Troy Smith Posted November 26, 2022 Share Posted November 26, 2022 (edited) 1 hour ago, Cees Broere said: Indeed, One-oh-four and I have had a good look at the built op model. It looked great. also two canopies, one of which is intended to portray the slid back hood. The Revell representative confirmed that a Mk I will follow. This is because Hurricane canopies run on curved rails, and thin and flexible, so change shape when open or closed, when shout the front is narrower and higher, and open the front is wider and lower. Also when Hurricane canopy frames often look quite tatty, the flexing cause the paint to flake off.. 1 hour ago, Mark P said: Anyone know if different propeller options are planned? If not, I'm sure the aftermarket people will step up. Mark Proulx From what I can iin the sprue shots and build up, we have the common Rotol unit used by Mk.II's, there are at least two blade shapes, and two types of 'bullet' spinner, the kit look to have the ES/9 unit. They two spinner types are very similar at first look, the bullet shaped ES/9 spinner and the slightly longer CM/1. The difference in shape between the two is very subtle with the ES/9 having a constantly increasing curve from the back plate to the nose while the CM/1 has a flatter curve from backing plate to just in front of the blades and then a slightly steeper curve from that point. The easiest way of telling the difference is but looking at the way spinners attach to the back plate. The CM/1 spinner is locked by a single slot located on the backing plate so if you can’t see any holes on the spinner you may be looking at a CM/1. If you are lucky and the prop has stopped in the correct place you may even be able to see the slot in the backing plate. It also has a seam just in front of the blades, sometimes you can see oil streaks. You also see a black square round the slot sometimes. It is I believe a bit longer than the ES/9 , and this may account for different quoted lengths for the Mk.II The ES/9 is attached by six locking studs on the spinner so if you can see two small holes on the spinner between the blades, you are looking at an ES/9. Just be aware if you are looking at a close-up, DH spinners attach in a similar way. note late Mk.I's got the CM/1 unit, the type initially introduced, the ES/9 came in later, and becomes the common type, but you CM/1 quite late in production. see here https://www.britmodeller.com/forums/index.php?/topic/235078582-hurricane-rotol-spinners-the-cm1-vs-es9-quest You would need new spinner for the Rotol unit commonly associated with the BoB, the ES/6, but the "Mk.I" is a term that can cover A LOT of variations, there are 6 or 7 props and spinners you can see on a Mk.I, not including the one in Canada that got Battle props. see here for as a complete run down of what I know. https://www.britmodeller.com/forums/index.php?/topic/234980181-hawker-hurricane-propellers-and-spinners-a-modellers-guide/ which does at least have identifier photos, and what is likley fitted to what and where..... I'll stress this again, what throws modeller is Hurricanes are simple simple simple COMPLEX, the complex bit is various small external details that vary, and are not well covered in most references. These are also the bits that a modeller interested in making an accurate model wants to know... Once you know what too look for it's easy enough, but it can be a bit random, so with the CM/1 vs ES/9, you won't know what fitted without a photo generally, same with 20 mm cannon barrels, there is the Mk.I with flat spring at base, and Mk.II with a round spring in the middle, note Canadian radiator Lovley image of the ES/9 spinner, and the white line on the back of the blade, sadly i don't think the identity of this one is known the Mk.II replaced the Mk.I, but again there is no 'rule' .... Edited November 26, 2022 by Troy Smith additions mozart, Martinnfb, geedubelyer and 12 others 8 7 Link to comment Share on other sites More sharing options...
mozart Posted November 26, 2022 Share Posted November 26, 2022 Thanks Troy, can’t say I understood ALL of that on first read but it’s great to have it on record for later consumption! Stevepd, Rick Griewski, Archimedes and 3 others 3 1 2 Link to comment Share on other sites More sharing options...
