Gazzas Posted May 6, 2018 Author Share Posted May 6, 2018 Karimb, Thank you so much! I've worked really diligently to scrape paint from between parts, and the fuselage does close up quite snugly once I give a few of the parts a little prod to make them drop into their allotted slot. Gaz Link to comment Share on other sites More sharing options...
Gazzas Posted May 12, 2018 Author Share Posted May 12, 2018 Hi everyone, Less progress than hoped for this week. I meant to be painting but found some seams needed neatening. Today I did a lot of masking... Most of it for pre-shading: I also did the prop and axle fairing. Think I got one layer too many on the laminated prop. Don't think I'll redo it though. Thanks for looking! Gaz Uncarina, CANicoll, Michael Scarborough and 4 others 7 Link to comment Share on other sites More sharing options...
Kagemusha Posted May 12, 2018 Share Posted May 12, 2018 The prop looks superb. Gazzas and CANicoll 2 Link to comment Share on other sites More sharing options...
Robthepom Posted May 12, 2018 Share Posted May 12, 2018 love the cockpit gaz, and the prop and wheel plate graining look very realistic Gazzas 1 Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2018 Share Posted May 12, 2018 Yes sir, looking good. Your making me want to pull out another Wingnut kit. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 12, 2018 Share Posted May 12, 2018 (edited) Gaz Super progress and looking mighty good. Don't be so hard on yourself as the Albatross looks great. LNice work on the prop lamination's and color. I did go back and count the laminations and you're right, left to right: isn't the same but unkess it is aggrivating your to the point of loosing sleep, I would leave it as is Keep 'em comin Peter Edited May 12, 2018 by Peterpools Link to comment Share on other sites More sharing options...
MikeMaben Posted May 12, 2018 Share Posted May 12, 2018 Think I got one layer too many on the laminated prop. Oh man that's just awful ! First thing I do is count the layers in the prop. Michael Scarborough and Gazzas 2 Link to comment Share on other sites More sharing options...
Gazzas Posted May 13, 2018 Author Share Posted May 13, 2018 Guys, Thank you so much for the encouragement! Yes sir, looking good. Your making me want to pull out another Wingnut kit. Currently I seem to be having a bit of WWI LSP's on the brain. I have two Roden and two more WNW in the stash awaiting. I fear WnW will be my undoing. Gaz Super progress and looking mighty good. Don't be so hard on yourself as the Albatross looks great. LNice work on the prop lamination's and color. I did go back and count the laminations and you're right, left to right: isn't the same but unkess it is aggrivating your to the point of loosing sleep, I would leave it as is Keep 'em comin Peter Thank you Peter! I find that quite often it's best just to move on. I have plenty of spare props, and the kit is not specific about which to use... so I may do another one yet. Oh man that's just awful ! First thing I do is count the layers in the prop. Heh... every man has his poison! Michael Scarborough and MikeMaben 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 13, 2018 Share Posted May 13, 2018 Gaz Absolutely the right move Peter Link to comment Share on other sites More sharing options...
Gazzas Posted May 13, 2018 Author Share Posted May 13, 2018 Gaz Absolutely the right move Peter I'm still at the point where I want to develop a routine way of doing it. On this occasion I used my Silhouette Portrait to cut ovals for masks. However, I needed to make a five-ovals pattern but instead made a four-ovals pattern. So, I used a spare 4-oval-pattern set and a pair of scissors, to make up for the lack, and it didn't come out as intended. Gaz Michael Scarborough and CANicoll 2 Link to comment Share on other sites More sharing options...
Gazzas Posted May 15, 2018 Author Share Posted May 15, 2018 HI again everyone, I got to spend a lot of today at the paint booth (my verandah). Not only did I do some work on this Albatros, I got to spend some quality time with the Tamiya 109. I've decided to forego conventional wisdom and do my pre-shading for the lighter colors with darker shades of their intended colors. Just one pic to show it all: For the Jasta 5 green tail I used black because the intended shade of green is pretty dark. Worst comes to worst, a little Simple Green and a toothbrush will remove the black acrylic without harming the Tamiya white rattle-can primer. In the center of the fuselage is the only topcoat so far. It's just a gray band that will be covered by the pilots Wappen. Yesterday I learned that the aerofoil that covers the axle for the LG should have a panel line in the center. So...I've stripped it and the propeller of paint for a redo. Cheers, Gaz Michael Scarborough, MikeMaben, CANicoll and 1 other 4 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted May 15, 2018 Share Posted May 15, 2018 Gaz, You're doing great work on the Albie. Well done! Bring on those updates Von B Gazzas and Michael Scarborough 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 15, 2018 Share Posted May 15, 2018 (edited) Gaz Looking good and looking forward to seeing the paint work after the masking is removed Keep ‘em comin Peter Edited May 15, 2018 by Peterpools Link to comment Share on other sites More sharing options...
MikeMaben Posted May 15, 2018 Share Posted May 15, 2018 I've decided to forego conventional wisdom Michael Scarborough 1 Link to comment Share on other sites More sharing options...
TorbenD Posted May 15, 2018 Share Posted May 15, 2018 Looking good Gaz - I think pre-shading in the colours may help keep things nice and vibrant. Torben Link to comment Share on other sites More sharing options...
