fuselage, once that was painted black, the view down the intakes isn't much different than the Hasegawa kit with the blanked-off intakes, and nobody has ever done aftermarket intakes for the Hasegawa F-5E to date. LSP_Paul, LSP_K2, Harold and 1 other 4 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 22, 2018 Author Share Posted May 22, 2018 One more backdate in progress, removing the ECS vent from the port side of the canopy. Photos soon. LSP_K2 1 Link to comment Share on other sites More sharing options...
HobbyZoneUSA Posted May 22, 2018 Author Share Posted May 22, 2018 (edited) While installing the flaps and ailerons onto the wings, I noticed that the ailerons are both deflected down while the flaps are set at full-up. While you see a few that might sag when parked, I didn't see many on the line at Nellis that way. I reworked the hinges and have them neutral. The canopy and windscreen are dry-fitted and I'll be removing the excess putty off the ECS vent on the canopy frame next. Edited May 23, 2018 by HobbyZoneUSA Out2gtcha, LSP_Kevin, Gazzas and 5 others 8 Link to comment Share on other sites More sharing options...
karimb Posted May 25, 2018 Share Posted May 25, 2018 Nice work done. i wonder how hard the surgery was to get the vent removed from the canopy. Does that entail any removal from the inside of the canopy too? looking forward to some paint on the kit! Karim HobbyZoneUSA 1 Link to comment Share on other sites More sharing options...
shark64 Posted May 25, 2018 Share Posted May 25, 2018 turning out nicely HobbyZoneUSA 1 Link to comment Share on other sites More sharing options...
