jumpjack Posted June 18, 2018 Share Posted June 18, 2018 I think the wings and undercarriage were common across all 3 (?) engine variants bar the later addition of air brakes. Fuselage and tail alterations were quite another matter. Link to comment Share on other sites More sharing options...
alain11 Posted February 1, 2021 Share Posted February 1, 2021 hi I am tempted by the Tigger Wyvern , so , what about your promising build ???? it would be great to see how it turns Alain Link to comment Share on other sites More sharing options...
Nic C.D. Posted February 4, 2021 Author Share Posted February 4, 2021 Hi Alain, I did a little more work on the Wyvern, but when it was announced - I believe by HPH Models - that they are working to release a 1/32 scale kit of the aircraft in resin or injection, I lost a little motivation... I'm not sure where they are with the development with the kit though, so I might pick up the kit again. If you are tempted by the Tigger kit: go for it! The basic forms are pretty good and the plastic is thick, which is really comfortable to work with. I've got other vacuformed kits with very thin plastic and those are a pain. The plastic is sometimes so thin that you go right through it when you try to engrave it... The Tigger kit is a good one! I also have the Sea Vixen, not an easy one, but like the Wyvern: a good basis! Nic alain11, Uncarina and Starfighter 2 1 Link to comment Share on other sites More sharing options...
alain11 Posted February 4, 2021 Share Posted February 4, 2021 hi Nic thank you for your reply !!!! As you said , HpH , or Infinity planed to produce the Wivern in resin or injected plastic , there was a discussion about this 3 years ago now .... wait and see !!! ?? , in fact , I am tempted by the Wivern ( for years now ) , but the vacu kit tempts me too , I never had this experience , so it's time to cope with it , and too bad if the build goes wrong , I would have learned something .........................let's go !! Alain Uncarina 1 Link to comment Share on other sites More sharing options...
