AEROPOXY Posted January 9, 2017 Share Posted January 9, 2017 "The THING" , "Double or Nothing" , "Piper Bomber" , "Twin Piper" , lot of names for this unusual brainchild of Mr. Harold Wagner of the Wagner Aircraft Co. at Troh's Skyport, Portland, Oregon. He wanted to create a simple and cheap twin engine SUV type aircraft. This strange aircraft, nicknamed "The Thing" by Wagner himself. It consisted of a 65 hp Continental C-65 powered J-3 Cub and an 85 hp Continental C-85 powered PA-11 Cub Special fuselage mounted side-by-side using a small wing center section and central tail plane. The outer wing panels and tail planes were standard components. Later was 65 HP Continental from J-3 removed and 85 hp Continental C-85 was installed.The resulting aircraft looked so odd that Wagner called it "The Thing". The two fuselages were located closer to each other than on any other dual-fuselage aircraft. The combined horsepower would in theory support four passengers, but the increased wing loading prevented this. Hence only the right hand fuselage could be occupied by a pilot and passenger, the left hand one serving only the purpose of engine mounting.The twin Cub was first flown on December 6, 1951, after 150 flying hours it was returned to standard configuration. I do some drawings and prepare artwork for set of home printed decals and airbrushing masks, for this build. Having few of Revell Piper Cub's on shelf, this is the easy way to reduce plastic stock and build unusual and eye catching model. Closest PA-11 and J-3 version from Revell CUB offer is this one, PA-18-95 with 95 HP continental with similar nose cowlings, wings and tail ,to PA-11 model . Kit is partially started, removing some parts from sprues and preparing for assembly, hope this start up stage classifies to this group build. Fooesboy, Shawn M, Hubert Boillot and 6 others 9 Link to comment Share on other sites More sharing options...
Shawn M Posted January 9, 2017 Share Posted January 9, 2017 wow this should be cool! Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 9, 2017 Share Posted January 9, 2017 Neat! Will follow along for sure Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2017 Share Posted January 9, 2017 Interesting ! Will be following......Harv Link to comment Share on other sites More sharing options...
Fooesboy Posted January 9, 2017 Share Posted January 9, 2017 Crazy looking plane and only 150 flying hours before being backdated..... Like you said, it will give a very interesting and eyecatching model, I'm looking forward to seeing how you tackle some of the complex issuse that will no doubt crop up. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 9, 2017 Share Posted January 9, 2017 This should be a really cool build, Nenad! I must confess I'd never heard of this modification until now. Kev Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2017 Share Posted January 9, 2017 This should be a really cool build, Nenad! I must confess I'd never heard of this modification until now. Kev Nor I......Harv Link to comment Share on other sites More sharing options...
Hubert Boillot Posted January 9, 2017 Share Posted January 9, 2017 Is that a twin-engined 172 behind Mr Wagner ? Hubert Link to comment Share on other sites More sharing options...
Jack Posted January 9, 2017 Share Posted January 9, 2017 .....WT.....??!!@@#@? Link to comment Share on other sites More sharing options...
R Palimaka Posted January 9, 2017 Share Posted January 9, 2017 I wasn't sure if you were playing a practical joke on us. I thought it was photoshopped lol. I had to look it up online. This should be very interesting!! Richard Link to comment Share on other sites More sharing options...
AEROPOXY Posted January 9, 2017 Author Share Posted January 9, 2017 Is that a twin-engined 172 behind Mr Wagner ? Hubert No, its WAGNER 2 , twin engined PA 22 Colt , http://www.aerofiles.com/_wa.html Link to comment Share on other sites More sharing options...
williamj Posted January 9, 2017 Share Posted January 9, 2017 Learn something new every day..never knew this even existed... Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 10, 2017 Share Posted January 10, 2017 I'm pretty sure it's not two PA22-108 Colts, as the Colts didn't have the teardrop window. Looks like two Tripacer from the window arrangement. Never knew about this combo Peter Link to comment Share on other sites More sharing options...
Shaka HI Posted January 10, 2017 Share Posted January 10, 2017 What's this! What's this! Coolest build ever! Link to comment Share on other sites More sharing options...
geedubelyer Posted January 10, 2017 Share Posted January 10, 2017 What a fascinating aeroplane Aeropoxy. This is the first time I have seen anything like it and I will be sure to follow your progress to see how you work your magic. (I wonder if his chums called him "Wacky Wagner" back in the day?) Cheers. Shaka HI 1 Link to comment Share on other sites More sharing options...
