Tony T Posted May 4, 2018 Share Posted May 4, 2018 Thanks for the review Andy. Alistair, if you do a NLG leg for the 1/32 Revell Typhoon or MLG legs for the 1/48 ICM Foxbat series you can have my money - I'd take two of the latter and pay up-front. Tony David66 1 Link to comment Share on other sites More sharing options...
David66 Posted May 7, 2018 Share Posted May 7, 2018 Thanks for the review Andy. Alistair, if you do a NLG leg for the 1/32 Revell Typhoon or MLG legs for the 1/48 ICM Foxbat series you can have my money - I'd take two of the latter and pay up-front. Tony And I'd do the same for a set of landing gear for the Revell 1/32nd F-4 Phantom kits ! Zero77, kalashnikov-47 and ScottsGT 3 Link to comment Share on other sites More sharing options...
Ali62 Posted May 11, 2018 Share Posted May 11, 2018 All sets except for one order placed yesterday are now in the mail. Thanks for all the support guys, although the response has been not too bad and I have broken even and made a little with the sales thus far, I will really have to consider further releases carefully, especially when it will need quite a few parts like the Bronco set. I now have 16 sets left from the production that I have done, once those sell I will look at when I do a further production run, as I need too order at least 20 each time, so if you are wanting another set soonish then now would be a good time to get it. I was hoping to announce the next set that I am going to try, HOWEVER the master parts got destroyed by the caster setting up the moulds.........so this will now only happen in about 2 weeks time. Hopefully more sets will follow after that, but will see how this next set goes. Ali David66, Harold, Zero77 and 1 other 4 Link to comment Share on other sites More sharing options...
ScottsGT Posted May 11, 2018 Share Posted May 11, 2018 Got mine yesterday. WOW!!! These are incredible. For the detail and parts count I would have expected to pay a little more. Now about those 1/32 Revell Phantoms David mentioned.... I'm just saying, I have 6 Revell Phantoms in the stash. Harold, johncrow and David66 3 Link to comment Share on other sites More sharing options...
Ali62 Posted May 11, 2018 Share Posted May 11, 2018 Hi Scott Thanks that is great, good to have positive feedback. Perhaps I will consider a set for the Phantom if they are sought after, that may have a wider appeal than the Bronco. I plan to look at the Eurofighter and the P-38 in time, but as I do not have ALL the models and I do not model some of the larger size aircraft in 1/32, I would take as much guideance as I can from you guys. What I mean is that perhaps for some aircraft and applications only the nose wheel or in some cases on the main undercarriage needs to be done, it is pointless making parts to replace parts that are perfectly good for the job. As this is a part time venture and also on limited resources I will only be able to do one or two projects at a time and then regroup and fund the next. However now I am gaining more knowledge and settling in with the brass caster it does bode well for some larger multi-media projects for later down the line. Suggestions will be welcomed here or via PM's, and as Andy requested 1/48 ICM Foxbat U/C above, it does not have to be restricted to LSP subjects but I do not want to break the site main emphasis of LSP, so keep that in mind when you make suggestions, but I am sure all will work out. Ali David66, Iain and Harold 3 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 11, 2018 Share Posted May 11, 2018 For the Revell Phantom, the front LG leg is far too skinny whereas for the Eurofighter the main problem of the front LG leg is the lack of strength, not its shape. So, you are right regarding the fact the problem is often a front landing gear leg one! Harold and David66 2 Link to comment Share on other sites More sharing options...
Kagemusha Posted May 11, 2018 Share Posted May 11, 2018 So what do you think Thierry, just a replacement nose gear for the Revell Typhoon, and F-4, or main gear also? David66 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 11, 2018 Share Posted May 11, 2018 Well, for the Phantom, the main LG legs are far too long (something like 3mm if my memory is right). So, there is a need here as well but not an absolute one as it is rather easy to decrease the length and add a metal core inside (e.g. paperclip section) because the parts are hollow. Harold and David66 2 Link to comment Share on other sites More sharing options...
Kagemusha Posted May 11, 2018 Share Posted May 11, 2018 Thanks Thierry, something for Ali to consider. Harold and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Iain Posted May 11, 2018 Share Posted May 11, 2018 Ali - I think the Eurofighter nose leg would be a great product - I'd certainly want a few... Iain David66 1 Link to comment Share on other sites More sharing options...
Tnarg Posted May 12, 2018 Share Posted May 12, 2018 The P-38 set sounds like a winner. Good luck with your efforts. I am incredibly pleased with the OV-10 set you sent, and hope to get something done on the CAL FIRE plane from our local airport. Tnarg David66 and Harold 2 Link to comment Share on other sites More sharing options...
kalashnikov-47 Posted May 12, 2018 Share Posted May 12, 2018 (edited) And I'd do the same for a set of landing gear for the Revell 1/32nd F-4 Phantom kits ! I cannot possibly push the "Like" button enough for this comment!! I'd buy two! Edited May 12, 2018 by kalashnikov-47 ScottsGT and David66 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 12, 2018 Share Posted May 12, 2018 Just got my two sets! Thanks Ali! This kit needed these brass legs as bad as any I know of atm. David66 and Harold 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 14, 2018 Share Posted May 14, 2018 Got my sets as well. Highly recommended!!! Link to comment Share on other sites More sharing options...
otis252 Posted May 15, 2018 Share Posted May 15, 2018 Got my shipping notice Friday, May 12th. Hopefully it won't be long until mine arrive. Chuck Link to comment Share on other sites More sharing options...
