1/16 wooden Spitfire
Jens
got it in christmas gift.
i hope i can make it Danish.. i would apreciate if you could help me find the diffrence between those two..(mk5, to mk21E)
im making a scratch build cockpit and this time the instruments followed the kit :D
Erwin as i have told you MANY times, you make it look easy, but these gulliow kits isnt easy i found out :(
i have already broken a couple things B) i cermentet them togther again :) ..
Hi Jens,
No build is easy.No matter witch material it's made of.
You encointer problems,you overcome them .
Lucky for you I just did a full picture buildstory on the same kit.
I'm not saying that my method is THE best and only way to build such a kit.
But the result I get pleases me enough to say it's a pretty good buildmethod.
Don't rush your build and take your time.
Looking forward to see more.
BTW,I'm no Spit expert.But the Mk 21 has a different prop,oilcoolers,bigger nosesection,etc...and also a much bigger tailsection than the one in the kit.
So the fin parts you already started will not be correct.
Keep it simple and stick to a early mark.Otherwise you will be doing a big and difficult conversion.
If you wanted to do a Mk 21 then you should have changed the plans before starting and making the bigger parts from scatchbalsa.
I know that I wouldn't begin to convert a Mk1 into a Mk21.
im thinking about it.. im sure ill cover the stablizer as well.. but im still thinking about fuselage and wing.. <_<
Don't think about it...do it. You won't regret it. It's much better looking than tissiue.
If you are unsure on how to do it.Have a look again how I did it.
It's not realy that difficult.
  • 4 weeks later...
  • 6 months later...
after a long brake im back rebuilding this one!
i have in the mean time i've done a lot of things on it..
wing- and destroyed all the ribs on it trying to cover it with balsa, but i got mad and rebuilded all the ribs and at the time im sanding and fitting vac parts, and yes- i know that there still is missing a lot ribs on it but dont worry, they'll be added soon :)
cockpit-trashed :huh:
Fuselage- added a lot ribs, and then i removed them again, and then i added them again :huh: and as in Erwin's spitfire build the vac parts also was a disaster :angry:
its quite heavy becurse f all the putty i used to fit it :blink:
LG (landing gear)-startet, and its looking quite good i think, i covered it with metal tape :lol: , the only thing im thinking about is how long it'll hold :unsure:
