TaffyMan Posted January 30, 2012 Author Share Posted January 30, 2012 Nice work The PE realy does add to the finesse. This will look very nice when finished. Matt Cheers Matt The PE does help with detail but I am surprised that the set doesn't do anything with the gun just the truck!!!! Shame could do with some. Taff Well that is coming along quite nicely... Engine looks impressive and NEAT . Yeah nice engine hid away underneath How goes this?? Hi Mike sorry was meant do an update last week but work has kicked off so didn't find time to get to it - I will make amends this week He's certainly doing a great job of it so far. Thanks Kev Am enjoying chasing all these fiddly bits that I have pinged around the room only lost one so far to the carpet monster. Also am loving the Den Fighters some cool stuff Thanks for looking in and happy modeling - Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted January 30, 2012 Author Share Posted January 30, 2012 Hi guys I have been slowly ticking away at this for the last two weeks. Work has been real busy so getting in the way of model time. So on to my progress. I went back and revisited the chain and holders. I managed to get the loops a bit more even plus put some electric insulator to make a false nut. I think take two looks a lot better. With this redone I thought I would try a dry fit of the cabin and the flat back. The back sat down okay. Not the same for the cabin. Somehow the radiator wouldn’t fit into the recess properly. It is even worse when you put the cabin front on, which just would not sit on! This side view shows the gap under the front mudguard. Uhm! Right got bored of looking and trying to work out this so will revisit later! So went and primed the bits ready for some painting. After a coat of Humbrol 63 Sand I got down to doing some weathering. I started with the cabin with a bit of rubbing back to the underlying aluminium colour. I then rubbed in a bit of powdered graphite, to make it look more worn steel. Then it was to make some sand. I started with underside of the front mudguards. You can also see where the radiator has pushed the PE panel out of shape. Um that problem again I think the answer will be to take the radiator of the chassis and fit it into the cabin I will test this! Then stared to give the inside some treatment and a bit of a work over. Also you can see here I have put the dash on and a bit of Maskol to protect the dials. Okay think I am at the picture limit so will be back in a mo! Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted January 31, 2012 Author Share Posted January 31, 2012 Back with some more The winch was next. I first removed the plastic wire from the hook and after a bit of a tidy before drilling a hole. Then I made some wire from thread. This was painted with silver 11. Then just before it was fully dry I rolled it to make sure there are no hairy bits. I then gave it a bit of dry brush with gunmetal then a mix of dark brown and flat black. This was then threaded on to the hook then carefully wound around and stuck to the winch. After removing the radiator everything is now sitting down properly. So that is how I will do the final fit and stick the rad into the cabin. Why this problem I have no idea but hay onwards! Okay somehow I managed to stick one of the door handles on upside Doh – this I very carefully removed with a scalpel and cleaned up the area then stuck it back down in the correct place I have had a look around and there isn’t much pictures or info about these vehicles. Some of the info I have found is an equipment list and placement. This shows a fire extinguisher in the passenger foot well, so I have attempted to make one of these and the holder. My scratchy effort Bit of paint and placed in the foot well. Looks okay to me? Bit more PE added to all the ammo boxes. Also I have been working in Illustrator on some homemade decals for this vehicle and the troops. I have run these out on to decal paper today but had the printer set to too much ink so it’s blurred a bit! So I will need to get some more paper and redo. Typical that was my last piece. This is the artwork. Hope to show you the finished item in my next update. Till then happy modelling and thanks for looking in. Any comments or pointers always welcome. Happy Days - Taff Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 31, 2012 Share Posted January 31, 2012 Awesome work Taff! Kev Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 31, 2012 Share Posted January 31, 2012 I do build the odd target from time to time so I find this an interesting build A question out of curiosity, would ammo boxes in the field really have pad locks? they look neat, just wondering if they would have been used (and truly not knowing either way). I like your weathering, very convincing. Ron Link to comment Share on other sites More sharing options...
