43 minutes ago, airscale said:
looking incredible Pete - good luck with the canopies, your approach is spot on I reckon
i have no idea why Revell made them the framed version that literally only 50 aircraft had..
Thanks! And great question Peter-
I was hoping I could talk Ali into doing them..but he is swamped with work-
cheers
P
On 2/5/2023 at 5:40 PM, scvrobeson said:
Seems relatively normal for the rear observer/gunner to only have a lap belt. I think the Stuka had the same.
Your work is exemplary Pete, but we all knew that.
Matt
Thanks Matt-
As far as I can tell, just a lap belt for the observer- I’ve reached the end of the internet it seems
Makes sense I guess?
cheers
P
Great work Pete, your stuff is truly amazing.    On a side note - do you happen to recall what size rivets you used on your previous HH-60 build (to cover the exterior of the fuselage)?  I dove through the build log last night but could find any info.
Hi John,
 thanks!
I had Woody custom-make me rivets for that project. I gave him the size and spacing and he made me a few A4 sized sheets. That covered most of the airframe, and I used several different stock Archer sheets to fill in details like circular rivets patterns etc.
 I know that’s not a direct answer to your question, but I think I still have the measurements for diameter and spacing that I took from an actual Pavehawk- let me dig around a bit. The spacing is from rivet center to rivet center; not the gap between rivets
cheers
Pete
Thanks all for the encouraging words!
…poured the female mold for the canopy just now. We’ll see how it turned out in a few hours
just simple 1:1 mold rubber. Remember to cover the male pattern with mold release before you pour the rubber. Both these get poured into a red Solo cup and mixed before pouring into the mold
the mold box is simply a container for some Tapcon screws I had lying around
P
Edited by Pete Fleischmann