Troy Smith Posted November 26, 2022 Share Posted November 26, 2022 39 minutes ago, dennismcc said: My finger will be on the "buy" button straight away if a Sea Hurricane appears, which looking at the sprues is highly likely. Cheers Dennis From what I can see, you can do a Sea Hurricane OOB, but ONLY one of the few Canadian built JS*** that retained their B wing. BUT MOST Sea Hurricane II's were C winged, the only ones with the B wing are the JS*** serialed Canadian built ones, and the only markings I know of for them are the Torch photos. JS355 these 2, both listed as JS327 but I think these are different, as on is on a beach, the other is on a field Being Canadian they would have a different radiator intake shape. All Canadian built Hurricanes I have seen where you can see the serial and radiator show it was retained, and you do see both in photos. eg this HMS Vindex Hurricane, has the Canadian radiator, (curved sides) but has been rewinged with C wings this is the British type, more of a rectangle The above is very interesting shipboard conversion with rockets for their Swordfish.... which is another story... Paul in Napier, scvrobeson, Alain Gadbois and 11 others 8 6 Link to comment Share on other sites More sharing options...
Mark P Posted November 26, 2022 Share Posted November 26, 2022 Well, I guess I just got schooled on Hurricane spinners/propellers Thanks Troy! Now to try and digest all this! Mark Proulx Archimedes, CharmyDown and Troy Smith 2 1 Link to comment Share on other sites More sharing options...
viper Posted November 26, 2022 Share Posted November 26, 2022 I find it amusing that the original members that were swift to complain and decry have been slow in coming forward..after the designer posted his build … shame really considering they were so swift to mock it ….. albymoore, Paul in Napier, AlanG and 4 others 7 Link to comment Share on other sites More sharing options...
Mark P Posted November 26, 2022 Share Posted November 26, 2022 First, let me say the Hurricane has not held a lot of fascination for me. However, that doesn't mean I don't have plenty of books on it in my library. .So, after the tutorial I got earlier in this thread on Hurricane props (who thought it could be so complicated ), I opted to spend a Saturday afternoon reading up on the Hurricane. Geez... Now, I am left with even more questions! So, I read that Gloster didn't use standard colors for the national insignias on their Hurricane builds. WTH? What did they use and why? . Does it need to be this complicated? Mark Proulx KiwiZac and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
Troy Smith Posted November 26, 2022 Share Posted November 26, 2022 15 minutes ago, Mark P said: First, let me say the Hurricane has not held a lot of fascination for me. However, that doesn't mean I don't have plenty of books on it in my library. .So, after the tutorial I got earlier in this thread on Hurricane props (who thought it could be so complicated ), Its not that complex, and it just they were at a time of changes, and also from different suppliers. Really hurricanes are very simple, say 80% or more of the Airframe is common to all of them (except the fabric wing ones) it's just the bits that do change are very visible. 15 minutes ago, Mark P said: I opted to spend a Saturday afternoon reading up on the Hurricane. Geez... Now, I am left with even more questions! So, I read that Gloster didn't use standard colors for the national insignias on their Hurricane builds. WTH? What did they use and why? . Does it need to be this complicated? you could say that about life.... Re Gloster, and roundel colours, they used the pre camouflage brighter blue and red, note the camouflage dark blue and brick red, one point not usually noted is how many of the Gloster Hurricanes subsequently got their markings repainted at an MU? Some didn't, at the height of the BoB. but it's hard to tell unless you have another plane with the corerect colours, or, new markings added, say when underwing roundels were re-introduced in August 1940 One other Gloster problem is some of their planes also had rather poor paint adhesion, and it flaked off the metal in big chunks. example of all of the above Note the wing roundel on the photographer's plane, pale and flaking off, compared to LK-A, which was Gloster built, and has had them repainted, note fin flash matches the rest, and that is from May 1940, photo is late August, perhaps an example of Gloster's reputed use of bright pre war red and blue? Heavy paint chipping is also noted on some of the first batch of Gloster built Hurricane's as well, the plane the photo was taken from is LK-G, by Sergeant Laurence ‘Rubber’ Thorogood, and avid photographer this is LK-G, P2829, an early Gloster build Its very rare to have multiple images of BoB era planes like this... the above sjo0ws the classic oil stains on Hurricane UC doors as well.... We haven't even got to the free form nature of RAF Sq codes..... no 'font', a specified size which didn't fit, and no even a specified running order? do the codes on the starboard side run LK-G or G-LK? They run LK-G, and are usually consistent in a squadrons but without a photo you won't know.... and yes, the running order in a squadron could, and did change during the war..... Are we having fun yet? iang, Martinnfb, MikeC and 10 others 7 5 1 Link to comment Share on other sites More sharing options...
