TankBuster Posted November 17, 2022 Share Posted November 17, 2022 Hi I would like to use magnets to keep outside fuel tanks on Tamiyas big Phantom so I can change to bomb load as well, holes are around 2mm but could be enlarged of course, I just not sure what size magnets to buy to hold them both. Cheers Bob. Link to comment Share on other sites More sharing options...
John Stambaugh Posted November 19, 2022 Share Posted November 19, 2022 These Neodymium magnets are surprisingly strong. Particularly if two are used to attract each other. Tiny as in 1/16th x 1/8th will hold most ordinance quite well. I have used K&J magnets supply with good satisfaction. Happy modeling, John S Woody V, jeroen_R90S and themongoose 1 2 Link to comment Share on other sites More sharing options...
TankBuster Posted November 26, 2022 Author Share Posted November 26, 2022 Hi John, Thanks for the reply. I did find some 5mm ones I had at home and they are super strong as you say. I have ordered some 2mm by 1mm from ebay and will use them to do the job. I will put up a wip this week sometime for all to see and hopefully it will workout. cheers Bob. Link to comment Share on other sites More sharing options...
themongoose Posted November 29, 2022 Share Posted November 29, 2022 (edited) I’ve done the same as John. KJ Magnetics is a great company. The F/A-18 in my sig has all ordnance done this way. It did take 2 of those 1/16” magnets for the centerline tank. It almost floats in the air it’s so closely balanced. A key trick is to stack a couple magnets together and then apply each one. This keeps them from flipping as you glue them down. It also helps remind you which way to orient them when applying to the opposite surface ;-) if you are doing it separate vs assembly all at the same time. I wrote up a description of the technique for the Cincinnati club. You can see it here Edited November 29, 2022 by themongoose Rockie Yarwood and TankBuster 1 1 Link to comment Share on other sites More sharing options...
TankBuster Posted December 2, 2022 Author Share Posted December 2, 2022 On 11/30/2022 at 10:19 AM, themongoose said: I’ve done the same as John. KJ Magnetics is a great company. The F/A-18 in my sig has all ordnance done this way. It did take 2 of those 1/16” magnets for the centerline tank. It almost floats in the air it’s so closely balanced. A key trick is to stack a couple magnets together and then apply each one. This keeps them from flipping as you glue them down. It also helps remind you which way to orient them when applying to the opposite surface ;-) if you are doing it separate vs assembly all at the same time. I wrote up a description of the technique for the Cincinnati club. You can see it here Hi , thank you exactly what I was looking for. Cheers Bob. themongoose 1 Link to comment Share on other sites More sharing options...
