LSP Kit Database needs your help!
LSP_Kevin
Thanks, Erwin. It turns out we were also missing the Safari version from the database, too, so I've added them both now. There seems to be no information about when the Swedish version was released, however. This is usually a sign that there's no date on the kit anywhere.
Kev
Kev
It seems to be a re-pop with different decals.
But I'm going to conventions for a long time,and I've never seen this boxing. Maybe just a limited mumber were made and released.
https://www.scalemates.com/kits/788715-revell-4726-dornier-do-27-fpl-53
Edited by Erwin
OK, here's one for our WWI aficionados: did the Hi-Tech 1/32 Albatros D.V kit ever actually get released? It's in our database as released, but the only talk of it I can find on the web is 2 years' worth of when's it coming out? This seems to have died off some time after 2007, and by 2010, the Wingnut Wings kit was out. I suspect it never happened, and I can find no evidence that it did. But I can't find a definitive statement about it being cancelled, either.
Anyone know for sure? I'll remove it from the database if we can confirm it never came out.
Kev
I have no idea about the D.V kit, Kev, none at all.
Any idea about this one, guys?
Kev
I never heard any more about that D.V. I have a sneaky suspicion it died, especially once WNW came on the scene.
That's my feeling too, Ray. I'll give it a few more days for someone to chime in with something definitive, and then remove it from the database.
Kev
So, we've got a few unanswered questions in the queue, so perhaps it's time to offer up some low-hanging fruit. Are all of Roden's LSP kits (pretty much all WWI so far as I can tell) original? No reboxes from other manufacturers?
Surely someone knows the answer to this one!
Kev
Thanks, Thierry. I realise that the initial release is much older, but I can't pin down a definitive release date for the specific "Little Bird Night Stalkers" release,  kit no. 3527:
http://www.largescaleplanes.com/kitdb/details.php?kit=856
As I noted in my previous post, the information on the web is all over the place!
Kev
When I wrote initial release, I was refering to the release of this specific kit, not the OH-6 one.
Kev
All their WW1 kits are original molds.
Hth
Thierry
  • 2 weeks later...
Here is some additional information for the Revell Piper Super Cub "family":
Additional information for the existing entry HERE:
Kit Name: Piper PA-18 Super Cub
Kit Family: Revell Piper Super Cub
Availability: OOP
Notes: Parts depict an L-18C with early, small cowl, Continental C-90-8F engine, and military "greenhouse" windows.
_______________________________________________________________________________________________________
New entry information:
Manufacturer: Revell USA
Kit Number: 85-5483
Kit Family: Revell Super Cub
Medium: Injected (White & Clear)
Scale: 1/32
Status: OOP
Year: 2009
Notes: Same plastic as original RoG release (04208). Flap-less wings, single fuel cell in port wing, small engine & cowl, and military "greenhouse" windows. Decals are supplied to ineffectively depict civilian style window shapes.
Markings: Civilian N83359, white with red trim. Civilian N462RL, white with blue trim. US Army L-18C 51-5339, overall yellow.
_________________________________________________________________________________________________________
Manufacturer: Revell-Germany
Name: Piper PA-18-150 Float Plane
Kit Number: 04698
Scale: 1/32
Status: OOP
Year: 2009
Notes: Substantially different from earlier releases. Includes new wings with flaps, two fuel cells (one in each wing) and port wing leading edge light. New, larger horizontal stabilizers. New engine, cowl, spinner and prop depicting the larger Lycoming O-320 engine. New fuselage halves and clear parts to properly depict civilian style windows.
Markings: Civil (Netherlands) PH-PDL, overall while with red trim. Civil (Switzerland) HB-PQJ, white and yellow.
Name: Piper PA-18 With Bushwheels
Kit Number: 04890
Scale: 1/32
Status: Available
Year: 2014
Notes: Contains the same airframe parts as the previous Float Plane version (04698). Includes wings with flaps, two fuel cells (one in each wing) and port wing leading edge light. Larger horizontal stabilizers. Large engine, cowl, spinner and prop depicting the Lycoming O-320 engine. Fuselage halves and clear parts to properly depict civilian style windows. Also includes parts for both standard landing gear and wheels, as well as new "Bush Wheels" with modified landing gear. This is the first boxing to include proper civilian style windows and standard landing gear in the box.
Markings: Alaska State Troopers N7059, Blue with white and yellow trim. Civilian N693JB, overall yellow with black 'lightening bolt'.
All images and observations are mine from this afternoon. :)
D
Edited by D Bellis
Thanks, D - mighty helpful! This info does raise a question though. If the float and bush versions have a different wing to the other releases, that normally qualifies them to be split off into a different kit family (the basic guideline is that if the wing or fuselage is new/different, then it's essentially not the same tooling anymore). So, based on your descriptions, it seems to me we need 'early' and 'revised' versions of the basic kit family to accommodate them. Does that seem right to you?
Kev
That is a tough call. I would have to say no, though, since the fuselage modifications were accomplished via mold inserts not modified tooling. All of the rest was accomplished though separate tooling. Revell could release any of the versions at any time, so spitting them might not work in the long run.
D