Bradleygolding Posted November 26, 2022 Share Posted November 26, 2022 1 hour ago, viper said: I find it amusing that the original members that were swift to complain and decry have been slow in coming forward..after the designer posted his build … shame really considering they were so swift to mock it ….. Okay I'll bite. I still think there seem to be significant problems with the model in those initial publicity photos from Revell. Some of it may be the camera and lens, and since we only had to wait a couple of days to see a test build which showed the model in a different light, I have to say I wondered why they bothered with the first photos? Information from Radu and Tony does suggest that this is going to be a very nice model, and the number of versions seems almost endless! I look forward to seeing some builds on here soonish. I have way to many other things to build first. Steve CRAZY IVAN5, Rick Griewski, viper and 5 others 6 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted November 27, 2022 Share Posted November 27, 2022 7 hours ago, Troy Smith said: One other Gloster problem is some of their planes also had rather poor paint adhesion, and it flaked off the metal in big chunks. Looks to be BoB era ... iang, Gazzas, geedubelyer and 3 others 5 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted November 27, 2022 Share Posted November 27, 2022 4 hours ago, MikeMaben said: Looks to be BoB era VY-K, of 85 Squadron, July 1940, P3408, probably at Debden, flow by Sammy Allard, one of a very extensive series of photos by Life magazine of 85 and 17 Squadrons taken at Debden and the Castle Camps satellite airfield.. these are the others 85 album here https://www.flickr.com/photos/144949377@N05/albums/72157704898371932 17 Sq album here https://www.flickr.com/photos/144949377@N05/albums/72157678154026658 As it from July 1940, there are several examples of non standard 'sky' repaints, likely a quirk of the Debden paint shop, with wavy leading edges and high demarcations,. seen on VY-K, H, N, R, and YB-A, C, W both units are look to have been using flight coloured spinners as well, note that S/Ldr Peter Townsend YV-Q, P3166 has a white spinner, photos of 111 Sq in 1938 with 111 painted on show the top in flight colour, but the C/O's is all white numbered. After a mauling in the BoB, 85 went to Church Fenton in Yorkshire, the famous air to air shots of them are from this era, Twonsend has another VY-Q, P3854... famous from the 1/24th Airfix kit.... what has only recently been linked up is that P3854 has fabric wings. OH, @Mark P last year some original fabric off a Hurricane ended up on ebay, a Gloster built Mk.I, P3875 ended up as a maintenance (training airframe) hence the 2694M the brighter pre camo colurs are seen, as well as the red oxide fabric dope up the camo Rick Griewski, Mark P, Model_Monkey and 10 others 7 6 Link to comment Share on other sites More sharing options...
mozart Posted November 27, 2022 Share Posted November 27, 2022 I know Spits are the “glamour boys” but Hurricanes have so much more character! geedubelyer, Uncarina, Alain Gadbois and 6 others 9 Link to comment Share on other sites More sharing options...
Cees Broere Posted November 27, 2022 Share Posted November 27, 2022 Remember that Spit/Hurri debate was made up by the press. And has led a life of it’s own. Nothing to do with reality. Troy Smith, KiwiZac and Archimedes 1 2 Link to comment Share on other sites More sharing options...
Uncarina Posted November 27, 2022 Share Posted November 27, 2022 The info in this thread is fantastic! Cheers, Tom geedubelyer, Mark P, D.B. Andrus and 1 other 4 Link to comment Share on other sites More sharing options...
MikeMaben Posted November 28, 2022 Share Posted November 28, 2022 20 hours ago, Troy Smith said: VY-K, of 85 Squadron, July 1940, P3408, probably at Debden, flow by Sammy Allard, Yep, just posted to show an example of the heavy paint chipping on the leading edge and wings. Thanks Troy. Troy Smith 1 Link to comment Share on other sites More sharing options...
CRAZY IVAN5 Posted November 28, 2022 Share Posted November 28, 2022 On 11/26/2022 at 2:07 PM, viper said: I find it amusing that the original members that were swift to complain and decry have been slow in coming forward..after the designer posted his build … shame really considering they were so swift to mock it ….. I know for my part , I had a question concerning the dihedral, now that that is cleared up I'm good for 3 of them! Thankyou Mr. Troy Smith for all the info that you've imparted, I will be using it in my builds! Uncarina, geedubelyer, mozart and 2 others 4 1 Link to comment Share on other sites More sharing options...
