sandbagger Posted February 22, 2023 Posted February 22, 2023 (edited) Hi all, As the build of the Halberstadt Cl.II is coming to a close, I've started to prepare for the next model. This hopefully will be Hannover Cl.II, Serial No.690/18 of FEA 8 (Fliegerersatz Abteilung 8), based at Graudenz (now Grudziadz in Poland) in late 1918. I've changed my original scheme to this one as the decals I applied did not go well. Basically the lozenge decal I used were clear backed, which was not the problem. The problem was adding the rib and edging tapes to the wings etc. The cut clear backed lozenge decal, when applied, showed the underlying decal, making the rib tapes way to dark and muted. I did try white backed lozenge decal, but they were way too bright. Basically I should have used the white backed lozenge decal to start with. So, rather than spend more buying replacement decal, I decided to change the scheme to the above. Also, I have a commission build of the CSM Bristol Scout waiting to be started, so time is pressing, Mike Edited March 26, 2023 by sandbagger Kagemusha, MikeMaben, LSP_Kevin and 10 others 13
sandbagger Posted February 24, 2023 Author Posted February 24, 2023 Hi all, I've started on the Argos As.III engine. I'm using the kit supplied alternative cylinder block, as this does not have the unrealistic solid moulded valve push rods. These will be added later using Nickel-Silver tube. The exit ports of both exhaust pipes have been drilled out as these were also solid moulded. Finally, I've added 0.8 mm diameter tube to the rear ends of the ignition lead support tubes. These will allow for the insertion of ignition leads from the magnetos later in the build. Mike Boch, Landrotten Highlander, scvrobeson and 9 others 12
Uncarina Posted February 25, 2023 Posted February 25, 2023 I’ll be following this! It might be just what I need to see me through my stalled build. I’m curious to see your interpretation of the painting of the fuselage ventral surface. Cheers, Tom
sandbagger Posted March 7, 2023 Author Posted March 7, 2023 (edited) Hi all, The basic engine is done. The radiator pipes and exhausts will be fitted later in the build, Mike Edited March 7, 2023 by sandbagger Iain, Troy Molitor, patricksparks and 12 others 15
sandbagger Posted March 17, 2023 Author Posted March 17, 2023 Hi all, The fuselage is close to being closed up now. I've added: The rudder and elevator control cables, using 0.12 mm diameter mono-filament and 0.5 mm diameter blackened Brass tube. The wireless cable from the from the hand reel in the observers cockpit and through the cockpit floor. The control rod from the clutch control lever (wireless set generator - engine driven), from 0.4 mm diameter Nickel-Silver tube. I've also fitted the cockpit panel for the pilots machine gun ammunition magazine in the half open position, not that you can see much of the ammunition inside the magazine. The engine and two radiator pipes are only dry fitted. Those, along with the pilots 'Spandau' machine gun, will be fitted after the fuselage has been painted. An engine throttle control will also be fitted at the same stage. Mike chukw, AlbertD, LSP_Kevin and 12 others 15
LSP_Kevin Posted March 17, 2023 Posted March 17, 2023 That looks superb, Mike! All those details just look so authentic. Kev
Archimedes Posted March 17, 2023 Posted March 17, 2023 Oh wow that looks good! I see you have chosen quite a dark shade for the natural wood interior which is interesting: Generally the Hannovers were skinned with 1.6 mm Baltic birch plywood and then with doped fabric over the top. It is not clear from my references whether this would be on both the inner and the outer surfaces though. But, you are doing a fantastic job with this machine and I am really looking forward to seeing the finished result. Kind regards, Paul
sandbagger Posted March 18, 2023 Author Posted March 18, 2023 18 hours ago, Archimedes said: Oh wow that looks good! I see you have chosen quite a dark shade for the natural wood interior which is interesting: Generally the Hannovers were skinned with 1.6 mm Baltic birch plywood and then with doped fabric over the top. It is not clear from my references whether this would be on both the inner and the outer surfaces though. But, you are doing a fantastic job with this machine and I am really looking forward to seeing the finished result. Kind regards, Paul Hi Paul, Yes, your correct in that birch plywood was used on the fuselage and certainly covered with doped lined. I couldn't find any reference to the type of finish that was applied inside the fuselage and cockpit areas. 'Wingnut Wings' call for a dark wood finish and usually their recommendations are well researched. So I've assumed that a dark shellac varnish or similar was applied to the fuselage internals, Mike Archimedes, Paul in Napier and Troy Molitor 3
sandbagger Posted March 18, 2023 Author Posted March 18, 2023 Hi all, Both weapons for the Hannover completed. The pilots 'Spandau' is a combination of the kit supplied parts and the ‘Master’ Spandau LMG 08/15 barrel and jacket (AM-32-023). The observers 'Parabellum' is the ‘Gaspatch’ Parabellum 14/17 resin machine gun, Mike Troy Molitor, AlbertD, spartacus2000 and 8 others 11
Paul in Napier Posted March 18, 2023 Posted March 18, 2023 Always loved this plane, since I first saw the Airfix 1/72 in their catalogue. Never found the kit though (just as well........those lozenges in 1/72! Yours looks fantastic though! Troy Molitor 1
europapete Posted March 18, 2023 Posted March 18, 2023 Hi Mike! Awesome job as usual. Paul, with regards to the doped fabric over the plywood. Shuttleworths LVG has that too, but only on the outside. The interior is just varnish. Paul in Napier and Archimedes 1 1
Troy Molitor Posted March 19, 2023 Posted March 19, 2023 I can't agree more than what Paul mentioned above. Love this aircraft. You're doing it up properly Mike. Lovely updates mate. Paul in Napier 1
