G-Man Posted June 4, 2018 Share Posted June 4, 2018 What putty are you guys using for camo masking? I use Gunze Mr. Color paint, but I've heard some putty brands like Blu Tack will stain the paint. Link to comment Share on other sites More sharing options...
1to1scale Posted June 4, 2018 Share Posted June 4, 2018 I used the "white tack", never had an issue, but I use acrylic paint. CANicoll and Tomjw 1 1 Link to comment Share on other sites More sharing options...
CANicoll Posted June 4, 2018 Share Posted June 4, 2018 Ditto, I use 'Scotch Removable Mounting Putty'. Don't use it on a matte surface, go for a gloss or satin. Had similar problems to you with the Blue Tac - left a residue behind. I have some Play-Doh but have not actually used it yet. I may still on my latest build. If I do, I will let you know how it turns out... Link to comment Share on other sites More sharing options...
Guest Maxim Posted June 4, 2018 Share Posted June 4, 2018 White tack, Blue tack. Same here never an issue. If it leaves small pieces behind you just use another piece of tack to pick it up. Link to comment Share on other sites More sharing options...
G-Man Posted June 5, 2018 Author Share Posted June 5, 2018 Hmmm, at my work, we have foam tape that prevents hard edges. It's rather thick though, as it's for cars. It's a wonder no model company hasn't scaled it down. Link to comment Share on other sites More sharing options...
ChuckD Posted June 5, 2018 Share Posted June 5, 2018 I use silly putty. Works perfectly. Dragon 1 Link to comment Share on other sites More sharing options...
Dragon Posted June 5, 2018 Share Posted June 5, 2018 I use silly putty. Works perfectly. +1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 5, 2018 Share Posted June 5, 2018 For the worm method I use eith blue, gray or white tack and now Mr Color and MRP paints with no problems ans no staining. Peter Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 5, 2018 Share Posted June 5, 2018 White tack, Blue tack. Same here never an issue. If it leaves small pieces behind you just use another piece of tack to pick it up. Same same here, with never an issue staining. The theory with the blue tack is that generally whatever color it is, the tack will stick to itself way better than most any other surface. Maxim right, just use another piece of tack, to pick up any parts or bits of the tack left behind from masking. Works a treat. Link to comment Share on other sites More sharing options...
Gerhard Posted June 5, 2018 Share Posted June 5, 2018 For the worm method I use eith blue, gray or white tack and now Mr Color and MRP paints with no problems ans no staining. Peter I use a white putty called Prestik over here. Link to comment Share on other sites More sharing options...
