14 hours ago, chrish said:
Oooooooh this is gonna be good in the hands of the master!
if I remember right I built one back in the early 70’s when I was just a kid, not even a teen yet. I think it was motorized? I’d love to try building one again but daaaaaam they’re expensive now!
ok I’m pulling up a chair, I’ll get a big bag of Doritos and a Drink
Thanks for the compliment, but I'm no master at all! Pete and Chuck are masters, but not me!
Tim
Tim
Ya...you're right about those two... but the rest of us are mere humans.
enough talk get to work!
  • 2 months later...
Well, it turned in to more than a few days, but I finally started on the pilot seats.
First up was the left seat. I added the forward/aft handle from .030 rod bent to shape and the 2 ends of rods are for the crank handles for height adjustments.
I also added a back pouch made from 2 part aves putty.
20230305_005212
More later on tomorrow after church.
Tim
While I wait for the Vallejo putty to dry on my seats, I decided to tackle the oval that houses the dual landing lights under the nose.
Screenshot_20221217-062443_Chrome
After a few hours of shaping and sanding with files and sanding sticks, I have the rough opening finished.
20230311_205224
In hindsight, I wish I would have made it a little smaller, but it's done now so it is what it is.
Hopefully as I fill it in with details, it will look a little closer to real.
Comments and critiques welcome!
Tim
  • 3 weeks later...
After looking at the nose a little longer, my AMS kicked in and I had to make it better.
First, I took a scrap piece of .010 sheet styrene and glued it to the back to make the mounting wall for the landing lights.
Secondly, I then took a strip of .030 styrene and heated it up using my floor heater and began to roll it back and forth using a paintbrush handle till I got the rough shape and then snipped it and glued it into the opening to look like the bezel.
Finally, I took Vallejo putty and filled in the gaps and sanded. (Looks like a small gap needs more).
I temporarily placed 2 resi-cast 4mm light lenses inside to see how much it better it looks.
I think it looks ALOT better. All I need to do now is glue on some resin rivets and I'll call it finished.
20230327_022743
Comments and critiques welcome.
Chow till next weekend!
Tim
20 hours ago, jeroen_R90S said:
Looks great -no critique needed! :D
I may have missed it, but what Vallejo putty did you use? I've used the white water soluble one in the past and found it sanded poorly, so I'm curious!
Jeroen, the secret to sanding that Vallejo putty is to leave it at least 48 hours before you attempt to do so, with 72 being preferable. And don't wet sand it! Water seems to reactivate it no matter how long you leave it, in my experience. Admittedly, I didn't experiment very much with it after it happened the first time!
Kev
  • 2 weeks later...
Tonight I decided to start work on the engine firewall. It was airbrushed using  Vallejo MC Dark Aluminum.
Afterwards I painted the voltage regulator tamiya rubber black and applied a placard from my decal spares. My wires are red stretched sprue.
I applied a dark grey tamiya panel line accent wash, and it needs cleaned up, but I need some help as to how you highlight silver???
20230408_004643
Comments and critiques welcome as usual.
Tim
Edited by Hawkwrench
A little bit more work on the firewall tonight before work.
I first cleaned up the pin wash followed by painting the battery box tamiya rubber black. Next, I put a couple of spare decals on the top and superglued it onto the firewall. Next I painted 2 lengths of detail master coolant hose off white to replicate the battery wires.
I also added the ignition coil and wire.
20230408_233332
Tim
Outstanding work Tim.
:goodjob:
I shall follow this with much interest (I would love to have one of these kits as I wish to make a T-41D Mascerlero).
Cheers
Derek
:goodjob:
Cheers
Derek
Derek,
they pop up from time to time on Ebay for a reasonable price.
I think I paid $225 shipped.
Tim
