Tamy F4U-2N build
  • Please log in to reply
1204 replies to this topic
#31 harvey
harvey
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 19,431 posts
  • Gender:Male
Posted 03 May 2016 - 03:01 AM
Thanks Bill. It's looking like that this might the only option I'll have. I have lots of time....Harv
  • mpk likes this
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#32 LSP_Paul
LSP_Paul
    Senior Member
  • LSP Moderator
  • 5,586 posts
  • Gender:Male
Posted 03 May 2016 - 03:05 AM
Rather than trying to deform it to fit the wing, I'd go with filling and blending.
Plus One. Just make sure you have it where you want it and then well set with CA  After that, use your favorite modeling epoxy ( milliput etc) to blend it in. You could try using a small rat tail file and see if you can't improve the fit to at least the top of the wing, then most of your filler will be on the bottom surface.
 Paul
  • Bill_S, harvey, David66 and 1 other like this
#33 harvey
harvey
    Senior Member
  • LSP_Members
  • 19,431 posts
  • Gender:Male
Posted 03 May 2016 - 03:07 AM
Sounds like a good option Paul. Thanks buddy....harv
  • mpk likes this
#34 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 10,149 posts
  • Gender:Male
Posted 03 May 2016 - 03:54 AM
I'll be watching with interest   :)
Two_VF-10_pilots_on_USS_Enterprise_(CV-6
Edited by Martinnfb, 03 May 2016 - 04:07 AM.
  • Jack, Lothar, harvey and 2 others like this
In progress:   D-13 ; Ta-152V7 ; Mig-29 ; EMIL ; P-39 Аэрокобра ; Avia S-199 ; K-14 what if
Done:            F-8 F-8 Wurger Party ; D-9 ; D-15; Ta-152E ; P-40E
#35 airscale
airscale
    Senior Member
  • LSP Sponsors
  • 1,872 posts
  • Gender:Male
Posted 03 May 2016 - 06:59 AM
great choice Harv...
looking forward to being one of your passengers :)
Peter
  • harvey and mpk like this
airscale donates a % of sales to the Royal Air Force Association to remember 'the few' RAFA
#36 bdthoresen
bdthoresen
    Senior Member
  • LSP_Members
  • 1,823 posts
  • Gender:Male
Posted 03 May 2016 - 09:42 AM
Hey Harv- Great subject choice. Rather than try to alter the shape of the pod or wing, I also think you might try some Milliput Superfine white, and blend the radome in. Trace its' location on the assembled wing, mix up a small amount of Milliput, and roll it out flat on the tracing. Press your radome into it, so that you can then use a small spatula to sculpt the Milliput exactly to the edge of your radome. Use a wet tool or finger to blend the seam. You would then only need to lightly sand/polish the join.....Easy fix!
Looking forward to your work....
THOR    :ninja:
  • harvey, David66, quang and 1 other like this
Is the enemy of my enemy my friend?; or just another a**hole?
#37 David Hansen
David Hansen
    Senior Member
  • LSP_Members
  • 929 posts
  • Gender:Male
Posted 03 May 2016 - 03:18 PM
Harv, what i did on mine was, first i laminated a piece of .010 to the inside surface of the part that went under the wings, then cleaned and sanded that up along the edges as best i could, to try to reduce the magnitude of the "gap".
Then i wrapped a piece of clear, shiny package wrapping tape (you know, the stuff that drives you crazy when you try to peel it off the roll) around the leading edge where the radome went (its clear so you can see where the radome is in relation to panel lines, etc). After that i tack glued the radome in position with just enough glue to locate its position.
Then, i started adding thick super glue (it took a LOT, BTW) around the gap to start closing it up. You might want to try one or two iterations with accelerator to sort of create a "back stop" so the super glue won't seem to be draining into a black hole indefinitely. Once i got the gap filled, i left it to set up overnite.
The next morning, i applied side loads to the radome and "cracked" it off the leading edge of the wing, taking the tape with it. It left the kit wing pretty much untouched. I then primed the radome where all the super glue was and started sanding away the excess superglue. When the primer was gone, i knew i had a smooth-sided radome.
Then i went back and test fitted the radome again. At this point, any remaining gaps could be filled with Mr Surfacer. Then it was just a matter of fixing all the OTHER shape irregularities in that @#$**!?? thing.
Anyway that's how I did it. Your mileage may vary.
-d-
  • harvey, dutik, David66 and 1 other like this
#38 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 6,266 posts
  • Gender:Male
Posted 03 May 2016 - 06:17 PM
i'll be here for this one too!
  • mpk likes this
I dont suffer from AMS, I revell in it..get it...Revell
#39 harvey
harvey
    Senior Member
  • LSP_Members
  • 19,431 posts
  • Gender:Male
Posted 06 May 2016 - 11:06 PM
First work done. Not much, a start on some interior paint. BTW, it took ALL day to load this pic to PB !.........Harv
  • SciFi58, Uncarina, dutik and 5 others like this
#40 Uncarina
Uncarina
    Senior Member
  • LSP_Members
  • 3,176 posts
  • Gender:Male
Posted 07 May 2016 - 02:41 PM
Harv,
Looking like a great start to this amazing aircraft!
Cheers, Tom
#41 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 25,110 posts
  • Gender:Male
Posted 07 May 2016 - 07:17 PM
Harv
You're off and running and that's all that counts. Slow but steady and enjoy the journey.
I'll be there all the way
Peter
#42 dutik
dutik
    Senior Member
  • LSP_Members
  • 2,806 posts
  • Gender:Male
Posted 07 May 2016 - 08:05 PM
Watching you! :ninja:
:D
- dutik
#43 shark64
shark64
    Senior Member
  • LSP_Members
  • 2,834 posts
  • Gender:Male
Posted 07 May 2016 - 09:07 PM
let the magic begin..
#44 harvey
harvey
    Senior Member
  • LSP_Members
  • 19,431 posts
  • Gender:Male
Posted 07 May 2016 - 09:20 PM
Thanks to all of you!.....Harv
  • mpk likes this
#45 Bill_S
Bill_S
    Senior Member
  • LSP_Members
  • 2,626 posts
Posted 07 May 2016 - 09:45 PM
Go, Harv, Go!
I started building my shelf of doom, but I never finished it.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
