Not another ROG P-51D Mustang? Lets call her done!
  • Please log in to reply
71 replies to this topic
#16 dennismcc
dennismcc
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,781 posts
  • Gender:Male
Posted 25 February 2018 - 08:07 PM
Now that is looking really good.
Cheers
Dennis
#17 mmaben
mmaben
    Senior Member
  • LSP_Members
  • 4,401 posts
  • Gender:Male
Posted 25 February 2018 - 10:35 PM
I like how your reds aren't too bright.
Not too fire enginey.
Edited by mmaben, 26 February 2018 - 11:31 PM.
I just like airplanes
Mike                        Smirnoffcat    RomanianG-2
#18 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,910 posts
  • Gender:Male
Posted 26 February 2018 - 08:14 AM
Sweet!
​We don't have social skills.  We build models.
#19 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 1,325 posts
  • Gender:Male
Posted 01 March 2018 - 02:24 AM
Miles of seam filler...
I spent 8 hours sanding, filling, sanding, filling, finally shot a first layer of primer, I think I need more filler now.
The infamous flaps, full length filling, both sides.
  • blackbetty, MARU5137, KUROK and 3 others like this
#20 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,910 posts
  • Gender:Male
Posted 01 March 2018 - 03:57 AM
Where would we be without seams to fill?  Keep it up!
Gaz
#21 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 1,325 posts
  • Gender:Male
Posted 04 March 2018 - 11:17 PM
Well, I had a major mishap last Wednesday, I had a lot of issues painting the Tamiya gloss yellow. It was coming out of the airbrush super thick and rough, I keep thinning it more and more, then all of the sudden, it was so thin, it wouldn’t stay. It would puddle and pool and developed ripples of color. I can only guess that the bottle had to be old. I decided to just leave it alone, let it dry, walk away, and I will come back later to sand and respray with fresh jar of yellow. I didn’t get any pictures, because I had considered binning the whole model, just pulling the cockpit for transplant to a Hasegawa kit.
Overnight, a miracle happened, since I had thinned it so much and it was a humid rainy night, it leveled out and the rough texture smoothed out. I did have to do a little sanding with some 2000 grit to smooth the orange peel. I went over all the yellow with fine sanding pads, then resprayed the yellow. The new jar did the trick and covered much better. Below is a pic of it masked off. You can see I had to fill and sand again on the seam in front and behind the cockpit. At this point, I have sprayed red, masked ebpverything off, and sanded the whole model with 2000, then 3200 grit, now ready for primer.
Edited by 1to1scale, 04 March 2018 - 11:19 PM.
  • johncrow, Harold, Uncarina and 2 others like this
#22 Bstarr3
Bstarr3
    Senior Member
  • LSP_Members
  • 534 posts
  • Gender:Male
Posted 04 March 2018 - 11:48 PM
Nice work. Airscale or barracuda for the cockpit placards?
#23 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 1,325 posts
  • Gender:Male
Posted 04 March 2018 - 11:53 PM
Neither, Revell.
  • RLWP likes this
#24 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 1,325 posts
  • Gender:Male
Posted 05 March 2018 - 04:13 AM
I have a nice smooth layer of primer.
I fought with this seam along the spine, finally got it hid.
Finally got this seam to hide
Masking tape madness, mid spray.
Final result. I ended up with 5 metal shades on it, plus White aluminum on the rudder and elevators.
I still need to mask and spray a couple wing panels and landing gear doors, but after 2 1/2 hours with paint in my airbrush, it was crying for a tear down and clean.
Edited by 1to1scale, 05 March 2018 - 04:18 AM.
  • johncrow, dennismcc, Astro32 and 14 others like this
#25 mattlow
mattlow
    Senior Member
  • LSP_Members
  • 2,917 posts
  • Gender:Male
Posted 05 March 2018 - 09:52 AM
Very nice.
You're using the Vallejo water based metallics... how do you find they spray and cover?
There's going to be a flurry of these crossing the finish line in the next weeks.
Matt
#26 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 23,008 posts
  • Gender:Male
Posted 05 March 2018 - 01:41 PM
Looks lovely!
  • CANicoll likes this
#27 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 1,325 posts
  • Gender:Male
Posted 05 March 2018 - 07:05 PM
T
Very nice.
Matt
They cover very well, much better than an allclad, dry fast, tape lift is rare, if it does, then you need to let it dry longer. Usually, colors dry between 15-30 min and can be masked over with de-tacked tamiya.
The biggest critical factor is to spray at very low pressure and with very little paint flow, I do 12-15 psi and just barely any paint flow. They are thin, cover well, and will spray fast. You can overspray to touch up an area if needed as soon as it dries to the touch (5 min). I have a few goofs I need to sand and fix today.
Here is what I used, Stynilrez Grey primer (my favorite in tests).
ALL metal colors were Vallejo Metal Air.
77.724 Silver --- painted wings top and bottom, and landing gear
77.701 Aluminum --- overall body and tail, flaps, Aux fuel tanks.
77.717 Dull Aluminum --- 2nd major accent color, ailerons, lower radiator scoop (this one takes much longer to dry before masking, maybe 45 min)
77.706 White Aluminum --- Fabric covered tail surfaces
77.704 Pale Burnt Metal --- exhaust panels
77.703 Dark Aluminum --- upper rudder, lower fuel tank panels, a few accent panels
Tamiya X-7 Red --- Perfect match to the Eaglecals Red for Flying Dutchman.
Tamiya X-8 Lemon Yellow --- Wing and Tail ID stripes.
  • Uncarina, coogrfan and CANicoll like this
#28 Phartycr0c
Phartycr0c
    Senior Member
  • LSP_Members
  • 1,185 posts
Posted 05 March 2018 - 08:22 PM
Coming along nicely. Have to say this site provides sooo much inspiration on so many different subjects, keep up the great work
Eagles may soar, but weasles dont get sucked into jet engines!
#29 mmaben
mmaben
    Senior Member
  • LSP_Members
  • 4,401 posts
  • Gender:Male
Posted 06 March 2018 - 02:05 AM
I say ,  it looks like an 'American Beauty' ???
Yes ?   No  ?
#30 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,910 posts
  • Gender:Male
Posted 06 March 2018 - 08:16 AM
Very nice!  You've gone from zero to almost done, very quickly.
