Gazzas Posted May 27, 2018 Author Share Posted May 27, 2018 Hi everyone, Been putting on the decals on the Tamiya kit. The only plastic parts not yet on the kit are the MG-131 barrels. Here are some photos: My first semi-successful spinner decal. These decals are thinner than older Tamiya decals. They tend to sink in nicely but are thick enough where you get some second chances when you mess up. You'll notice the white primer showing on the edges. This is where paint has come off through handling. Of course... touch up will be required. There are a lot more stencils I could/should add. But they are tiny little things that I don't think will add much to the build. After touch up painting, I'll seal the decals, and work on the weathering. Looking forward to try to make the difference between RLM74 and RLM75 more pronounced. My best mate: She has a tendency to try to bathe me when I'm on hands and knees looking for a lost part. Cheers, Gaz SCRATCH BUILDER, Javlin1, mustang1989 and 7 others 8 2 Link to comment Share on other sites More sharing options...
mustang1989 Posted June 4, 2018 Share Posted June 4, 2018 (edited) Been out of commission for the past month and man did I miss ALOT!!! Those decals look fantastic Gazz!!!! Looks great bud. Edited June 4, 2018 by mustang1989 Gazzas 1 Link to comment Share on other sites More sharing options...
Gazzas Posted June 5, 2018 Author Share Posted June 5, 2018 Thanks, Joe! Glad to have you back! Gaz mustang1989 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 5, 2018 Share Posted June 5, 2018 Gaz Aces on a beautiful build and the cammo work looks simply stellar Peter Link to comment Share on other sites More sharing options...
Gazzas Posted June 5, 2018 Author Share Posted June 5, 2018 Thank you Peter. I've a fair bit of paint modulation and fading...and oil streaking and... but it's all on hold. I have a group build on another forum to complete and the days are winding down. Gaz Link to comment Share on other sites More sharing options...
Gazzas Posted June 28, 2018 Author Share Posted June 28, 2018 Hi Everyone, It's been a while since I got anything done on this comparison, but I'm back at it after the arrival of the Eduard wings. After attaching the wings, I added the already painted LG Legs. After letting them set over night I checked them the next morning. The starboard wingtip was higher than the port. A visual check showed that one had moved a fraction. Then I moved to the forward edge slats and the flaps and radiators. I'm not certain what the actual dihedral of the 109 wing should be. To change the position of any of the Eduard control surfaces, simply cut off the tabs and glue. Thanks for looking! Gaz mustang1989, Kahunaminor, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
Kahunaminor Posted June 28, 2018 Share Posted June 28, 2018 Good to see you back in the saddle on these mate. Regards, Gazzas 1 Link to comment Share on other sites More sharing options...
mattlow Posted July 2, 2018 Share Posted July 2, 2018 (edited) Gaz Nice work. I used Gunze acrylics on my Eduard 109G-14. I did' however lighten them up quite a bit to give some scale effect. I had noted quite low contrast between the tone of the RLM 76 and the RLM 75, so tried to replicate that.. I freehanded this camo and it was a bit daunting. I have just a couple of evenings ago used blue tack (version of) to do some hard edged camo on a 1/32 Hunter F-5. It was abit of a revelation. Much easier to lay out and adjust and with a small tip and lowish pressure I didn't need any masking between the sausages of tack. I think it'll be my masking friend of choice (I'm a bit late to this party - but I had reservations about residue). One thing is that I took the masking off immediately I had finished spraying, so it was only in place for 45mins - 1 hour. I'd recommend it as a way to get the 'soft hard edge' of Luft camo, especially in the smaller scales. For mottling I think a good 0.2 needle and lots of practice cannot be beaten. Yours looks good, but getting the hang of the airbrush is THE way to go and once you have a go at it (use your paint mule) you'll find it isn't actually that hard. The other thing is that I used black Stynylrez as my primer - so a sort of 'black basing' which I think works really well for Luft aircraft and if top coat does wear down a bit isn't as obvious as white.. Matt Edited July 2, 2018 by mattlow LSP_Kevin, Gazzas and mustang1989 3 Link to comment Share on other sites More sharing options...
Gazzas Posted July 6, 2018 Author Share Posted July 6, 2018 Thanks for the tips, Matt. Your G-14 looks excellent! Gaz Link to comment Share on other sites More sharing options...
mattlow Posted July 6, 2018 Share Posted July 6, 2018 Thanks Gaz Last night at our club meeting I was overwhelmingly advised that 'white tack' leaves no grease marks... I suppose that is useful if you're likely to leave the stuff in place for any length of time. I shall try to track some down. Matt Gazzas 1 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 10, 2018 Share Posted July 10, 2018 Learning some good times from Matt and still enjoying the progress here. It's amazing how much difference there is between these two kits. Gazzas 1 Link to comment Share on other sites More sharing options...
Eagle Driver Posted July 24, 2018 Share Posted July 24, 2018 I am bracing for a long and trustworthy conclusion. This will be very useful. mustang1989 1 Link to comment Share on other sites More sharing options...
Gazzas Posted August 20, 2018 Author Share Posted August 20, 2018 Hello Everyone, I've finally finished the build and the comparison. Both kits have a lot to offer and are worthy of anybody's time or effort. It just depends on what you want, really. The Eduard kit is the winner when it comes to surface detail. The Tamiya kit the winner if you want it to have all of the correct angles without the use of a protractor. I didn't use a protractor, so the Eduard sits taller than the Tamiya. The Tamiya decals are nice. Nicer than Tamiya decals were a few years ago. Most of the Eduard decals are nice. A few of the smaller stencils have a white border around them. You'll see them on the top cowling and the tail lifting points of the Eduard which carries Barkhorn's markings. The Tamiya kit was more expensive. But once you get the detail sets for the Eduard, the prices come closer. I enjoyed assembling the Tamiya kit more than the Eduard. It seemed more fun and less labor intensive. That's my two cents on the comparison. Here are the final photos: The Spinner of the Eduard kit appears a bit beefier than the Tamiya kit. They are nose-to-nose here. All parts of the G6's being equal, Eduard has a huge lead in variants in production. Will Tamiya pump out a G-5 or G-14? Will Tamiya make Erla variants? Who can say. Thanks you for looking. I hope you've enjoyed this build log. Gaz TorbenD, CANicoll, mustang1989 and 7 others 10 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 20, 2018 Share Posted August 20, 2018 Great stuff buddy. Always good to see a build of such quality. I have the Tamiya in the stash but still an Eduard devotee until then. Regards, Gazzas 1 Link to comment Share on other sites More sharing options...
mustang1989 Posted August 20, 2018 Share Posted August 20, 2018 Man oh man oh man! I've half a mind to purchase the Tamiya kit after watching this thread. I really appreciate you taking the time to share all of these insights and knowledge. Great work on both of these modern art masterpieces Gazz. You da man. Rockie Yarwood and Gazzas 1 1 Link to comment Share on other sites More sharing options...
