monthebiff Posted April 29, 2018 Share Posted April 29, 2018 (edited) So, with a couple of full on conversions on the go and not completing a build in the last year I decided to start on this one and just enjoy a simple OOB build. First up is the lower fuselage frame which is made up just three pieces! Huge amounts of flash on the outer fuselage frames to remove. Really disapointed with the fit in places, just overerly tight and not fitting at all without serious trimming. Control surface does not fit onto the tailplane without some careful adjustment. I was keen to see how the wings went together and how much clean up they would require around the leading edges. That was the best I could achieve and not looking foward to cleaning up around all that beautifuly rendered corrugated surface! After a fun afternoon at the bench I had all of the major parts built up and cockpit parts ready for painting. Got to say, its a lovely little kit and goes together very quickly, looking foward to getting some paint on and finish building the cockpit. Regards. Andy Edited July 6, 2018 by monthebiff Jan_G, Hubert Boillot, Trak-Tor and 12 others 15 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 29, 2018 Share Posted April 29, 2018 Nice to see someone building this kit, Andy. I'm just working on my review of it now. You'll probably finish your build before I finish my review! Kev LSP_K2, Kagemusha and monthebiff 3 Link to comment Share on other sites More sharing options...
Guest Posted April 29, 2018 Share Posted April 29, 2018 Thanks Andy !.....Harv Link to comment Share on other sites More sharing options...
sandokan Posted April 29, 2018 Share Posted April 29, 2018 Good shot Andy!! monthebiff 1 Link to comment Share on other sites More sharing options...
Iain Posted April 29, 2018 Share Posted April 29, 2018 Great start Andy! Recon this is probably the most straightforward of the WnW kits? Iain monthebiff 1 Link to comment Share on other sites More sharing options...
monthebiff Posted April 29, 2018 Author Share Posted April 29, 2018 Great start Andy! Recon this is probably the most straightforward of the WnW kits? Iain Its a lovely little kit Iain and is a very simple build, I have come across a couple of silly fit issue's which should have been ironed out at the test shot stage but otherwise a lot of fun to build! Regards. Andy Iain 1 Link to comment Share on other sites More sharing options...
Jan_G Posted April 29, 2018 Share Posted April 29, 2018 will follow with great interest Andy! jan monthebiff 1 Link to comment Share on other sites More sharing options...
karimb Posted May 1, 2018 Share Posted May 1, 2018 I am in with a load of popcorn. Haven't jumped on the bandwagon yet but i have a couple of ideas. Following your progress and taking notes! monthebiff 1 Link to comment Share on other sites More sharing options...
Robthepom Posted May 1, 2018 Share Posted May 1, 2018 that does look like a fun build, i'm really interested to see how your decals go in the wing texture, great start monthebiff 1 Link to comment Share on other sites More sharing options...
DonH Posted May 2, 2018 Share Posted May 2, 2018 monthebiff 1 Link to comment Share on other sites More sharing options...
monthebiff Posted May 2, 2018 Author Share Posted May 2, 2018 I am in with a load of popcorn. Haven't jumped on the bandwagon yet but i have a couple of ideas. Following your progress and taking notes! Hi Karim, thanks for checking by. its a great little kit wnW have put together. Hopefully I can do it some justice! Regards. Andy Link to comment Share on other sites More sharing options...
monthebiff Posted May 2, 2018 Author Share Posted May 2, 2018 that does look like a fun build, i'm really interested to see how your decals go in the wing texture, great start WnW say the decals are extra thin, I like you are very interested to see how they perform! Regards. Andy Link to comment Share on other sites More sharing options...
monthebiff Posted May 2, 2018 Author Share Posted May 2, 2018 Spent this evening spraying the main interior components ready to move on to detail painting. I thought I would go with unpainted fuselage interior with the main cockpit frame work in light grey/green for some interest. How correct it is I'm not sure but fun all the way on this build!! For the fuselage interior I first sprayed a very light coat of Tamiya primer followed by a pre shade of dark grey. I then misted over Vallejo Dark Aluminium metal coat. I think I have managed to add a little variation to the corregation and should look interesting with the grey green cockpit frame work. Regards. Andy DonH, Gazzas, Rick Griewski and 2 others 5 Link to comment Share on other sites More sharing options...
Rick Griewski Posted May 4, 2018 Share Posted May 4, 2018 I have the kit so it is great to see this build going on while I am in the trenches with my other builds. I was planning to clean up around "all that beautifuly rendered corrugated surface" using a Fiberglass scratch brush tool. I am betting that a buffing motion parallel to the grooves will remove the trash in the grooves and high points equally. Rick monthebiff and Bomber_County 2 Link to comment Share on other sites More sharing options...
monthebiff Posted May 5, 2018 Author Share Posted May 5, 2018 Cockpit just about ready for closing up with all of th major components ow painted and just needing some final weathering. I pre shaded the rear cockpit panel which has a subtle fabric texture moulded and then covered in a scrap of Aviattic fabric decal. Then the seat was added with HWW fabric belts I had in the stash that were earmarked for a Fokker D VII build. So not quite an OOB build but almost! Should get the cockpit closed today and then on to fitting the engine which is pretty well built up now. Regards. Andy Kagemusha, Gazzas, Grant_T and 4 others 7 Link to comment Share on other sites More sharing options...
