1/8 HISPANO SUIZA aero engine
PROPELLER
Hi Gentlemen!
My first post here... A french WW1 engine. A french guy too!
This engine will fit an SE5a "Museum Series" of Hasegawa, the reason why...
The real engine:
The way of Hasegawa, only one of cylinder head_before surgery_no crankcase, no oil sump, no carburetor, no plumbing... Just that you can see on the ended model, no more!
Of course I can understand. Take a look to the crankcase only:
Well, I had to find a solution...
Let's go, my way:
Some parts to wear the skeleton...
That's all folks today!
Cheers, Dan.
Hi Dan, this is an interesting project.
I have the same kit myself and pondered the same problem.......why Hasegawa did not do a full engine for this kit. I pondered about the possibility of making a crankcase and other details....but that was as far as I got. I did however managed to collect some detailed component and assembly scale drawings for the engine. They were drawn by W.A. Wylam and published in the September 1945 Model Airplane News. I would be happy to scan and e-mail to you if that would be useful. You will have some work to do to replicate the carburettor and intake assemblies as well as the magneto assembly on the back of the engine.
The next question arises....any thoughts of copying the components you make in resin?
Thanks guys!
To Steve McC, now, I can understand "why" they did not! And yes I will have some work...
Thanks for your help but I got all engine drawings now, but... I'm looking for diagram of cooling system!
Well, some work on cylinders blocs, with many flanges and support of it!
Oil sump now may be?
Cheers, Dan.
Hi Dan,
I'm impressed. When you say you need a drawing of the cooling system, I presume you are referring to the external pipe work and pump associated with engine and the relevant plumbing to the SE5 radiator. The Wylam drawings have this information with dimensions.
Not wanting to be pushing the question....but I have to, are you intending to copy these parts in resin?
This most elegant of all aircraft engines would look great in a 1/8th model of the famous speedboat, Baby Bootlegger.
Good to see some real brass-bashing for once. So much more satisfying than all this mucky old plastic!!
Martin
Dan, you are doing a fantastic job!
If you plan to make some resin (or even white metal) copies of this, I will definitely buy one! I have the kit and the incomplete engine is an issue that nees to be addressed.
I love what you are doing!
Radu
Thanks guys!
To Radub, Maybe, maybe... Not in resin_I hate!_ but white metal perhaps...
And all my congratulation about your work!
Well, some progress, some re-done, take a look on the beast size:
Et sous toutes ses faces:
The other side of the moon:
Cheers, Dan.
