Can't figure it out: Airbrush and Lacquer primer problem
  • Please log in to reply
42 replies to this topic
#16 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,895 posts
  • Gender:Male
Posted 17 February 2018 - 01:15 AM
It's back Up
Thanks!  I really appreciate a lot of your videos.
Gaz
​We don't have social skills.  We build models.
#17 ringleheim
ringleheim
    Senior Member
  • LSP_Members
  • 918 posts
  • Gender:Male
Posted 18 February 2018 - 07:09 PM
Gazzas, this seems weird.
The first thing I would do is take the airbrush apart, especially the nozzle/tip area, and clean the heck out of everything with lacquer thinner.  Make sure the airbrush is in like new condition.
Make sure you are thinning a lacquer based product with lacquer thinner.  I recommend using only Mr. Leveling Thinner from Gunze Sangyo.  The stuff is expensive, but it has retarder built into it and makes lacquers and Tamiya acrylics spray perfectly.
You really should not ever be getting orange peel.  To me it means you are spraying too aggressively and putting too much wet paint on the subject too quickly.  And then it is drying before it can level itself out.
Go with a thinner paint mixture and a more gentle air pressure.  20 PSI is good as a general rule; that should be plenty as long as you have thinned appropriately for that pressure.
Always apply multiple light coats letting the paint set up a bit between passes, and frequently blow air onto fresh paint with the airbrush to help it dry.
Orange peel is sort of the byproduct of blasting away with a ton of paint at high pressure at a close distance.  Try to paint in the opposite sort of manner.
Hope some of this helps!
#18 Hardcore
Hardcore
    Senior Member
  • LSP_Members
  • 1,632 posts
  • Gender:Male
Posted 18 February 2018 - 11:02 PM
Dry tips is a problem of the past for me. I am not sure how but I suspects using a cheap AB with bigger nozzle is relevant. Then maybe I learned to thin the paint.
#19 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 25,104 posts
  • Gender:Male
Posted 19 February 2018 - 12:13 AM
HI Gaz
Yikes, orange peel with lacquer paints, something isn't right. You know my work and I'm pretty much fully converted to lacquer paints now: MRP and Mr Color; used for both the base primer and top coats. Never a speck of orange peel and I'm pretty sure it isn't the airbrush. Just make sure the air brush is really clean, with no clogs and no residue from other types of paint in the air brush.
I never thin MRP paints but do use a few drops of Gunze Mild Retarder to keep the lacquer wet and flow a bit better.
Mr Color: thinned 3 parts Mr Color Self Leveling Thinner to one part of Mr Color and a few drops of Retarder.
The paint is now good to go and mix in a 1 oz plastic cup and never in the air brush cup.
I shoot around 12-15 psi, an 1-2 inches or so from the model surface.
keep the air brush square to the model surface
Lots of thin, light coats.
It it's hot and humid and no AC , add more retarder.
I shoot this way no matter what the air brush:
My weapons of choice:
HS Infinity CR Plus .2 tip
Iwata Eclipse HP-CS .35 tip
Iwata Revolution CR .5 tip
Iwata HP-M1
Just doesn't matter the air brush. Just keep the paint thinned, add retarder, lots of thin light coats and keep the air brush moving.
Orange peel is normally the paint being too thick and blasted on (I never shoot at 25 psi; 18 psi is about my limit) .
Peter
  • MARU5137 and CANicoll like this
#20 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,895 posts
  • Gender:Male
Posted 19 February 2018 - 02:53 AM
Guys,
Thanks for all of the great, helpful responses. I managed to get a decent result using Mr. Self levelling thinner, yesterday. I thinned the primer roughly 50/50 and didn't have any trouble getting thin, smooth coats.
Gaz
  • Peterpools, MARU5137 and CANicoll like this
#21 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 25,104 posts
  • Gender:Male
Posted 19 February 2018 - 02:55 AM
gaz
Thinning is the key. Use 3 or 4 drops of Gunze Mild retarder and you will be amazed at how smooth the surface will be
Peter
  • MARU5137, CANicoll and Gazzas like this
#22 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,895 posts
  • Gender:Male
Posted 19 February 2018 - 08:53 AM
Peter,
   Thanks for the recommendation.  I ordered a bottle, and will be able to try it soon.
Gaz
#23 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,716 posts
  • Gender:Male
Posted 20 February 2018 - 05:20 PM
gaz
Peter
Peter, will the Gunze retarder work with Vallejo acrylics or just the lacquers?
THX  Chris
  • MARU5137 likes this
#24 kman458
kman458
    Member
  • LSP_Members
  • PipPip
  • 28 posts
  • Gender:Male
Posted 03 March 2018 - 05:49 AM
I have a question since we are talking about paint. I have some model master metallized aluminum lacquer I would like to use on an airplane model. It's been so long I can not remember what I used to clean the airbrush. What do i need to use?
Edited by kman458, 03 March 2018 - 05:50 AM.
