BloorwestSiR Posted November 13, 2016 Share Posted November 13, 2016 So, while I've been recently working on the WNW Snipe, and the Tamiya Mossie, this has also had a bit of space on my workbench. This was the kit that I did the original in box sprue said of when it first came out. I finally got around to starting on it after following Harv's night fighter WIP. I don't have a full run of photos but here's what I have. I started with the cockpit and mostly it's all OOB. Here's the seat with a bunch of scratches added to it using a Prismacolor pencil. This will probably end up being the most weathered build I've ever done (besides the Millennium Falcon). Here's the cockpit sidewalls. I used mid bronze green for the colour. Harold and Uncarina 2 Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2016 Share Posted November 13, 2016 Looking good buddy !!.......Harv Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 13, 2016 Author Share Posted November 13, 2016 Here's most of the cockpit tub assembled. At this point, I noticed that I misplaced one of the tanks in the cockpit. I ended up using one from the Aires set for the Trumpeter F4U as a substitute. From the other side: I then started work on the seat. I replaced the kit belts with ones from Wako. They're Japanese and have some great instructions to them. They lay out the buckles on the get si that the can be threaded into the belts before you remove them. Their only downside is that you have to paint them and for some reason, the buckles are laser cut plastic instead of PE. madmusky, Uncarina, TenSeven and 5 others 8 Link to comment Share on other sites More sharing options...
Martinnfb Posted November 13, 2016 Share Posted November 13, 2016 Lovely detail and shading, thumbs up Link to comment Share on other sites More sharing options...
Shaka HI Posted November 13, 2016 Share Posted November 13, 2016 Nice Carl...this one looks to be weathered more than usual with your builds. Looking forward to it. Link to comment Share on other sites More sharing options...
D.B. Andrus Posted November 13, 2016 Share Posted November 13, 2016 (edited) Great work, Shaka Bloorwest! (Sorry, got carried away.) Just ordered some of those seat belts from HLJ. Cheers, D.B. Edited November 13, 2016 by D.B. Andrus mistaken identity Shaka HI 1 Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2016 Share Posted November 13, 2016 Coming along nicely! Link to comment Share on other sites More sharing options...
shark64 Posted November 14, 2016 Share Posted November 14, 2016 lovely cockpit work Link to comment Share on other sites More sharing options...
Uncarina Posted November 14, 2016 Share Posted November 14, 2016 Carl, Some great work! What did you use to paint the bronze green and the salmon color I caught a glimpse of? Cheers, Tom Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 Lovely detail and shading, thumbs up Thanks Martin! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 Nice Carl...this one looks to be weathered more than usual with your builds. Looking forward to it. Thanks Shaka! It certainly is much more weathered than I'm accustomed to doing in a build but that reflects the aircraft I'm planning to build. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 Great work, Shaka Bloorwest! (Sorry, got carried away.) Just ordered some of those seat belts from HLJ. Cheers, D.B. Thanks D.B.! Wako make two versions of their belts. Both with fine but I prefer the slightly more expensive version. The difference I think is the basic version uses paper for the buckles so they're slightly more fragile while the deluxe version use plastic. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 Coming along nicely! Thanks John! I'm glad to see you dropping in. I don't think I'll be getting it together as quickly as you do. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 lovely cockpit work Thank shark! I'm happy with the way it turned out. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 14, 2016 Author Share Posted November 14, 2016 Carl, Some great work! What did you use to paint the bronze green and the salmon color I caught a glimpse of? Cheers, Tom Thanks Tom! For the green, I used Xtracrylix Mid Bronze Green. I then added a drop of white and sprayed in between the ribs for a bit of a weathered look. The salmon colour I mixed up using the guide in the instructions. Here's a better shot of it. Mal_Belford and Uncarina 2 Link to comment Share on other sites More sharing options...
