Rick Griewski Posted March 21, 2024 Posted March 21, 2024 On 3/10/2024 at 5:36 PM, Gazzas said: Love the tenuous connection to the group build. Well done! Maybe offer a prize to the most tenuous connection at the end of the build. Gazzas and blackbetty 2
blackbetty Posted March 21, 2024 Author Posted March 21, 2024 i glued the cockpit assembly to the port side of the fuselage next LSP_Kevin and Azgaron 2
blackbetty Posted March 21, 2024 Author Posted March 21, 2024 (edited) then i cut a wedge from both fuselage halves behind the cockpit to make the italeri bulkhead fit Edited March 21, 2024 by blackbetty LSP_Kevin, Landrotten Highlander, chrish and 5 others 8
blackbetty Posted March 21, 2024 Author Posted March 21, 2024 before joining the halves i made some intake trunking in bolth halves to prevent a see-through fuselage granted, the mirage intakes are very small, but still a modification i wanted to do geedubelyer, alain11, BradG and 5 others 8
blackbetty Posted March 22, 2024 Author Posted March 22, 2024 had to use considerable force to close up the fuselage and keep everything fairly straight Azgaron, denders, BradG and 3 others 5 1
blackbetty Posted March 22, 2024 Author Posted March 22, 2024 the wedge for widening the fuselage was glued in at the bottom, cannon ports were opened up before, lotsa putty required chrish, BradG, Azgaron and 2 others 5
blackbetty Posted March 22, 2024 Author Posted March 22, 2024 correcting the shape of the fuselage behind the pit to make the canopy fit, again lotsa putty on the intakes denders, Azgaron, BradG and 2 others 5
blackbetty Posted March 22, 2024 Author Posted March 22, 2024 (edited) some work to change the IP setup to a dagger from the mirage part (uh-oh, macro) Edited March 22, 2024 by blackbetty LSP_Kevin, Azgaron, denders and 1 other 4
alain11 Posted March 22, 2024 Posted March 22, 2024 Hi WOW !!! a long sanding session awaits you ... did you receive the 1300L tank ?? Alain blackbetty 1
Azgaron Posted March 23, 2024 Posted March 23, 2024 Very nice work so far! Looks great! Håkan blackbetty 1
blackbetty Posted March 25, 2024 Author Posted March 25, 2024 lots of scratchwork to fit the italeri canopy... BradG, Landrotten Highlander, Daniel Leduc and 4 others 7
blackbetty Posted March 25, 2024 Author Posted March 25, 2024 dryfit of the dagger nose alain11, denders, Daniel Leduc and 7 others 10
thierry laurent Posted March 25, 2024 Posted March 25, 2024 Well done Karl! Typically the kind of project I love!!! blackbetty 1
DugyB Posted March 25, 2024 Posted March 25, 2024 Gulp…., and I thought I hated putty and sanding …..ain’t got nothing on you…. blackbetty 1
