Crossofiron Posted June 25, 2018 Author Share Posted June 25, 2018 Cheers Will! I don't do many firsts... Here is the revised section after your picture; I also have a bit of a get of jail card... I may have a go at the night binoculars but here is the final photo of Midnite Madness after the accident; I know they could have been taken off but the support bracket is not there for the Night Binoculars either.... Victor K2, chukw, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
Night Fighter Posted June 25, 2018 Share Posted June 25, 2018 This plane was damaged when the Spook crash landed. Link to comment Share on other sites More sharing options...
Youngtiger1 Posted June 26, 2018 Share Posted June 26, 2018 Very nice and clear work...as if no glue has been used Link to comment Share on other sites More sharing options...
Trak-Tor Posted June 26, 2018 Share Posted June 26, 2018 Fantastic looking details, indeed! How did you make the rivets on the stringers? Are they photo-etched? Thanks. Juraj Link to comment Share on other sites More sharing options...
Night Fighter Posted June 26, 2018 Share Posted June 26, 2018 That conduit on the left side that goes to the box continues along the left side along side the one for the communications antenna. Both continue to behind the panel. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 26, 2018 Share Posted June 26, 2018 Absolutely brilliant work. Way beyond us mere mortals Keep ‘em comin Peter Link to comment Share on other sites More sharing options...
theseeker Posted June 26, 2018 Share Posted June 26, 2018 Exceptional work! Link to comment Share on other sites More sharing options...
Night Fighter Posted June 27, 2018 Share Posted June 27, 2018 (edited) Actually the box that you have the lower conduit running to is not a box but a bracket where that T-handle I was telling you about goes. I'll check on what that T-handle actually goes to. Just realized that the picture you sent me was from a P61C. That's why it was so confusing. Duh, silly me. Edited June 27, 2018 by Night Fighter Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 27, 2018 Share Posted June 27, 2018 That is a serious bit of kit! Thanks for sharing Biggles323 Not much to show, ploughing through some bits when I get the time, work is full on to the extreme.... Wanted to share this though as it tickles me a bit; Had the brass bits for years now in my parts box. The black bit is the kit's take on the 'Relief Tube'; one for each station. So, in some circles, it's a 1/48 A1 Skyraider Gun Barrel and Muzzle, to me, it's the P**s Tubes for a P-61... Hmmm. Looks a little small.... Beautiful work so far. I have this kit with loads of AM in my stash. Just needs the Relish bits for me to start. Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 27, 2018 Share Posted June 27, 2018 Amazing, just #@£#@£ amazing.........pass the knitting ........ No joke there. Personally, I'm considering macramé Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 27, 2018 Share Posted June 27, 2018 Hello All! An update on progress. First of all, I would like to thank Night Fighter who has been simply fantastic. Not only did he stop me going down the path of building a B Model when I am building an A but also Night Fighter certainly knows his stuff!!! Cheers mate... So, After mail exchanges, here is the upgraded seat; Here is the Rear Station now modified to an A Model with custom Photo-Etching etc. Seeing as I did the front bit, thought I should have a go at the back bit... Here's the front Undercarriage; Here is the Instrument Panel. Difficult this one as each dial had to be really carefully milled as the panel is designed to have an acetate sheet behind with the dials. It's Airscale every time for me! Here are the final side walls; Thanks for looking. Next time, I will prove I can paint! Cheers Steve Truly masterful. Multiple comments mean I'm blown away, over and over again. Link to comment Share on other sites More sharing options...
Night Fighter Posted June 27, 2018 Share Posted June 27, 2018 (edited) Got it, your lower conduit is correct for the "A". The T-handle coming from the box/bracket is the pull release for the bottom door opening mechanism. The two conduits I saw going forward on the left belong to the two antennas. One on the top for communication, the other on the bottom below and slightly forward of where the r/o sits, used to transmit friend or foe signals. Will Edited June 27, 2018 by Night Fighter Link to comment Share on other sites More sharing options...
Troy Molitor Posted June 27, 2018 Share Posted June 27, 2018 This is such an amazing and accurate build coming to life. Seriously, a great tread to witness a step by step build. Pilot and crew relief tudes are important! That was really cool to read about how that issue was reproduced. Carry on and more pictures please? Troy Link to comment Share on other sites More sharing options...
Crossofiron Posted June 27, 2018 Author Share Posted June 27, 2018 Thanks for all the words of encouragement. Keeps me smiling.... Cheers Steve Thanks again Will! Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 27, 2018 Share Posted June 27, 2018 I really like the way those hard lines look ran all together in parallel. Looks very realistic. Out of curiosity, what kind of thickness/type of wire did you use for those? Did you make up a jig or anything to keep them all parallel to each other? Link to comment Share on other sites More sharing options...
