shark64 Posted June 18, 2018 Share Posted June 18, 2018 Looking good.. Link to comment Share on other sites More sharing options...
Dandiego Posted July 1, 2018 Author Share Posted July 1, 2018 (edited) The bump in the road has been smoothed out. I decided that the nose gear was too long , so I shortened it. Plus it broke where the wheel fork joins the strut. So while I sorted this out I continued work by adding wheel doors and Sidewinder rails. And the Navpac....and if you look closely the 20mm cannon barrels. Thanks, Dan Edited July 1, 2018 by Dandiego MikeMaben, Rocat, Out2gtcha and 3 others 6 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 1, 2018 Share Posted July 1, 2018 Excellent work Dan! Can't wait to see this thing in Phoenix Dandiego 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 1, 2018 Share Posted July 1, 2018 Nice work, Dan! I see what you are talking about re nose gear. It seems odd the main gear torque links show a lot of weight on them, or compressed, but the nose gear has them with nearly no weight on them, practically full out. Seems odd. Dandiego 1 Link to comment Share on other sites More sharing options...
Timmy! Posted July 3, 2018 Share Posted July 3, 2018 (edited) Dan great work! I just happen to know the designer of the landing gear...I know him equally well as he knows himself actually. The gear were designed to their nominal strut extension. It looks like your gear is mounted in the right place. I'm looking at how much of the gear structure is revealed, relative to the fuselage surfaces. Also, there was a lot of travel in the shock struts, I've noticed the jet sits at a range of angles. Presumably, because of variable ramp weights, strut servicing and temperature. Bottom line adjust as you see fit, the most accurate way by adjusting the struts...maybe not the easiest way. Good luck! Looking forward to more. Timmy! Nice work, Dan! I see what you are talking about re nose gear. It seems odd the main gear torque links show a lot of weight on them, or compressed, but the nose gear has them with nearly no weight on them, practically full out. Seems odd. Ray, Long nose gear was very common in early Naval jets. Angle of attack was everything to get these jets on and off the ground/carrier, given the limited engine power, and wing design of the time. Catapult power too. British Navy F-4 Phantoms for example. The nose gear was modified to extend further than other F-4 variants, to work with the smaller British carriers. It has a double scissor link to accommodate the extra extension of the strut. Not odd, by design, but yes it does look a bit funky I'll give you that! BTW, the Skyray has a wheel as part of the arresting hook assembly, because the tail was regularly on the ground. Cheers, Timmy! Edited July 3, 2018 by Timmy! Dandiego, Hubert Boillot and sandokan 3 Link to comment Share on other sites More sharing options...
Dandiego Posted July 3, 2018 Author Share Posted July 3, 2018 Thanks for the comments Tim. The main gear I thought was correct all along. I took great care to install them correctly. But when placed on its wheels it looked quite nose high. I realize that the "stance" will change due to load. I looked at many photos and have shortened the nose gear to get the "stance" normally seen. What it comes down to in the end is personal preference. I think it looks better with the shorter nose gear. Either way could work. Dan Timmy! and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 4, 2018 Share Posted July 4, 2018 Dan Nice progress on the undersides and hoping the nose gear repair will go well. Keep 'em comin Peter Link to comment Share on other sites More sharing options...
Dandiego Posted July 7, 2018 Author Share Posted July 7, 2018 Hey all, I had some issues with the main canopy. I sent an email to Paul and 3 days later I had a new one. Thank you Paul! Home stretch now. Just get the canopy painted and installed and install the stores and the Ford will be done. Dan Out2gtcha 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 7, 2018 Share Posted July 7, 2018 Paul's customer service in incredible and he is always there for help and guidance Peter Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 7, 2018 Share Posted July 7, 2018 Looking forward to seeing the Ford at Phoenix Dan! Link to comment Share on other sites More sharing options...
shark64 Posted July 7, 2018 Share Posted July 7, 2018 Super cool. I cant wait to see it. next stop is Phoenix....how about OrangeCON? Link to comment Share on other sites More sharing options...
Dandiego Posted July 8, 2018 Author Share Posted July 8, 2018 5 hours ago, shark64 said: Super cool. I cant wait to see it. next stop is Phoenix....how about OrangeCON? Can't wait to see it in Phoenix as well. That would mean that I finished it and that I survived the drive out. Dan Link to comment Share on other sites More sharing options...
Dandiego Posted July 15, 2018 Author Share Posted July 15, 2018 (edited) Getting close to being done. Today glued on the remaining underwing stores. And some paint work on the canopy. Dan Edited July 15, 2018 by Dandiego blackbetty, LSP_Kevin, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Posted July 15, 2018 Share Posted July 15, 2018 Beautiful! See you in Phoenix!!.....Harv Link to comment Share on other sites More sharing options...
Dandiego Posted July 31, 2018 Author Share Posted July 31, 2018 The end. A few photos of the canopy... And the Ford is finished. Thanks everyone for your comments in the last 4 months. This is a terrific subject and a wonderful kit from Fisher Models. It is a shame that more are not being built. Dan LSP_Kevin, Hubert Boillot, johncrow and 8 others 11 Link to comment Share on other sites More sharing options...