TaffyMan Posted January 31, 2012 Author Share Posted January 31, 2012 Awesome work Taff! Kev Thanks for looking in Kev and the encouragement - long way to go yet Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted February 1, 2012 Author Share Posted February 1, 2012 I do build the odd target from time to time so I find this an interesting build Ron I got some strange looks at work as I laughed - spoke like a true airman!!!! Yep I thought the same about the padlocks - "Imagine the scene - as the German tank came over the ridge - I thought you had the keys!!!!" But it is what the instructions say and I couldn't find much photo reference and they add a bit of interest. The kit speck I found says there should be three or four portable ammo bins on the flat bed. The kit only comes with one so I will have to see if my scratchiness is up to trying to make the others. So I think these other ones are for storage and carriage. Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted February 1, 2012 Author Share Posted February 1, 2012 Taffyman EXCEPTIONAL work..It is quite AMAZING Watching this build.. Moving along at a quick pace and enjoyable too. Thanks you for such a treat Keep up the good work. MARU Cheers Maru Thanks for looking in and the encouragement - I am stretching myself here so I am glad you like it. Happy Days - Taff Link to comment Share on other sites More sharing options...
Tomek Posted February 2, 2012 Share Posted February 2, 2012 I haven't check on your build for a while It's coming along very nicely, Taffy! Question, what did you use for the mud texture as seen on the underside of the front mudguards? Looks very nice. Link to comment Share on other sites More sharing options...
Guest Posted February 2, 2012 Share Posted February 2, 2012 My god, what good work. Looks just phenomenal!........Harv Link to comment Share on other sites More sharing options...
TaffyMan Posted February 3, 2012 Author Share Posted February 3, 2012 I haven't check on your build for a while It's coming along very nicely, Taffy! Question, what did you use for the mud texture as seen on the underside of the front mudguards? Looks very nice. Hi mate - The sand stuff is a thing I am making up as I go along. If there is a better way Most probably is! This is how I make my muck - first rub with much vigor and finger aching some sprue on sand paper of different grades or files. I then collect the dust, for dry mud I mix with some flat coat some Dark and Light Mig pigment and ground coloured chalks. For runny mud some liquid glue helps make it really gloppy, but be careful as this a harsh mix! Then apply to the area - Tell you what!!! - rather than write this out when I do the chassis at the weekend I will take some pictures that should explain it better than my ramblings. Not the best answer but hope the future pictures will be a better answer. Happy Days - Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted February 3, 2012 Author Share Posted February 3, 2012 My god, what good work. Looks just phenomenal!........Harv Cheers Harvey - Glad you are enjoying the trip. I just hope I can deliver whats in my minds eye? Still got a long way to go. Happy Days - Taff Link to comment Share on other sites More sharing options...
LSP_Mike Posted February 4, 2012 Share Posted February 4, 2012 Taffy, thanks for the update, your truck is coming along just fine. Link to comment Share on other sites More sharing options...
TaffyMan Posted February 13, 2012 Author Share Posted February 13, 2012 Hi Folks Thanks for looking in Mike I want to try and put some canvas cover on this. So in searching out how too I found this guy on the tinter-web. Making Realistic Tarps By Brian Balkwill http://www.militarymodelling.com/news/article.asp?a=3310 Looked pretty cool to me so I thought I would give it a go!?? I tried the bathroom sealant I had in the garage and non of them would break down in water – or I am doing something wrong – my moneys is on this – So I thought I would try it with Builders Caulk, this mixes really easily with water. I tried to do this on to flat piece of paper as he did but just ended up in a mess. I then tried it on a sheet of picture glass – this seemed to work a lot better. After the hair dryer treatment – it seems to workout might not be a robust as his with the bathroom sealant, will try and get some of this and redo it. I made two sheets should be enough! It took the paint okay and this is picture of the rolled ground sheet on the front. With the roll and some other bits done for the back meant it was the coming together of lots of bits and hopefully she will start to look a bit more lorry looking. I made the windscreen up plus also made the wiper motors out of some scrap. Then all the bars and metal shield where stuck together and glued into place. She has a face My be not the prettiest!!! Think I am at the Picture limit so will be back in a mo! Taff Link to comment Share on other sites More sharing options...
TaffyMan Posted February 13, 2012 Author Share Posted February 13, 2012 Okay back after the short brake I did a bit more work in the cabin area and some more dirt applied. Next put the homemade decals on the water cans closed these up stuck them into place. Then with all the lower Ammo Boxes in place and both the cabin and flat bed stuck down – She is know a bit more like a Truck!!!! Whilst I waited for these to set I started on some more detailed work with the Bren Guns. The kit gun didn’t come with the front legs so this is my effort at a scratched version. I also made the straps out of tape and some thin wire. Need a bit of colour and should look okay! I'l finish with a quick tour of her. I will be next getting some muck out to dirty up the lower parts and some decals before finishing the back. Till next time I hope you enjoyed and any comments, hints and tips always welcome Happy Days Taff Link to comment Share on other sites More sharing options...
