1/32 T-38A Talon
  • Please log in to reply
24 replies to this topic
#1 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 04 February 2018 - 01:45 AM
I decided to start this concept in my spare time as it may take awhile. I could wait forever for someone to inject one  <_<  An initial look at the lines tells me that the back of the canopy is the reference point and everything moves forward from there. I picked up the Belcher Bits get to transform the F-5E to an A. I also have 3 canopies, 3 front fuselage sections, and 2 complete kits to work from...my version of mistake proofing  :coolio:  The big question mark will be whether I can get a canopy formed or not. I dropped a note over in tips and techniques but if anyone knows someone that can help me out with a vacuum formed canaopy let me know.
6732B7B8-B8B9-4BF2-8BAD-EBB810719C24-M.j
Here's my 1st test, I wanted to see if there was any way to combine 2 canopies to make it work out. No dice unfortunately. The stock canopy drops too far in the front. Thought I might be able to make one shorter and the other taller by building up the frame but it's just too far off. If nothing else I wanted to try out these new ultrafine saws I got.
8EDE66EA-2BED-4084-AB44-3CE60BB86171-M.j
I was doing a couple things at once here; finding the marks on top for relocating the coaming (not sure if this is the right term but the cover over the instruments).
I found a great straight on shot of the plane with the canopies raised so I took the ratio of the canopy length to the overall length of the opening and mocked up the two cockpits.
And here's where I left things today. Canopies in place just to see how it looks in profile.
If you've looked into doing something similar let me know your thoughts on the design. Any advice from you guys that scratch build alot let me know how you'd proceed. I'm just working off the 1st set of practice parts so I can do some experimenting here for sure.
  • johncrow, harvey, sandokan and 2 others like this
On the bench - 1/48 Revell PT-17, close to being a RedBull special, 1/48 Monogram F-16 Alaska Aggressor,
1/32 T-38 Thunderbird custom build, on hold awaiting seats from the new KH model,
1/32 F/A-18A kitbash - augmenting the Haz YF prototype model with Aries cockpit, misc Academy kit parts, and parts generously donated by red Dog & Dragon!
#2 mmaben
mmaben
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 4,401 posts
  • Gender:Male
Posted 04 February 2018 - 02:01 AM
:popcorn: :popcorn: :popcorn:
  • harvey likes this
I just like airplanes
Mike                        Smirnoffcat    RomanianG-2
#3 Lenny320
Lenny320
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 66 posts
  • Gender:Male
Posted 04 February 2018 - 01:26 PM
You might look at Pete Fleischmann's T-38 build. He has done some incredible work.
  • Out2gtcha and themongoose like this
#4 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,999 posts
  • Gender:Male
Posted 04 February 2018 - 04:42 PM
Cool project! I love the T-38. I have also been and still AM waiting for someone to kit one.
Does the F-5E/A have the same underbelly curve up from aft to the tip of the nose like the T-28 does?
#5 Dandiego
Dandiego
    Senior Member
  • LSP_Members
  • 552 posts
  • Gender:Male
Posted 04 February 2018 - 08:40 PM
T-38 is so cool. Good luck with this. Everything I think of doing something like this the same old problem rears it's ugly head ...the canopy. You will probably need to vac a new canopy, good luck with that. I have crashed and burned several times in he past.
Dan
#6 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 04 February 2018 - 10:33 PM
The Belcher kit includes a nosecone with a modified arch to it. Then everything behind the cockpit is also in the Belcher kit so it looks like all the curves are matched up now. The IP coaming moved forward nicely without having to narrow it or widen the fuselage so that makes for a clean look without worrying about any of the lines looking wrong. I’m excited about this now that I kicked it off and it feels possible to accomplish.
#7 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 18 February 2018 - 11:13 PM
Back on this baby today. I'm working on the form so I can make a mold for the vacuum formed canopy.
1st I traced the outline of the canopy from the sections I had made earlier. Then I determined where to make the cuts to keep the profile smooth. I read on here that using clay give support to the clear plastic and minimizes the chances of cracking it while sawing.
BE8D27F5-1C48-4D28-B59F-D4CE8BBCFC1D-L.j
Next I notched the canopy out. The frame along the bottom is pretty straight. I think it will take some filing and filling once the mold is done but it matched up real well between the halves. Where as the curved portions of the canopy weren't even close.
77710110-D4AF-42A6-A84E-FC236EF0E82C-L.j
Next I used some T beam evergreen strip to set the profile and stiffen the pieces up.
A71B830A-5717-4503-888B-D332885899E1-L.j
Then last I placed flat sections of evergreen over the entire outside. That will keep the molding material inside the canopy until it dries. More next weekend as I'm traveling through Wednesday and then the kids have school activities. I'm going to have to get out of my cave this week  :)
F87BE4BC-09B7-4E69-9E34-B37E3F5D821D-L.j
  • johncrow, LSP_Kevin, Out2gtcha and 2 others like this
#8 Youngtiger1
Youngtiger1
    Senior Member
  • LSP_Members
  • 2,654 posts
  • Gender:Male
Posted 19 February 2018 - 05:15 AM
Wow, ambitious project. Though F-5 is similar to T-38 but far from it's beauty. So, you have your hands full but a great journey ahead. ;)
If you don't it have it already I strongly suggest you get the Daco T-38 book. It will be a strong reference point for your build. Just a thought.