#25 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,895 posts
  • Gender:Male
Posted 04 March 2018 - 03:43 AM
Any hardware store lacquer thinner should do.
Gaz
#26 kman458
kman458
    Member
  • LSP_Members
  • PipPip
  • 28 posts
  • Gender:Male
Posted 05 March 2018 - 03:11 AM
Gaz
Ok cool. Thanks for the help.
Kenny
#27 tcrayne
tcrayne
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 09 March 2018 - 01:50 AM
I only get the problem you have when I don't clean what I'm painting to the fullest. There is always extractor residue left over on plastic parts that sometimes can be hard to remove. Most paints will react to the residue
#28 Zero77
Zero77
    Senior Member
  • LSP_Members
  • 6,041 posts
  • Gender:Male
Posted 09 March 2018 - 07:11 AM
  Actually worse than orange peel.  It's more like spraying it with fine granules.
It sounds like you simply dont thin you paint / primer enough.
What is the consistancy of your mix?
Following the big Photobucket rip-off attempt, all my pictures on the forum cannot display anymore. I try to reupload the RFI pictures, but i'm not sure i'd have enough time and energy to reupload the pictures of the WIP threads. If you're interested in a specific subject and want me to reupload some pictures, just let me know. :)
Finished : F-16C Barak, F-4J VMF333, Czech Mig-19PM, Bell X-1, Russian Su-25 in Chechnya, Ta152H-1, Czech Avia S.199, Heinkel He162, Swiss AF Bf109G-6, Regia Aeronautica Bf109G-6, P-47D "Slick Chick", RFC Sopwith Pup, A5M2 Claude, Schneider Cup 1926 Macchi M.39, German F-104G JaboG34, Curtiss P-6E, Curtiss P-36A USAAC, Piper SuperCub floatplane (PA-18-150), Russian built Nieuport 11, Albatros D.Va Seefrontstaffel 1, Bf109G-12 (two-seater trainer), Texas ANG F-86D,  Post-war Hawker Tempest Mk.V, Bf109E-3, F-35A 34th FS
#29 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,716 posts
  • Gender:Male
Posted 11 March 2018 - 05:35 PM
And maybe at too-high of pressure?  I know some folks here shoot at 12-14 psi I tend to shoot 16-18 myself.  Thinning the paint is definitely important.
Good luck and remember - Practice, Practice, Practice!!!   B)
#30 GuildAero
GuildAero
    Senior Member
  • LSP_Members
  • 648 posts
  • Gender:Male
Posted 11 March 2018 - 07:03 PM
If you have a decent compressor, use a small spray gun. Especially for primer. All you want is a nice even finish with a primer and for the most part, any other paint.  If you must use an airbrush, dump the ones with needles and use a single action. I have 2 Paasche Model Hs. Now considered vintage apparently. Probably by the airbrush snobs. I ignore all that tosh and keep one for colour, one for clear.  I clean them with cellulose glossing thinners (unless I use Valejo clear, then it's water) or (what I think you overseas chaps call lacquer thinners)  I buy the one that costs these days about 12 quid a gallon, but it last me 2 years at least.  I use Sikkens self-etch primer on everything from aluminium and brass (for which it was originally developed) to resin, plastic and yes, even wood.  It ain't nice stuff I should imagine, so I spray it outdoors.   I spray everything outdoors if at all possible.  I use cellulose paints if at all possible and Zero paints, which are the best, bar none are cellulose (only different, he says) and so do them outside. Because they are airbrush ready I use the colour Paasche Model H. It takes seconds to set up for a nice spray and then I go over all with Akrifan clear in the small spray gun for which it is formulated. No thinners required.  Zero paint needs a gloss clear for most finishes or, I assume a matt clear for war stuff. I don't know, I don't do war.  If you get orange peel, the paint is almost certainly too thick, as your pressure is plenty high enough. My self -etch is dry in about 5 minutes, Akrifan gloss clear about 10.
I'd invest in a small spray gun, also called a spotting gun or a dent gun.  The needle is thick and bullet proof, they are easy to clean without damage and the whole thing is less than the cost of an airbrush....much less. Last I looked, a very nice one, all fancy blue anodized was a measly 18 quid.
In case you wonder, I have been doing this since I was a teenager. This year I will have been a pensioner for a year.  I've painted full sized classic cars (they weren't then classics!) down to 2mm scale model railways.  Same rules apply. Like most modelmaking it really is NOT difficult if you're just a bit careful.  Oh and the best way to spray is to pretend you're a robot. Nice mechanical strokes back and forth starting off the model, finishing off the other end.
Then bang it in somewhere dry and warm  and dust free.
I'm making either a master or a finished slot car at least one a week and always have, so that's how often I spray.
Cheers,
Martin
Manifestly it is better to use simple tools expertly than to possess a bewildering assortment of complicated gadgets and either neglect or use them incompetently. ( L.T.C.Rolt)
Artwork at :- http://drawingboard.....com/index.html
Blog at:-      http://oddsoracle.blogspot.co.uk/