#9 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 19 February 2018 - 12:04 PM
Wow, I hadn’t found that book in my searches. Will definitely pick one up. Thx!
#10 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 23 February 2018 - 04:30 AM
Tonight I made my first impression of the canopy mold. Since this is new I figure to try 2 different techniques. From this I’ll make a clay overmold that i can pour bondo into for the first method. For the second method Tomorrow I’ll pick up some plaster and make a form that i can directly place the hot PETG over. One of the guys in the Cincinnati scale modelers club iffered to help with the forming if I could do the molding.
  • sandokan likes this
#11 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 24 February 2018 - 04:53 AM
Lots of fun this project! So the clay was interesting. Because the canopy is sooo long shrinkage was actually a consideration. It ended up 1/8” short. Lesson learned use clay right away for the mold.
My plaster mold and casting came out ok. Almost messed it up. Apparently the mold moved when i poured the castable around it. I’m going to use it but as a spare. Tomorrow I’m going to do another set now that I’ve experimented once. The rest of it seems to be good. While the castable is still drying, about an hour after pour, i was able to sand the lip of the canopy to a uniform angle all the way down the length. This has been the hardest part to recreate because it’s rather thin.
#12 MostlyRacers
MostlyRacers
    Senior Member
  • LSP_Members
  • 5,254 posts
  • Gender:Male
Posted 24 February 2018 - 08:13 AM
If I may, you are on the right track, but your molds, whether positive or negative, look a bit rough to achieve a smooth result.
If you use a female mold to form the clear plastic (PETG is the one to use, with plenty of stock for failures, because it is extremely sensitive to temperature - too hot and bubbles will form inside the plastic, too cold and it will not form ), create a small hole for the air, and hence the plastic sheet, in the mold to be sucked.
Use monofilament to create this hole. Stick it in the male master, pour your mold, and when the mold has set, remove the monofilament with pliers : a neat, smooth small diameter hole will result. To avoid the « dimple » created by the hot plastic being sucked in the hole, the diameter of the hole should 1/2 of the plastic sheet thickness, i.e. 0.5 mm for 1 mm sheet, or 0.375 / 0.4 mm for 0.75 sheet. This is why monofilament is the best way to get this small diameter hole in the female mold.
Keep going. You’re learning a new trade, and scratchbuilding is sometimes (often ;) ? ) frustrating, but I know no more satisfying modelling.
Hubert
  • themongoose likes this
#13 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 25 February 2018 - 01:27 AM
Thanks for the observations Hubert! It just wasn’t working that way for sure. I think it’s somewhat more complicated because I’m starting with a female mold...at least I’m telling myself that 😣🙈🙉🙊 so next time I may use foam and start with the male mold though it’s probably got its own set of complications.
I went back to the original canopy pieces I glued together and finished the inside as smooth as possible. Had a small crack in the bondo from all the handling but i filled it with clay and the put vaseline on it so the clay would come out. Ruined one because I forgot the vaseline.
C2E2D2B4-385F-4BB1-9C11-2633170ACB93-XL.
When i put the mold on the bottom of the tuperware it kept moving around and material got under it in places and made it uneven.
IMG_1474-XL.jpg[/url
The solution I thought was to press the mold in from the top. Now i just needed a way to keep it from settling to the bottom. 🤔 So i made it a lifejacket 🤣
I cut slits in the side so no air would be trapped. I put the screws through the platic sheet and into the clay while it was still inside the canopy so the clay wouldn’t distort. This also made it easy to remove the clay without messing up any corners. I mixed up the perfect cast and poured it in the tuperware, sprayed the clay with a windex type product to minimize air bubbles, and then angled it into the casting material so the slanted rear of canopy was filled first. And presto it floated!
0165C5DA-77F6-4396-A2C4-F6D7B1D9C12E-XL.
Here’s my finished product.
[url=https://themaddmongoose.smugmug.com/T-38A-Thunderbird/i-7jRXHBp/A]56AB5D81-E1F3-453A-A4C1-85BC642C3BAD-XL.
It has to dry for 24+ hours so I’ll wait till Monday to try a mold from it that i can use to form petg over. Tomorrow I’ll probably make another one so I have a spare. I will probably have to make several molds anyway So I don’t get caught short in the forming stage. One of the guys from the local club is goingg to help me with that as he does them all the time for his paper models.
Any upfront advive on this next molding step would be appreciated for sure.
  • sandokan and DonH like this
#14 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 288 posts
  • Gender:Male
Posted 25 February 2018 - 04:21 PM
Now that I know I have a good copy of my canopy mock-up I felt safe pouring a mold right from the original. The bag says this perfect cast gets hot so i was worried about distorting the pep canopy plastic and bondo i made it from. After a few molds though I recognized it was just getting warm, not hot. I applied a light coat of vaseline, capped the ends (left a small hole for air to escape), and then hit it with the hairdryer so the vaseline would flow out smoothly eliminating any chunkiiness or streaking. Hopefully I can finish this nicely and use it for my mold.
9A26CD9F-400D-445B-8739-89983227BD8C-L.j
2134802F-6C82-4076-AA95-A649F6087039-L.j
  • johncrow and sandokan like this
#15 periklis_sale
periklis_sale
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 238 posts
  • Gender:Male
Posted 27 February 2018 - 05:16 AM
Looking good
Great craftsmanship
Posted Image
